Old Oct 17, 2008, 12:37 PM
aeroknot is offline
Find More Posts by aeroknot
still learning
aeroknot's Avatar
west Georgia, USA
Joined Nov 2007
over in the flying wings forum, there was a thread about noise and pushers.
Several posters agreed that cutting out the edge in front of the lateral half of the prop reduced noise significantly. One person had semicircular cutouts on both sides of the motor mount, in front of the outer half of the prop.
I don't know if a micro-sumo is noisy with a 17 g motor, but when I build my micro-sumo, I'll see if I can make the slot wider on the outside than in the middle by cutting the edge in front of the prop at an angle, and leaving the back edge straight for CF support.
aeroknot is offline Find More Posts by aeroknot
Old Oct 17, 2008, 01:32 PM
aeroknot is offline
still learning
aeroknot's Avatar
west Georgia, USA
Joined Nov 2007
Originally Posted by REVKEV6
don't have any first hand experience with prop in slot setups, but the noise issues is due in large part to the two flat edges running parallel to the prop. It creates a pressure wave the causes noise. if you angle the the slot (make it diamond shaped for example) you should see a reduction in noise.
Kindof like what REVKEV6 wrote in post 7, only a bowtie shape, or some variant. I'll probably try the two semicircles along the lateral part of the front edge of the slot....
Old Oct 17, 2008, 09:45 PM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Edge beveling had relatively little effect compared to slot size and shape. The "dog bone" version on the right in my photo above was not as good as the "tail-less" one to the rear but was best compromise lift vs thrust.
rich smith is offline Find More Posts by rich smith
Discussion Aileron slot for RDS in Genie 3 pc. wing harleym Thermal 0 Jan 28, 2008 12:53 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
design for flying in wind maciek Aerial Photography 18 Jan 29, 2005 02:37 AM
What Prop for Zagi in Utah(4200 ft)??? Bob The Podder Foamies (Kits) 3 Mar 31, 2003 09:57 PM
OK, wizards, need ideas for prop/batt with GWS 100 in Pitts Chuck Parkflyers 5 Aug 24, 2002 10:33 AM
