Old Dec 09, 2008, 04:18 PM
sneasle is offline
Find More Posts by sneasle
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
no harm no foul.
I hope to get on my Z soon, probably won't happen until after I move next August as I fear it will take me the better part of a year to build it..
sneasle is offline Find More Posts by sneasle
Old Dec 14, 2008, 11:12 PM
bwalt822 is offline
Find More Posts by bwalt822
USA, WA, Edmonds
Joined Aug 2008
Work this weekend was to finish the wing to body fairing which went pretty well. Using hot water to bend the balsa then a heat gun to dry it out made for quick work.
The wing saddle went together pretty straight forward too. The major issue was that the stringers didn't line up but its the bottom of the plane so it doesn't bug me much.
Also, I drilled the holes for the wing bolt blocks a little crooked which made the nylon bolts want to come out at slightly different angles. This meant I had to put the bolt tubes at different angles otherwise it would be hard to unscrew the bolts.
Finally since the plane is pretty much ready to sand I weighed it again and it came out to 6.8 pounds. Lets hope covering doesn't add too much more. I also balanced it on my fingers and the CG is currently .5 inches in front of where it needs to be with the battery almost as far forward as possible. Covering will make it more tail heavy but I hope not too much more tail heavy.
All in all it has come out pretty well so far. I just have to add some of the 1/64th ply around the tail, put some balsa around the cockpit, sand, and cover.
bwalt822 is offline Find More Posts by bwalt822
Old Dec 14, 2008, 11:29 PM
sneasle is offline
War Eagle!
sneasle's Avatar
Joined Sep 2006
Looking good.
Don't feel too bad about being tail heavy. Very hard to get these planes neutral without some weight. Just the nature of the beast.
Old Dec 14, 2008, 11:59 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
its not tail heavy yet...
Old Mar 01, 2009, 05:43 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
Well I decided to put the kitchen scale that my fiancee got for her wedding shower to work to get a more accurate weight. Came out to 7 pounds flat by propping up 2 of the wheels to the approximate height of the scale and putting the scale under the third wheel. Repeat for all wheels.
I cant really do much finishing work until it is warm enough outside to sand. I dont have a place where I can do it indoors.
Old Mar 01, 2009, 05:51 PM
sneasle is offline
War Eagle!
sneasle's Avatar
Joined Sep 2006
Wow, long time coming update
How's the progress?
Old Mar 01, 2009, 06:09 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
well i haven't been able to do anything because I cant sand inside. So aside from attaching a few of the small trip pieces around the tail, its ready to sand, cover, and finish.
I wont be able to fly until probably late June anyway because my field box is up in the attic of my dad's house in St. Louis. All of that stuff wont be getting moved up here till I get married in early June.
Old Mar 01, 2009, 06:47 PM
Rodan is offline
Find More Posts by Rodan
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
Wow, 7lbs and not covered or balanced yet? You might have the same problem I had with the one I bought... I hope not...
Rodan is offline Find More Posts by Rodan
Old Mar 01, 2009, 06:48 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
The balance isnt too bad yet. Its about 1/2 inch in front of where it needs to be and the covering will push it back, just how much is the question. Even at 8 pounds I still think it would be Ok. It certainly shouldnt be anywhere near 13 pounds.
Old Mar 07, 2009, 03:15 AM
sdberlin is offline
Find More Posts by sdberlin
sdberlin's Avatar
Berlin Kaulsdorf, Germany
Joined Oct 2002
Hello,
for your motivation :
Gee Bee R2 1/5 (4 min 42 sec)
keep the pictures coming
regards
Stefan
sdberlin is offline Find More Posts by sdberlin
Old Mar 07, 2009, 11:03 AM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
AHHH, what is that aweful buzzing noise that it makes???!
Old Mar 26, 2009, 04:30 PM
KOMET 44 is offline
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
SD, I love it.I guess this is what I can expect from my electric 1/4 scale version . bwalt the weather is getting warmer.Hang in there,
KOMET44
KOMET 44 is offline Find More Posts by KOMET 44
Old Mar 26, 2009, 04:32 PM
sneasle is offline
War Eagle!
sneasle's Avatar
Joined Sep 2006
Get any sanding done?
Old Mar 26, 2009, 04:39 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
Still been too cold...It probably wont be until May that I do much work on it unless we get a warm dry weekend here. But I've also got to find an apartment by June so that might take up some time too.
Old Apr 02, 2009, 12:11 PM
miawesomemi is offline
Find More Posts by miawesomemi
Puget Sound Area
Joined Apr 2009
don't know about that
Yeah, you are going to be pretty busy in April/May... You'll find the time I'm sure. Don't stress about it, there will be plenty of time to fly.
miawesomemi is offline Find More Posts by miawesomemi
Question Anybody Interested In Another LightHawk + LightSpeed Build Thread? Bolt55 Hand Launch 13 Jun 19, 2008 03:16 PM
Question Is anyone interested in a Lap Dancer build log/question thread? robh Electric Sailplanes 12 Jan 07, 2008 11:32 AM
Wanted Page Aviation Gee Bee Z byoung Aircraft - Electric - Airplanes (FS/W) 2 Jun 25, 2006 02:02 PM
anyone interested in a Depron F-18 build? mjblack Electric Ducted Fan Jet Talk 24 Apr 21, 2004 12:05 PM
Anyone interested in Tartan Twin glow 2.66cu.in. DNA Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2001 01:43 PM
