Old Sep 26, 2008, 04:48 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I recently read (I can't seem to remember where) that using a jagged edge, like what them stealth fighters use (triangle teeth, sort of) may reduce the noise. I may give this a try, as i'll be building a prop in the slot jet this week end.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Sep 26, 2008, 05:26 PM
jnida63 is offline
Find More Posts by jnida63
Columbus, Ohio
Joined Jun 2005
I like the noise. nothing like a mid slotted prop doing 22k rpm!!!
jnida63 is offline Find More Posts by jnida63
Old Sep 26, 2008, 05:31 PM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Originally Posted by thewz
hey....wait a gosh darn second....if it only takes a minute why don't you do it now? jk
Takes ME more than a minute and hourly rates $250/hr so PM and I'll send Paypal address. Seriously, over a dozen planes need lotsa room and it's pouring outside (we're feeling Kyle). Left my SCUBA gear at home.
As far as serrated edge, been there done that. Nothing we did to the edges made any significant difference in thrust but made the sound change in some cases I recall. I think this trick is used by F3P guys on LE/TE to alter stall characteristics. I did try vortex generators on the Quicksilver but those wings don't stall anyway so no diff..
rich smith is offline Find More Posts by rich smith
Old Sep 26, 2008, 06:02 PM
rich smith's Avatar
Joined Dec 2006
There...I'm soaking wet and ESC is sparking and arcing! I hope you're satisfied!
My client better not find out what I've been doing on his dime.
Old Sep 26, 2008, 06:34 PM
boberos is offline
Find More Posts by boberos
Ontario Canada
Joined Aug 2003
Hi Lead,
I usually taper the LE & TE of the slot, but I have never noticed much difference in speed or noise with my type of sport flying.
I am sure that there is an improvement but I have no means of measuring it.
Bob
boberos is offline Find More Posts by boberos
Old Sep 26, 2008, 07:16 PM
jason23 is offline
Find More Posts by jason23
Brisbane Queenland
I think what we are seeing is an effect similar to prop cavition on a boat propellor and that the gap in front of the slot is just as inportant as the one behind and its shape and size will be in relation to the prop used. Maybe I am just imagining things but even pushers with the prop set close to any rear surface seem to be noisier that those with prop set back little.
jason23 is offline Find More Posts by jason23
Old Sep 26, 2008, 08:33 PM
Mikey C. is offline
Find More Posts by Mikey C.
"Hobby Apparatus" Flyer
Mikey C.'s Avatar
Oxford, PA
Joined Aug 2003
I just had a brain wave. Why not bevel opposing edges into the back of the slot (the edge that the prop "pushes" air over)? Instead of simply thinning it out or putting an edge, you bevel one side with, say, 45 degrees facing up, then the other side with 45 degrees facing down. You would do this in order to counter act the torque of the motor-- sort of like crude, fixed-in-place louvers.
I can't be the only one who's thought of this, no?
Here's a really crude representation of what I'm thinking. The wedges are on the back edge of the slot:
Mikey C. is offline Find More Posts by Mikey C.
Old Sep 26, 2008, 10:06 PM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
I always bevel the edge infront of the prop, and round the edge behind it.Don't know if it helps, but logic says it will a little.
62pilot is offline Find More Posts by 62pilot
Old Sep 27, 2008, 06:50 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Mikey, I think that is a good idea. Now how can we show that it works?
Prop clearance front and back seems to be important for reducing noise less noise which should mean more thrust.
What about the prop clearance at the sides of the slot. So far I've always kept it kinda close, but the pressure pulses from the tips of the propeller might be hitting there too and causing noise???
leadfeather is online now Find More Posts by leadfeather
Old Sep 27, 2008, 05:54 PM
jason23 is offline
Brisbane Queenland
I do not think that the sides of the slot are as important to the generation of noise as the pressure pulses will much less. That said i think a close fitting ring around the prop would increase the thrust by eliminating the radial loses ala a Korts nozzle. Then again all thrust benifits (if any) are likley to be negated by the extra drag of the devise. It was on he list of things to before i totalled my Dekan/Kosh F-22. Be intresting to see if anybody building something like the Sumo experianced this.
jason
Old Oct 17, 2008, 12:27 AM
achronox is offline
Find More Posts by achronox
Joined Jul 2006
Thrust Stand Data
I have a homemade thrust stand and did a quick and dirty test to measure the thrust with and without a slot.
I used a GWS 5x3 DD prop with a small (10g) BL motor in pusher configuration. The slot was cut out of a 12"x6.5" sheet of cardboard that was about 6mm thick. The slot size was approx 1" x 5.5".
I ran 2 power levels with and without slot - here's the data:
Slot Volts Current Thrust
No 6.3V 2.3A 96g
Yes 6.3V 2.3A 92g (~4% less)
No 7.6V 3.0A 130G
Yes 7.6V 3.0A 122g (~6% less)
So... there is a measurable difference, but its not that significant. I suspect the thrust would be reduced further if I had more flat surface in front of the prop, but my test stand gets in the way of adding this.
Anyway, I hope people find this data useful.
Andrew
achronox is offline Find More Posts by achronox
Old Oct 17, 2008, 04:20 AM
Winging it >
Joined May 2006
Andrew,
Very good work. Are you going to be able to continue testing and adding to the data?
From the data so far it appear that maybe the losses increase with power. It would be interesting to see if this trend continues with further power increases. On the KF ParkJet, the first slotted build had a 6x4 prop powered by the Grayson Hobby parkjet motor (about 150 Watts I think). It was very noisy and had a lot less thrust than did the pure pusher version. Based on you data and my experience, I'm guessing that the loss of thrust for a given slot size may become more pronounced as power increases.
In your test rig, could you add a fin right after the slot to see if a fin produces additional loss of thrust?
Can you test the effect of slot size?
Again great work, it is nice to have actual data from a controlled experiment, well done.
Old Oct 17, 2008, 06:22 AM
Tripod333 is offline
Find More Posts by Tripod333
Joined Jun 2008
i would love to see data with the different types of slot sizes, and slot LE/TE dressings, along with a best guess on noise changes.
I have a EPP F22 made of elmers foam board(paper on) that i recently put a new motor on. I had the prop centered in the slot but at the last second noticed that the prop adaptor was wobbleing. it was 3.17mm and the motor shaft was 3mm. the replacement prop adaptor was shorter, putting the Le oft he prop very close to the slot. the re-maiden of the plane left me very dissapointed in my new motor. This post has made me rethink the situation. i may give it another chance with a reconfigured prop/slot relationship.
Tripod333 is offline Find More Posts by Tripod333
Old Oct 17, 2008, 09:05 AM
achronox is offline
Joined Jul 2006
Hi Guys,
I will try to run a few more experiments with different slot sizes, and power levels. It may take a while, as I'm (unfortunately) busy with some business matters.
Stay tuned...
Andrew
Old Oct 17, 2008, 09:30 AM
rich smith's Avatar
Joined Dec 2006
Up to 30% reduction in thrust can be demostrated depending on slot size and shape. Generally in proportion to noise level.
No 6.3V 2.3A 96g
No 7.6V 3.0A 130G
Andrew
Discussion Aileron slot for RDS in Genie 3 pc. wing harleym Thermal 0 Jan 28, 2008 12:53 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
design for flying in wind maciek Aerial Photography 18 Jan 29, 2005 02:37 AM
What Prop for Zagi in Utah(4200 ft)??? Bob The Podder Foamies (Kits) 3 Mar 31, 2003 09:57 PM
OK, wizards, need ideas for prop/batt with GWS 100 in Pitts Chuck Parkflyers 5 Aug 24, 2002 10:33 AM
