Old Nov 12, 2008, 07:06 AM
Gandalf_Sr is offline
Find More Posts by Gandalf_Sr
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
If you go back to my post #108, you'll see the sketch I posted for how I think the setup will work http://www.rcgroups.com/forums/attac...mentid=2167198 Note this is a revised version posted today Nov 12,2008, the only difference is that the mixer for the rear control surfaces gets an input from the pitch gyro output - before this was wrongly fed through the front canard mixer.
You will notice that my design uses mixers to mix the gyro output with a channel I'm calling Hi Alpha (HiA). Mixers are used so that the following effects are produced:
Canards
- Normal Canards are level and controlled by the pitch (elevator) gyro
- Hi Alpha Canards are controlled by the pitch gyro but are offset up at the rear edge - amount of offset is controlled by the HiAlpha channel
Aileron Surfaces
- Normal Ailerons are level and controlled by the roll (aileron) gyro
- Hi Alpha Ailerons are controlled by the roll gyro but are offset up at the rear edge - amount of offset is controlled by the HiAlpha channel
Rear Surfaces + Motors
For normal and HiAlpha, the rear surfaces and motors are controlled by a mixture of pitch and roll gyros
Note As far as I can tell, RCSuperPowers' pitch gyro only controls the canard. He does produce an offset on the canards and elevons when he switches into HiA mode. In my design, the HiA channel produces an offset to the center position of 3 gyro-controlled servos (1 for canard and 2 for ailerons), I plan to initially control the HiA channel with a proportional control on my transmitter; from the video it looks like RCSuperPowers controls his with a switch.
A mixer is pretty easy to understand, it's basically got 2 inputs and 2 outputs. One input makes the servos move in opposite directions and the other input makes them move in the same direction. I'm using Digimix II mixers that have cool programmable features such as reversing; you can find them on eBay.
One caveat on all this... I HAVE NOT YET BUILT THE SYSTEM I POSTED THE DESIGN FOR. I've been busy with work and honey-do stuff. Also, now that I've printed out the plan, I've realized that I need to make something (wings?) removeable if I am going to be able to transport the plane in a vehicle because the WS is 47.5 inches.
Gandalf_Sr is offline Find More Posts by Gandalf_Sr
Old Nov 12, 2008, 09:45 AM
Go4it is offline
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
SU-35 three axis gyro setup
The attached wiring diagraw is Dave's Superpowers but I thought I understood it, until I tried setting it up. And now, I don't have a clue how it works completly. I did email Dave and he said he would get back on this project next year.
Go4it is offline Find More Posts by Go4it
Old Nov 12, 2008, 02:00 PM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
Actually that is MY diagram; note that I updated it to correct an error and you are showing the older version; I've added the corrected version as an attachment to this post. What do you want to know?
Old Nov 12, 2008, 02:27 PM
Go4it is offline
Go4it's Avatar
United States, FL
Joined Mar 2004
Wow!
All this time I thought this was Dave's diagram, sorry.
I guess what I need is a updated wiring diagram for the 3 axis sytem to do Hi alpha flight on a Su-35 with conards that tie into the gyro's and how the other gyro's are wired
Dave shows
3-gyros
3-mixers
2- BEC's
2- 40amp ESC
2-2200 lipo's
2-6 Ch receivers
Old Nov 15, 2008, 02:34 PM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
Basic Tests Work OK
I wired up 2 of my Digimix II mixers, one was behaving weird but was fine after I ran the programming routine on it. Then I added an EK2-0704 gyro to simulate the pitch gyro with the gyro output driving 1 of the mixer inputs and the other was connected to the HiAlpha channel of my receiver. I got exactly what I wanted so, as I expected, that confirms that the Digimix IIs are happy working with the output from the EK2-0704 gyros.
Trying to figure out what I need to do to make the wings removable or something.
Old Nov 15, 2008, 05:52 PM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Subscribed
mattyhawk is offline Find More Posts by mattyhawk
Old Nov 15, 2008, 08:51 PM
Go4it is offline
Go4it's Avatar
United States, FL
Joined Mar 2004
Gandalf_Sr
Great, that will help save some money. Keep up the great work.Digimax ll are half the price and the gyro at $12 can't beat it.
Old Dec 01, 2008, 06:33 AM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
I've been agonizing over the size of this moster; nearly 48 inch wingspan. I considered making a smaller version that used 6 inch props but my motors are known good with 7x5 props and anyway, my plan is only about 17% bigger than RCSuperPowers' (based off some measurements from the pictures and assuming he is 'normal' height); given that he comments that he wanted to try and build lighter, I guess that the extra wing area will work in my favor.
I plan to make it from inch Fan Fold Foam (FFF). I will make the rear fuse main deck out of double FFF with removable Kline Fogelman (KF) wings; there will be 2 CF rods that allow the wings to slide on from the sides.
Basic calcs show that I can get 530 W out of my motors but I still need to keep the build light - around 1400g (3 lbs) - in order to get hovering power to weight ratios.
Old Dec 03, 2008, 06:04 AM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
I was asked a question by Scottcr and thought I'd repeat it here for everyone to benefit from...
Originally Posted by Scottcr
Gandalf: I was wondering if you could help me with some gyro help? When Dave is holding his plane and he shows it pitching up the canards pitch down and as long as he is pitching the nose of the plane up the gyro maintains the canards in a pitch down config. I have the same gyro yet when I pitch up the gyro does pitch the canards down but does not hold it. Holding the plane with nose pitched up the gyro moves the canards back to neutral. How do I get the gyro to hold the pitch down as long as I hold the nose pitch up??? If you could help me out I would greatly appreciate it. I have a DX 6 trans the same as Dave. I am assuming it must be a programming solution but it is driving me nuts.
Scott
No probs Scott. The gyros that Dave (RCSuperPowers) is using are rate gyros (eSky 0704) and they detect movement in their control axis. So your description of what's happening matches my expectations. Try this explanation:
When you have the elevator control in the center position; this is feeding the gyro with a signal that really says "try to maintain a zero movement rate in the pitch axis". As the plane nose moves upward, the pitch gyro detects the movement and reacts by moving the canard to produce a downwards force on the nose - it's a rate gyro so the faster you move the nose up, the more the servo deflects down but only while the nose is moving. If you stop moving the plane, the gyro will center the canard again because it thinks it has stopped the movement. I think you may be confused by Dave's video - If you watch it carefully, you'll see that Dave throws a switch that causes the offset down pitch of the canards (and up pitch on the ailerons). In my diagram, you'll see that I implement that effect using a channel I call Hi Alpha although it's just a spare channel on the radio - I plan to control it using a linear control on my 12FGH transmitter.
Old Dec 03, 2008, 07:51 AM
Scottcr is offline
Find More Posts by Scottcr
Joined Sep 2007
Thanks Gandalf for the explanation. So let me see if I have this correct. I understand now that if the nose of the plane stops moving the gyro will go back to neutral. After looking at the video closely I did see them go back to neutral when Dave held the plane still. When he does the hialpha he has the gyro set up so the canards are pitched down which means even if the planes nose was pitched down the canards would still be in a pitched down config until he flipped the switch again.
I have not built the SU35 yet but put canards on my Northstar foamy.
Scott
Scottcr is offline Find More Posts by Scottcr
Old Dec 03, 2008, 08:19 AM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
Scott, it seems like you have fully understood
One word of warning, canards can make a plane VERY sensitive in the pitch axis, I suggest the following approach:
1. Make the plane fly OK with the canards level (maybe with the canard servo disconnected as long as the canards aren't likely to move in flight)
2. Connect with the gyro running the canards and set the gain of the gyro to a low value (50% suggested)
3. Test fly and gradually increase the gyro gain until you're happy with performance
Note. If the pitch is 'wobbling' then the gain may be too high, my experience was that 50% - 80% was the right range on my X42 but your experience my differ.
Ted
Old Dec 03, 2008, 08:34 AM
Scottcr is offline
Joined Sep 2007
Thanks Ted you have finally explained it in a way that someone with no knowledge of how gyro's work understands. I will try that and let you know what results I get. I am going to try and get out flying again in the new year. Until then guys have a good Christmas and New Years. I am going south to get away from the cold and snow for a while.
Old Dec 07, 2008, 08:09 PM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
I started my build today and decided to create my own build thread which is here.
Old Dec 13, 2008, 01:42 AM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
I've got Gyro's and mixers....time to experiment....
thewz is offline Find More Posts by thewz
Old Dec 26, 2008, 01:34 AM
GeekGod is offline
Find More Posts by GeekGod
What can I crash today?
GeekGod's Avatar
Louisville, KY
Joined Oct 2006
Incredible work Dave and others here.
GeekGod is offline Find More Posts by GeekGod
Which airfoil to make an AMD SU-35 to fly? Ado Slope 4 Sep 02, 2003 05:32 PM
Amd Su-35..... Ado Slope 3 Mar 05, 2003 06:17 PM
AMD F-14 or SU-35 conversion nadt770 Sport Planes 6 Dec 30, 2002 12:23 AM
Question Anyone flown the AMD Su-35 Superflanker? Ben74 Slope 2 Sep 18, 2002 10:18 AM
Jet Design Contest Project Su-35 borabora Electric Ducted Fan Jet Talk 14 Feb 20, 2002 02:51 AM
