Old Sep 22, 2008, 09:16 PM
sellonoid is offline
Find More Posts by sellonoid
Arvada, Colorado
Joined Jul 2008
Question
Do Spektrum AR7000/AR500 receivers use "JR" type servo connectors?
I want to use my $20 off at Tower Hobbies and buy some bulk servo connectors for use on my Spektrum AR7000 and AR500 receivers and Spektrum servos.
Tower has the following to choose from. (I'm showing just the male versions, but they have the same 3 choices in female of course.)
1) EMS Unassembled Male Connectors Futaba J
2) EMS Unassembled Male Connector J
3) EMS Unassembled Male Connector JR/Hitec/Z
sellonoid is offline Find More Posts by sellonoid
Old Sep 22, 2008, 09:48 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
3) is the correct servo connector.
1) and 2) should be the same. They'll fit Spektrum and JR receivers after some modification.
i.
ivanc is offline Find More Posts by ivanc
Old Sep 23, 2008, 12:04 AM
Arvada, Colorado
Joined Jul 2008
I don't know if the differences are pin size, pin spacing, or shell keying, or what. I noticed the Futaba connector shells in the pictures on the the Tower web site had neat little notches in the plastic, that seem to be for hooking your fingernail under to unplug them. But since I don't know what the modifications are, I'll play it safe and go with #3.
Thanks a bunch.
Old Sep 23, 2008, 12:35 AM
rsteffen42 is offline
Find More Posts by rsteffen42
Monterey, CA
Joined Jun 2006
The only difference between Futaba J and JR/H/Z is that Futaba J has a polarity tab on the side, and JR/H/Z have little beveled edges. JR/H/Z plugs fit Futaba receivers as is, Futaba J plugs can hit JR/H/Z after a moment's work with an sharp knife.
rsteffen42 is offline Find More Posts by rsteffen42
Old Sep 23, 2008, 09:31 PM
Arvada, Colorado
Joined Jul 2008
That's not bad. So they could be adapted in a pinch.
Thanks.
Old Sep 14, 2013, 09:37 PM
thailazer is offline
Find More Posts by thailazer
Joined Aug 2011
This is an old thread, but checking to make sure the pin sizes are the same. If all you have to do is file of the tab, then I am assuming the pins are the same.
thailazer is offline Find More Posts by thailazer
Old Sep 15, 2013, 09:44 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
As stated above, the only difference is the tab and bevelled edges.
Daedalus66 is offline Find More Posts by Daedalus66
Poll POLL: What type of connectors do you use for your video link? billpa FPV Talk 13 May 10, 2008 11:41 AM
Sold 2 Brand new in box Spektrum AR7000 DX7 receivers - $90 each shipped in US rcheliman Aircraft - General - Radio Equipment (FS/W) 0 Jan 11, 2007 02:50 PM
Whoops! JR type servo on Hitec/Futaba radio? geneb Radios 2 Mar 03, 2005 10:52 PM
What type of connectors do YOU use? pequeajim 3D Flying 37 Aug 12, 2004 11:05 PM
Are Hitec/JR servo connectors the same ? Al P Radios 2 Jul 07, 2002 11:04 PM
