Old Sep 26, 2008, 05:59 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it Ò>
leadfeather's Avatar
Joined May 2006
Slot design for "prop in slot"
Has any one done or know of any research on the slot for a "prop in slot" configuration.
What I'm interested in is minimizing the thrust reduction due to the slot, and also minimizing the noise caused by the slot. My guess is that a wider slot with more clearance behind the prop might be better. I also would guess that shaping the aft edge of the slot might help too.
Any data, research or theories out there?
leadfeather is offline Find More Posts by leadfeather
Old Sep 26, 2008, 06:14 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
I dunno about any research or data, but i havent found any noticeable preformance difference in prop in the slot and straight pushers, Ive even modified an old prop in the slot delta pusher by cutting out the slot (so its a straight pusher) to see if it made any difference, it didnt.
Be interesting to see if anyone has any actual data on this though.
jackosmeister is online now Find More Posts by jackosmeister
Old Sep 26, 2008, 06:54 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Dan. An Aussie guy makes wings with quite a big slot.... dunno if makes any difference. Maybe its just done for styling reasons or noise reduction?
http://www.tayloredtech.biz/TayloredTech/Home.html
dekan is offline Find More Posts by dekan
Old Sep 26, 2008, 07:35 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Lead, we thin the edges of the slot to provide the least resistance to airflow...
gpw is offline Find More Posts by gpw
Old Sep 26, 2008, 09:30 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Does it make a difference in noise? Interesting thread, it will be fun to follow the responses.
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Sep 26, 2008, 09:47 AM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
Maybe most of the noise is produced by the front of the slot and the prop blade......as pushers can be just as noisy
Old Sep 26, 2008, 10:02 AM
REVKEV6 is offline
Find More Posts by REVKEV6
massachusetts
Joined Apr 2003
don't have any first hand experience with prop in slot setups, but the noise issues is due in large part to the two flat edges running parallel to the prop. It creates a pressure wave the causes noise. if you angle the the slot (make it diamond shaped for example) you should see a reduction in noise.
REVKEV6 is offline Find More Posts by REVKEV6
Old Sep 26, 2008, 10:14 AM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
IIRC, Kai, the designer is the Shuriken, an F-22 type prop jet, says he puts the prop closer to the rear slot edge to reduce noise.
Update... I checked Kai's thread, and he says putting the prop at the rear edge was an attempt to reduce the noise. First page, post 5 and 6.
http://www.rcgroups.com/forums/showt...ighlight=kai+s
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Sep 26, 2008, 11:37 AM
Winging it Ò>
Joined May 2006
For someone with a "thrust test rig" already in place, testing the slot variations might not be too hard to do but could give some really helpful data on thrust and noise.
Old Sep 26, 2008, 11:42 AM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
I would be very suprised if there was any marked gain in thrust..... noise well?
Old Sep 26, 2008, 11:50 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
This has always been of great interest to me so recently I built a series of mid-motor deltas to settle the issue. One design has a slot which is barely big enough to clear the prop. It produces a loud (but cool) noise and requires 8 of 16 throttle clicks to stay aloft. Another has nothing behind the prop and bigger space in front of and around the slot (like Jacko). It is almost dead silent and runs on 6 clicks. A couple in-between configs perform as expected.
Noise requires energy which is robbed from the prop. I also found this to be true for a full size pusher ultralight aircraft I fly which makes a lot of noise when the prop is nearer the TE and requires noticeably more throttle.
Any vibration or noise from things like unbalanced engine/redrive or badly tracked props take away from thrust. More than you might think.
rich smith is offline Find More Posts by rich smith
Old Sep 26, 2008, 11:57 AM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
Any pics of your "quiet" slot Rich?
Old Sep 26, 2008, 12:12 PM
rich smith's Avatar
Joined Dec 2006
I will take some as soon as the rain clears. I will also do a build log on my "One Minute One Buck Delta" when time allows.
Also should mention that shaping the edges had no noticeable effect on thrust. Don't remember if noise changes but I'm guessing it did.
BTW the "quiet" one actually had no slot.
Old Sep 26, 2008, 03:28 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Now that's something I'm highly interested in seeing.. Especially in this economy!
~Kev
darksiede is offline Find More Posts by darksiede
Old Sep 26, 2008, 04:29 PM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
hey....wait a gosh darn second....if it only takes a minute why don't you do it now? jk
thewz is offline Find More Posts by thewz
Discussion Aileron slot for RDS in Genie 3 pc. wing harleym Thermal 0 Jan 28, 2008 12:53 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
design for flying in wind maciek Aerial Photography 18 Jan 29, 2005 02:37 AM
What Prop for Zagi in Utah(4200 ft)??? Bob The Podder Foamies (Kits) 3 Mar 31, 2003 09:57 PM
OK, wizards, need ideas for prop/batt with GWS 100 in Pitts Chuck Parkflyers 5 Aug 24, 2002 10:33 AM
