Old Feb 13, 2003, 11:34 AM
byrocat is offline
Find More Posts by byrocat
byrocat's Avatar
Aurora, Ontario, Canada
Joined Mar 2002
Catapult hook position and construction
I'm doing a bit of scratch-building (mentally right now) and doing a rough set of drawings to see if I have enough dta to start a prototype.
Anyway, one of the things that I haven't been able to find a lot of information on is the catapult hook.
When I flew sailplanes, the usual hook was about an inch or so of 4-40 rod, end-threaded, which was bent to give about an inch of wire to hook the bungee's ring unto. The threaded end of the hook went through the bottom of the fuselage and through a blind nut with another nut providing the locking to keep everything from coming apart too easily. Positioning was in front of the CofG, about an inch or so for the cautious types, up to just behind for the competitive types.
The blind nut went into a short section of basswood or plywood (abut 1/4 thick by one inch wide) which was tied into two bulkheads to spread the load.
Now, for EDF's, is such an arrangement workable?
If anyone has pictures of their installation (inside and out), or scans from the instructions or plans, it would be greatly appreciated.
I'm sure that there are lots of newbie lurkers (like me) who'd like to pick up the knowledge of more experienced fliers and builders.
byrocat is offline Find More Posts by byrocat
Old Feb 13, 2003, 12:14 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
The hook needs to be farther forward on EDFs than it is on sailplanes. The average position is about 40% of the distance starting from the nose and going back to the CG. EDFs would die quickly trying to launch them as steeply as the sailplanes get launched, the wingloadins are too high. The flatter launch of a more forward location is better.
I tend to use sailplane type hooks. 4-40 rod may snap if you try to use it, and bending the threaded rod is tough without it snapping. I use a plywood plate on the inside of the fuselage.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Feb 13, 2003, 01:56 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
my rule of thumb, is locate it half way between the nose and wing l.e. ............g
gregg f is offline Find More Posts by gregg f
Old Feb 13, 2003, 04:22 PM
Dr. Jet is offline
Find More Posts by Dr. Jet
H301 Libelle Pilot
Dr. Jet's Avatar
Oceanside, California
Joined Sep 2000
I wish I had a digital camera!
My newest tow hook is on the S&S F-86. I took a hunk of aluminum and milled out everything that did not look like a towhook. Afterall, this is a 7-1/4 pound beast and I use about 45# of pull on the bungee so I just couldn't use a wimpy hook! Then I epoxied a sheet of carbon fiber plate to the inside of the fuselage. The thing is attached with a countersunk 3mm FH machine screw in the back and an angled and countersunk 4-40 cap screw in the front. I'm sure someone will photograph it at the MWE and post it here (huh Gregg?? ).
Dr. Jet is offline Find More Posts by Dr. Jet
Old Feb 13, 2003, 04:32 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Re: I wish I had a digital camera!
dj: uncle joe is the official edf photographer. he's there now ......gregg
Help with tow hook position bilbobaggins Sailplane Talk 3 May 02, 2005 11:00 AM
Aerotow tow hook position? Soarbird Modeling Science 1 Oct 14, 2004 07:37 AM
Tow hook position relates to CG or to CL? gustabmo Thermal 5 Jun 03, 2004 10:02 PM
Wattage F86 bungee hook position. Arthur Electric Ducted Fan Jet Talk 3 Jun 26, 2003 08:00 AM
Bungee Hook Position on B/C kits ken_keeler Scale Kit/Scratch Built 2 Dec 12, 2002 06:01 PM
