View Poll Results: Is this gonna work ?
Awesome freaking cool, hell yeah it will work! 21 72.41%
Interesting contraption, but I don't think it will fly, sorry. 8 27.59%
Voters: 29. You may not vote on this poll
Old Sep 24, 2008, 04:04 AM
Taoweiji is offline
Find More Posts by Taoweiji
Dark Lord of the Sith
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
Poll
Stryker F27-X Build Log
I think this would be the most suitable forum for the build log...seeing she is based on the F27 wing...
I have been playing with the idea for a while to build an X-wing F27...the F27-X, but I did not have the experience or skill I gained over the past year (or the parts and motors, ESC etc)
But , I think I have learned a few things in 2008, including how not to build a plane , in my F4 Phantom build log...so here goes build log #2
Taoweiji is offline Find More Posts by Taoweiji
Old Sep 24, 2008, 04:16 AM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
Here I started the fibreglassing. In a previous attempt, I used epoxy finish cure resin. On both a F27 wing (still to be finished and she is HEAVY, and the bottom of my F15-P).
This time I decided to try Minwax polycrylic, as somebody had suggested I try it in my F4 Phantom build thread. I had used epoxy for her too and the beast was so heavy she never flew. I did learn a lot though...how not to do things
Old Sep 24, 2008, 04:19 AM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
I applied the cloth in 3 sections on the belly. Left wing, right wing (overlaps for added strength, and nose section.
Old Sep 24, 2008, 09:02 AM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
nice!!!
what are you going to use to power it?
brian94066 is offline Find More Posts by brian94066
Old Sep 24, 2008, 01:37 PM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
A nuclear reactor
Old Sep 24, 2008, 01:48 PM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
sorry, I'm being a wise-ass...I am not sure yet about the power system. I was thinking along a few different routes.
1- One Little Screamers Super Park Jet, driving a 6x5.5 or maybe 7x4 prop, Phoenix 35A ESC, TP 3cell 2200mAH lipo
2 Grayson Super Mega Jet, same prop and ESC and battery
3 TWO LSSPJ, installed on stick mounts where the vertical fins used to go !
4 Two ducted fans, Dons wicked extreme 5100kv motors, alfa df's... mmmm, maybe on the F27-X2 waddaya think?
IN any event, there is another matter to consider; the control surfaces. I started thinking roll and pitch only, just like on the F27.
BUT, now I am thinking yaw. So instead of two servos, installed in the bottom wing, and connected to the bottom and top wing elevons....I am thinking of installing 4 HS82MG servos, one in each wing, so that I can setup some kind of V-tail setup so I can knife edge the beast past the flightline filled with mouth-agape stunned old farts...whoahahaha
hehehe...
then I can maybe setup a 'airbrake' mode and have all the elevons...um, no, ruddevons...flick to the outside and she slams on the brakes. Might make a cool trick to come straight down, slowly !
Any input would be appreciated...
Old Sep 25, 2008, 02:52 PM
rawr404 is offline
Find More Posts by rawr404
Where'd my money go?
rawr404's Avatar
VA
Joined Jun 2008
I Wanna See It Fly!
rawr404 is offline Find More Posts by rawr404
Last edited by rawr404; Sep 25, 2008 at 02:53 PM. Reason: IT DIDNT LET ME DO ALL CAPS
Old Sep 25, 2008, 08:03 PM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
you and me both
I finished covering the top with lighter fibreglass, and gave top and bottom a few more coats of polycrylic. So far she is a lot lighter still that the F27 I covered with Epoxy.
Right now she weighs about 1lb, and all the electronics and battery will add about another 1lb, or 1lb 4ounces if I use a big battery
Old Sep 26, 2008, 10:19 PM
rawr404 is offline
rawr404's Avatar
VA
Joined Jun 2008
That looks sweet. What motor are you going to power it with? I'm assuming a it's a pusher, too, right?
Old Sep 26, 2008, 10:20 PM
rawr404 is offline
rawr404's Avatar
VA
Joined Jun 2008
nevermind i just looked at the post above it
hahaha
Old Sep 27, 2008, 09:58 PM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
Fitted the servos tonight, kinda worried about the control surfaces though. I have cut out strips pf Depron to the exact same size as the stock control surfaces, but I think they are going to flex a lot. Any ideas of wat I can use?
Old Sep 28, 2008, 12:57 AM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
I would use wood for the controls.
And use at least a 7 - 8" prop.... a stryker is draggy in its stock form... in whatever this form is it will be way more draggy. and heavy..
i would think a 15- 1700 kv outrunner and the 7 - 8 inch prop with 7 inch pitch should get you moving along nicely.
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Sep 28, 2008, 03:07 AM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
what kinda wood? ply?
Old Sep 28, 2008, 03:51 AM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
aileron balsa "wedge shaped" like http://www3.towerhobbies.com/cgi-bin...?&I=LXJD20&P=7 size of your choice of course... tower has tons and im sure there are lots of other manufacturers that have the same
turbored21 is offline Find More Posts by turbored21
Old Sep 28, 2008, 01:35 PM
Taoweiji is offline
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
I am trying to get a rimfire 35-36-1500 to work with this model, and I am having a hard time with it. I need 250W min, but prefer around 300W...I might use the good ole Grayson SMJ that can handle 40A, with a MAS 7x5 prop, Phoenix 60A ESC I get 350W...I sure do want to use this damn motor though, I bought it and I want to use it, not let it lie on the bench gathering dust....
turbored21 thanks, wil lgo look at the LHS for some
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
FFF-27 Stryker-Anybody interested:Build Thread dougmontgomery Foamies (Kits) 122 Sep 25, 2008 08:06 PM
Pocketcam X Build Thread....It begins! ZRX Doug Aerial Photography 98 Nov 16, 2007 11:57 PM
Best Prop for brushless Stryker F27? mark2025 Parkflyers 2 Mar 08, 2005 12:27 PM
Custom Building an F-27 Stryker: Will X-Port Work? Armchair Bronco Foamies (Kits) 0 Oct 24, 2004 07:05 PM
