Old Oct 05, 2008, 04:58 AM
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
Originally Posted by jjmouris
Me fly something slow, a foam model, join a club?! You must be kidding right?!.......
Joe
I fly RC combat for relaxation after F5B - 6 up together all trying to cut each others streamers. Not so fast but just as much fun. And the cheaper the model the better .
Why not persuade 'others' in your area to have a go - you can even do it with a Twinstar
Dick
dickw is offline Find More Posts by dickw
Old Oct 05, 2008, 02:12 PM
North vancouver, B.C. Canada
Joined Apr 2008
Dick
combat with everyone useing FPV would keep anyone occupied
that would be cool
Joe thanks for all you help, I re read your posts and you are a big help
thanks again
too bad there is not a contest in Seatle washington
I would be there lol
David22 is offline Find More Posts by David22
Old Oct 05, 2008, 03:16 PM
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
FPV ?
Think i'll rather do something not RC related...... like rowing!
By the way, i would suggest everyone refrains from using any RFM prop below 30 seconds of motor, just a little warning.
Joe
jjmouris is offline Find More Posts by jjmouris
Old Oct 05, 2008, 06:06 PM
Denmark
Joined Oct 2007
Joe
The reason being...? (You know that you can get reinforced versions, right?)
JeppeA is offline Find More Posts by JeppeA
Old Oct 06, 2008, 04:37 AM
jjmouris's Avatar
Joined Aug 2008
The reason beying that i have just sent 10 pairs back to Rudy. Even the reinforced ones crack at that sort of power. The don't crack at the LE and TE at the root but they go along the carbon tows. You think this is okey but the crack keeps growing and i imagine at some point there will be no more stucture holding the LE to the TE and the whole thing will collapse. A bit like a spar with no shearweb.
The simple fact is that his wide prop design is not suited to the high power we are using now. There is to much mass to excellerate and brake at switch on and off. No matter how much carbon you put in there.
However, i know Rudy is working on something!
At the worlds he was flying a reinforced RFM 18x19 with 1/3 of the blade cord removed by hand from the TE side. What does that tell you?!
Below 4,5KW the reinforced wide props (not the 16x16) are fine.
Joe
Old Oct 07, 2008, 01:02 AM
Denmark
Joined Oct 2007
Hmm, and I was looking forward to abusing my 220/37 P4 on 5S with a 17x18 RFM... Maybe not such a good idea after all
Old Oct 07, 2008, 03:21 AM
jjmouris's Avatar
Joined Aug 2008
That Plettenberg motor (P4) will also not survive 5S. To much RPM for it's design / construction.
Joe
Old Oct 07, 2008, 03:32 AM
Denmark
Joined Oct 2007
Rudi does it successfully on a 16x17, and on a 17x18 the rpm is even lower, so I don't expect that to be the biggest problem...
Old Oct 07, 2008, 03:51 AM
jjmouris's Avatar
Joined Aug 2008
Are you sure Rudy said it was a normal 220/37/A1/P4 ?!
What i heard was that this was tried but not succesfull by a few, including the German team members.
Old Oct 07, 2008, 04:52 AM
Tommy Persson's Avatar
Hillerød, Denmark
Joined Aug 2004
Jeppe, maybe you should discuss it once more with Rudi, or accept that your motor will not last for long.
Rudi was not using the 16 x 17 wide in Kiev, but a modified 17 x 18, if I remember it correct.
Maybe better to use the 220/42/A1/P4 6.7:1 on 5S, if you want/need to power up
Tommy
Tommy Persson is offline Find More Posts by Tommy Persson
Old Oct 07, 2008, 05:39 AM
Denmark
Joined Oct 2007
I have considered to go for a 42 long, but as I understand it is not available yet...
Rudi has used a 16x17 at all the Eurotour competitions I have attended...
My philosophy was that since Rudi gets about 33-35 sec motor on his 16x17, and this is what i have on 4S with the 18x19, then i could get more power by trying a 17x18 on 5S, and prevent the motor from overrev.
Well, I'll just have to try it out, only problem is to get the approval from the financial boss at home...
Old Oct 07, 2008, 06:38 AM
Mark Haigh's Avatar
Barnsley, Great Britain (UK)
Joined Dec 2000
Joe
Ive run the 220/37 on 5S with a 16x16 and it is OK, but the motor run time is very short. This motor seems better suited to 18x19 on 4S
Mark.
Mark Haigh is offline Find More Posts by Mark Haigh
Old Oct 07, 2008, 06:39 AM
jjmouris's Avatar
Joined Aug 2008
I think you might be wiser to change gearbox to 5.2:1 if you want a smaller higher RPM prop and shorter motor run times.
It certainly has worked for me with the Neu motors.
220/37/A1 P4 with 5.2:1 on 4S and RFM 16x17 should prove a very interresting and safe setup!
Joe
Old Oct 07, 2008, 06:41 AM
jjmouris's Avatar
Joined Aug 2008
Mark, 16x16 slim that is?
The 16x16 wide certainly will NOT handle that much abuse, reinforced or not!
Still, it seems there is a big chance it might throw a magnet.
Joe
Old Oct 07, 2008, 06:53 AM
Denmark
Joined Oct 2007
I don't want a smaller prop (at least not too much), I just want to try more power in less time, and see if it works for me or not...
After all, it depends if I can keep my climbs short enough!
Some thoughts on a park flyer for beginners kestrel2003 Parkflyers 5 Jan 01, 2004 09:17 AM
Some thoughts on efflux vs thrust. Hopperfly22 Electric Ducted Fan Jet Talk 57 Sep 16, 2003 10:30 AM
need some thoughts on understanding motor specs gouch Power Systems 4 Jul 09, 2003 04:58 PM
