Old Sep 25, 2008, 05:42 PM
Reed is offline
Find More Posts by Reed
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Great little how-to Dan - now this is why we love this forum!
Reed is offline Find More Posts by Reed
Old Sep 25, 2008, 05:48 PM
DCS is offline
DCS
Find More Posts by DCS
DCS
TD is for Me
DCS's Avatar
NorCal
Joined Nov 2003
Greetings.
Ditto on the Kudos.
Question: Can you do a similar plug-making tutorial?
I'm mostly curious about how the plug is finished. Can it be carved from blue foam and then glassed? Will an epoxy finish stand up to the heat from the plastic? How did you make those nifty raised frames? How tidy does everything need to be? Will dust on the surfaces show up on the finished canopy?
You've whetted our appetities - now we want the second course!
Ciao.
- DCS
DCS is offline Find More Posts by DCS
Old Sep 25, 2008, 05:58 PM
the_canuck is offline
Find More Posts by the_canuck
Where's the wind?
the_canuck's Avatar
United States, CO, Denver
Joined Jun 2004
I've been using similar technique for a long time. Your setup looks alot more polished but the technique is as described.
One note, you dont' need a fancy plastic holder. I just taped the plastic sheet to a frame with 'zagi' tape. Make sure the tape make contact with the plastic and frame all around the edges.
Also, leaving sheet in the oven a bit too long causes a big mess.
I was using styrene based plastic sheets and the smell got real old real fast. Of course I was doing parts for kits so the volumes were high.
At one point I went looking for an old oven for the garage to get the smell out of the house. It didn't happen and now I don't have a garage. So my solution was to stop offering the parts in the kits.
Andrew
the_canuck is offline Find More Posts by the_canuck
Old Sep 25, 2008, 06:03 PM
masson74 is offline
Find More Posts by masson74
Dave Massongill
masson74's Avatar
yucaipa, ca
Joined Dec 2003
Hey Dan is that my canopy for the p-51???? I hope so
Dave Massongill
masson74 is offline Find More Posts by masson74
Old Sep 25, 2008, 06:19 PM
quigley257 is offline
Find More Posts by quigley257
Say when.....
quigley257's Avatar
United States, MO, Hillsboro
Joined Sep 2005
Very helpful how-to Dan. What kind of plastics are best for vac-forming? Are some better than others? I think I used styrene in the past. I would also like to see a mold how-to done sometime.
--quigley
quigley257 is offline Find More Posts by quigley257
Old Sep 25, 2008, 09:25 PM
TRISME is offline
Find More Posts by TRISME
It's not going to build itself
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Nice frame, I didn't think to use wood, the temps aren't that high after all.
Thanks for posting,
Tom
TRISME is offline Find More Posts by TRISME
Old Sep 25, 2008, 10:06 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Hey you're wasting plastic! You can easily get 2 F-80 canopies on the same pull.
TFLG is offline Find More Posts by TFLG
Old Sep 26, 2008, 10:04 AM
masson74 is offline
Dave Massongill
masson74's Avatar
yucaipa, ca
Joined Dec 2003
I think that second canopy is actually the p-51 ...No?
Old Sep 26, 2008, 11:50 AM
ISRDAN is offline
Find More Posts by ISRDAN
ISRDAN's Avatar
Joined Jul 2007
Thanks ,Reed.
DCS-
The plug needs to be very clean (glass like) The raised window frames are pin striping tape and then painted over,cool ha.
Canuck,
The plastic I use is called PEPG .040 I got it at S&W plastic in riverside Cal.
no smell or fumes.
Dave
Have plug will pull but the p-51 plug is M.I.A.
ISRDAN is offline Find More Posts by ISRDAN
Old Sep 26, 2008, 12:34 PM
Where's the wind?
the_canuck's Avatar
Joined Jun 2004
I wasn't doing canopies, but will try anything other than styrene the next time I find a need for vac formed parts.
.040 sounds pretty thick. I guess it will make strong canopies.
Andrew
Old Sep 26, 2008, 02:49 PM
k2k is offline
k2k
Find More Posts by k2k
k2k
k2k's Avatar
United States, CA, Oceanside
Joined May 2003
Is it PEPG or PETG? I've tried PETG but have not been able to get very good results. A lot of small pits on the inside of the plastic. What do you coat your plug with?
k2k is offline Find More Posts by k2k
Old Sep 26, 2008, 03:38 PM
DCS is offline
DCS
DCS
TD is for Me
DCS's Avatar
NorCal
Joined Nov 2003
Originally Posted by IRSDAN
Thanks ,Reed.
DCS-
You're a genius!
More questions:
1. What kind of paint?
2. Anything on top of the paint? Clear coat? Wax?
3. The paint doesn't transfer to the heated plastic?
Thanks for sharing your great techniques and for your patience with all these questions.
- DCS
Old Sep 26, 2008, 04:04 PM
SLOPE HEAD is offline
Find More Posts by SLOPE HEAD
Bash Burn Bury
SLOPE HEAD's Avatar
Vic
Joined Dec 2007
Nice one Dan! Keep up the good work mate.
Steve
SLOPE HEAD is offline Find More Posts by SLOPE HEAD
Old Sep 26, 2008, 05:33 PM
masson74 is offline
Dave Massongill
masson74's Avatar
yucaipa, ca
Joined Dec 2003
Dan I meant the P-51 canopy Carl was finishing from what Doug did. No biggie. I can wait. It is fun to see how it is done. You do amazing work.
Dave
Balsacraft Beaufighter Clear Canopy and Gun turret Airnut 2 Aircraft - Electric - Airplanes (FS/W) 2 Jun 30, 2004 08:18 AM
Clear Canopy for SAAB A32 Lansen Pippin Electric Ducted Fan Jet Talk 5 Apr 18, 2003 01:47 PM
Switchback clear canopy? = instrument panel Wright Flyer Parkflyers 3 Oct 11, 2002 01:14 PM
clear canopy graphite sailplane for video crux12 Aerial Photography 1 Sep 26, 2002 10:25 AM
