Old Sep 24, 2008, 11:51 AM
fdix is offline
Find More Posts by fdix
fdix's Avatar
Switzerland
Joined Dec 2006
3.2m (126in) Pilatus PC-6 Porter with 12kW
After some successful test with a Rascal 110 powered by an AXI 5345 on 12s (about 4100W) we decided to scale things up a bit.
Here is a video of the Rascal
Rascal 110 tow plane first tests with the Aeromod Toons (5 min 27 sec)
Specs so far
Ecotop Pilatus PC-6 Porter
Jeti Spin 300
HCS C12000W/4
some specs of the motor
voltage 10-15s LiPo
164 rpm/V
max efficiency 91%
max loading 300A /30s
weight 2080g
On 14s LiPo burst power would be about 14kW... We plan on using two 14s 6Ah packs in parallel. To charge them two of the new Robbe Powerpeak Eternity chargers are on the way... stay tuned for updates
fdix is offline Find More Posts by fdix
Old Oct 01, 2008, 08:17 AM
mackone is offline
Find More Posts by mackone
"the bouncer"
mackone's Avatar
Australia, VIC, Vermont
Joined Nov 2006
I think there is one of those motors in my washing machine
awsome vid great to see the electric advance
mackone is offline Find More Posts by mackone
Old Oct 01, 2008, 01:56 PM
Peter W is offline
Find More Posts by Peter W
Peter W's Avatar
London
Joined Jul 2001
what prop does that motor turn?!
Peter W is offline Find More Posts by Peter W
Old Oct 01, 2008, 03:06 PM
fdix is offline
fdix's Avatar
Switzerland
Joined Dec 2006
Thanks! What washing machine do you have? Mine is only about 2kW.
The manufacturer recommends props form 26x12 up to 30x12. I am hoping to run a Mejzlik 27x12 three blade
Old Oct 01, 2008, 05:41 PM
Peter W is offline
Peter W's Avatar
London
Joined Jul 2001
who makes that motor? any pics of it in someones hand?
Old Oct 01, 2008, 05:48 PM
MarkF is online now
Find More Posts by MarkF
Battery Puffer
United States, NV, Las Vegas
Joined Nov 2001
Great airplane. We do aerotow in my area with the hobby lobby Taxi. Neu 2215 2y, 12s 2p 10,000 mah lipos, and 26 x 15 prop. It tows 4 to 6 meter gliders very well. Were do you order that airplane from. I like that plane a lot and have been looking for a bigger air frame. Thanks
Mark
MarkF is online now Find More Posts by MarkF
Old Oct 01, 2008, 05:57 PM
steve1814 is offline
Find More Posts by steve1814
One cell short of a Pack
steve1814's Avatar
Good ole Smithsburg, MD
Joined Mar 2007
Mark
Here is the link
you can get the motor from them as well...just don't faint!
I've been eying it for some time now.....Check out the Wilga-Awesome!
Cheers,
Steve
steve1814 is offline Find More Posts by steve1814
Old Oct 02, 2008, 02:41 AM
Peter W is offline
Peter W's Avatar
London
Joined Jul 2001
these packs obviously cost a lot, that aside, do electric tugs offer you guys any advantages over their gas counterparts?
Old Oct 02, 2008, 04:25 AM
fdix is offline
fdix's Avatar
Switzerland
Joined Dec 2006
Originally Posted by steve1814
Here is the link
Cheers,
Steve
Thanks for the responses!
Yep that is the plane... The motor is a HCS C12000W/4 made by Freeair in the Czech Republic http://www.freeair.cz not a Pletteberg Predator 30. It is a bit less powerfull than the larger Predator 37.
The Wilga is very nice but at 2.4m too small for big motors. A large tug is also nice because of its visual footprint, you can see a 6m glider a long time but the 2.8m Rascal 110 often started to become very small.
Peter,
there are not many large gliders where we fly and we were interested in building something crazy... so a big electric tug is perfect!
At the moment I am drawing the motor mount in CAD...
Old Oct 02, 2008, 11:05 AM
MarkF is online now
Battery Puffer
Joined Nov 2001
At the few scale glider events I went to in Las Banos the electric tug got used more than the gas versions simply because the gas ones had more problems keeping them running. Electrics are also quieter and less messy.
Mark
Old Oct 02, 2008, 11:18 AM
MarkF is online now
Battery Puffer
Joined Nov 2001
Steve, before the Taxi we went through 2 of those Wilgas from that web site. Its a very cool looking airplane but not a very good tow plane. The plane has bad flight characteristics and is tip stally. This is not an easy plane to fly.
Mark
Old Oct 06, 2008, 08:15 AM
fdix is offline
fdix's Avatar
Switzerland
Joined Dec 2006
Some progress...
I decided to divide the elevator since I did not like the idea of having two servos on one control surface if it could be avoided. If one elevator half or servo jams for any reason you still have one left, which is nice The elevators were closed with a triangle of 4mm balsa then covered.
Old Oct 06, 2008, 01:43 PM
fishdude1111 is offline
Find More Posts by fishdude1111
Spokane, WA
Joined Jun 2006
The Predator motor is incredible. I've seen it on 35% Imac planes. I was curios why they mounted the motor in the nose cone. I guess something
to do with CG. I'm glad to see battery size catching up with these motors,
the last plane I saw with this motor had so many packs paralled and seriesed
together it was the size of a car battery.
Best of luck
Great project.
fishdude1111 is offline Find More Posts by fishdude1111
Old Oct 06, 2008, 02:12 PM
Peter W is offline
Peter W's Avatar
London
Joined Jul 2001
on that note, any pics of the flight pack pls?
Old Oct 06, 2008, 02:30 PM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Very cool project, best of luck!
Jocke is offline Find More Posts by Jocke
Build Log Another Dumas Pilatus PC-6 Build LeeHoss Scale Kit/Scratch Built 120 Apr 28, 2012 06:29 PM
Discussion Top Gun Pilatus PC-6 Turbo Porter netdudeuk Sport Planes 5 Jan 22, 2007 05:30 AM
Pilatus PC-6 "Porter" for IPS Power P. Tritle Scale Kit/Scratch Built 106 Sep 18, 2005 09:30 PM
Rave Foam Porter Pilatus PC-6 maiden flight TuD0R Foamies (Kits) 0 Dec 12, 2004 04:52 PM
Pilatus Pc-6 Turbo Porter Parkflyer kestrel2003 Parkflyers 23 Jan 02, 2004 06:19 PM
