This thread is privately moderated by Concordefan, who may elect to delete unwanted replies.
Old Sep 19, 2008, 07:14 AM
Concordefan is offline
Find More Posts by Concordefan
Trader Rating: -1
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
Trader Rating: -1
Wanted
Hotwire foam cutter set up
I ma looking to get full foam cutter set up for future projects. This would include bows of 2-3 different lengths with or with out nicrome wire, power supply with voltage regulator or switch for 3-4 different voltage settings.
Let me know what you have and price in mind, will go from there. Pms would be much preferred. Thanks
Concordefan is offline Find More Posts by Concordefan
Old Sep 19, 2008, 09:48 PM
benjhind is offline
Find More Posts by benjhind
Trader Rating: 10
Planted planes wont grow
benjhind's Avatar
Ontario, Canada
Joined Dec 2006
Trader Rating: 10
Hey Sammy,
Get a good 600W dimmer from Home Depot and wire it up to one of the 24V transformers from here http://www.allelectronics.com/make-a...formers/1.html (Items TX-243, 244 or 245). This will allow a number of bows with varying thickness and length.
Credit goes to Brad for the above info.
Ben
benjhind is offline Find More Posts by benjhind
Old Sep 19, 2008, 10:46 PM
icrashrc is offline
Find More Posts by icrashrc
Trader Rating: 30
icrashrc's Avatar
Indiana
Joined Jul 2003
Trader Rating: 30
How many amp 24v transformer is needed?
icrashrc is offline Find More Posts by icrashrc
Old Sep 19, 2008, 10:52 PM
benjhind is offline
Trader Rating: 10
benjhind's Avatar
Ontario, Canada
Joined Dec 2006
Trader Rating: 10
It depends on the application. I'm not the authority on this, but I'd go 4 or 5 amps. Just remember, the higher the amperage, the thinner/longer wire it will allow.
BGH
Old Sep 20, 2008, 06:39 AM
Trader Rating: -1
Scale Modeler
Joined Feb 2006
Trader Rating: -1
Hey Ben,
Ok brother will do it that way now, Yeah Brad (Igor) is a good person. As i remember cutting my Connie sections with Mike at times had up to 15 amps but that was at top end for harder areas.
Thanks Ben for the info. Cheers
Old Sep 20, 2008, 07:42 AM
CClark is offline
Find More Posts by CClark
Trader Rating: 3
XMarinE
CClark's Avatar
Ohio
Joined Jun 2005
Trader Rating: 3
What about doing light weight foam...such as the blue or pink insulating foam 2" or less? Just basic cutting, nothing elaborate? Can you use a car battery charger connected to a hand held cutter(bow cutter)?
I think I said it right????
CClark is offline Find More Posts by CClark
Old Sep 20, 2008, 08:20 AM
benjhind is offline
Trader Rating: 10
benjhind's Avatar
Ontario, Canada
Joined Dec 2006
Trader Rating: 10
Check out this thread for more info: http://www.rcgroups.com/forums/showt...72#post6002347
"Gilligan's Island" hotwire foam cutter; easy yet full-featured vpatron Foamies (Kits) 19 Dec 19, 2005 10:43 PM
hotwire foam cutter Blackhawk3D The Builders Workshop 3 Nov 20, 2003 08:21 PM
Robbe Mustang P51 (Foam) : flyable set-up ? Intruder Foamies (Kits) 21 Dec 23, 2002 05:43 PM
