Espritmodel.com Heli Air
Closed Thread
This thread is privately moderated by Mikemynameis, who may elect to delete unwanted replies.
Old Sep 22, 2008, 01:06 AM
Field of Dreams Flyer
Mikemynameis's Avatar
San Pedro,Ca
Joined Sep 2004
Trader Rating: 259
E-Flite Taylorcraft 450 ARF NEW PNP Updated Pics
I have Forsale a Brand New E-Flite Taylorcraft Electric Airplane which is ready to go has a Plug and Play Comes with everything installed just add your receiver and your ready to fly There are some minor things that need to be put together like glueing the stab on etc. All the servos are installed and well as the motor ,speedcontrol and also comes with a battery. I decided to put one together so the user dons't have to buy anything and that its all set up for you. Everything is brand new I will have pics of all the items that are installed in the plane.
Turnigy TR 35-30C 1100kv Brushless Outrunner
Input Voltage : 7.4V~11.1V (2~3S Li-po)
KV : 1100 rpm/V within 10%
Max. efficiency current : 10~15A
Dimentions : 35mm X 30mm / 1.38in X 1.18in
Shaft diameter : 4mm / 0.16in
Weight : 77g / 2.72oz
Number of poles/magnets : 14
Recommended model weight : 600~1300g / 21~45oz
Power equivalent : .12,2stroke
Stator Dimentions: 28-08
TURNIGY Plush 40amp Speed Controller
Cont Current: 40A
Burst Current: 55A
BEC Mode: Linear
BEC : 5v / 3A
Lipo Cells: 2-6
NiMH : 5-18
Weight: 33g
HXT900 9g / 1.6kg / .12sec Micro Servo x4
Size : 21x12x22 mm / 0.74x0.42x0.78 in
Voltage : 3v ~ 6v
Weight: 9g / 0.32oz
Speed : 0.12 sec/60(4.8V)
Torque : 1.6 kg-cm
Working Temp : -30C~60C
Teflon Bushing, 15cm wire, coreless motor
Servo arms & screw included
ZIPPY 2200mAh 3S1P 15C
Spec.
Capacity: 2200mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 15C Constant / 25C Burst
Weight: 168g (including wire, plug & shrink wrap)
Dimensions: 103x34x24mm
Balance Plug: JST-XH
Discharge Plug: T-Connector (Deans Type)
$290.00 Shipped
Mikemynameis is offline Find More Posts by Mikemynameis
Old Sep 22, 2008, 02:36 PM
San Pedro,Ca
Joined Sep 2004
Trader Rating: 259
updated pics
Closed Thread
New Product E-flite Taylorcraft 450 800mZero Parkflyers 4582 Jun 15, 2013 02:56 PM
Discussion E-Flite Taylorcraft 450 ARF shadow74 Electric Plane Talk 28 May 23, 2009 05:01 AM
Discussion E-flite taylorcraft 450 fighter_ace06 Scale Electric Planes 3 Jan 16, 2009 07:14 PM
Sold E-Flite Park 450 motor -New in Box kdii02 Aircraft - Electric - Power Systems (FS/W) 1 Sep 28, 2007 12:11 PM
