Old Feb 13, 2003, 08:49 PM
mardy is offline
Find More Posts by mardy
Dismember
mardy's Avatar
New Hampshire
Joined Jan 2003
My Voyager E has a bad case of the shakes
After recovering from a crash, my Voyager has been left with a violent vibration originating from the tail. I've tried replacing the tail shaft, hub, blade grips and blades with no luck. If I run without the tail blades, the vibration goes away. I've checked the balance and it's fine. I doubt it has anything to do with it, but since the crash, I also upgraded to a CF frame and boom. Any ideas?
mardy is offline Find More Posts by mardy
Old Feb 13, 2003, 08:54 PM
HankF is offline
Find More Posts by HankF
Joined Apr 2000
Are you sure your main shaft isn't bent?
Hank
HankF is offline Find More Posts by HankF
Old Feb 13, 2003, 09:07 PM
mardy is offline
Dismember
mardy's Avatar
New Hampshire
Joined Jan 2003
It was. I had to rebuild the head after the crash. The vibration is definately comming from the tail.
Old Aug 03, 2003, 01:02 PM
aeropuppy is offline
Find More Posts by aeropuppy
aeropuppy's Avatar
Joined Nov 2002
Re: My Voyager E has a bad case of the shakes
Did you ever solve your vibration problem?
Was it a loose or twisted belt?
aeropuppy is offline Find More Posts by aeropuppy
Old Aug 03, 2003, 01:07 PM
mardy is offline
Dismember
mardy's Avatar
New Hampshire
Joined Jan 2003
That was a while ago!
It turned out to be one of the tail rotor shaft bearings. They just snap into the plastic tail assembly. I put a small drop of CA on it and that fixed the problem.
Old Aug 03, 2003, 01:27 PM
aeropuppy's Avatar
Joined Nov 2002
Wow, so the bearing was spinning in the tail mount causing vibration?
Interesting observation with my voyager e ozace Electric Heli Talk 6 Dec 21, 2004 11:31 PM
Weird problem with my Voyager E Zod Electric Heli Talk 5 Nov 07, 2004 03:35 PM
My Voyager E has arrived :) Malc C Electric Heli Talk 22 Jan 10, 2004 06:13 AM
Will Quick EP10 Parts work on my Voyager E? spessx Electric Heli Talk 3 Jul 24, 2003 07:29 PM
Got my Voyager E - need pek help Terkan Electric Heli Talk 14 Jan 08, 2003 06:53 AM
