Old Sep 18, 2008, 11:12 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked powered Freewing F-35 from BPhobbies
I just received the Freewing F-35 EDF ARF kit from BPhobbies two days ago and I am impressed with the kit quality and the price. Only $60 and for the ARF kit with EDF unit.
The kit was purchased here:
http://www.bphobbies.com/view.asp?id...6&pid=C2991668
I will be posting photos of my entire build and installation of the Wicked 4800 KV EDF motor into this model. The intent is to fly this on a 3S 2200 lipo pack.
See posts below for the build pictures.
Current F-35 status:
9/18/2008: Model is finished and ready to maiden. AUW is 15.8 oz with a TP3S 2200 Extremem V2 lipo. Watts are about 420 at the beginning settling to abotu 380 watts after 20 seconds. Thrust to weight ration is WAY over 1:1
The Don is online now Find More Posts by The Don
Old Sep 18, 2008, 11:33 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Mounting the Wicked 4800 into the EDF unit:
Additional notes:
1) The adapter used for installation can be purchased seperately here:
http://www.donsrc.com/cart/index.php...d&productId=72
When purchasing the Wicked EDF motor select "Standoff with XF/Eflite plug" when ordering and the adapter will be included.
2) You do not use the collet portion of the stock fan rotor adapter. You used the adapter listed above and the special mounting nut that comes with the EDF unit.
3) Before tightening the Wicked mounting screws all the way down, test fit the rotor to make sure it is not rubbing on one side only. If needed loosen the mounting screws and adjust the motor position until the rotor is centered in the EDF housing. Once centered, tighten the mounting screws.
Old Sep 22, 2008, 09:14 PM
rcwck is offline
Find More Posts by rcwck
Ohio, USA
Joined Jun 2004
How about a flight report?...................I might need one
rcwck is offline Find More Posts by rcwck
Old Sep 23, 2008, 12:51 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
don, that little guy is going to cook! looks like fun!
corsair nut is offline Find More Posts by corsair nut
Old Sep 23, 2008, 06:28 AM
Three-Wire is offline
Find More Posts by Three-Wire
AMA 562227
Three-Wire's Avatar
United States, CA, Bear Valley Springs
Joined Jan 2003
Don,
When your new one arrives, I'd be really interested in some test data with the Wicked 4000kv motor on 3 and 4 cells...
Three-Wire is offline Find More Posts by Three-Wire
Old Sep 23, 2008, 06:49 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
It was awesome right until it flew away on the maiden!
Here is all the video I have until it flew away!
Wicked Powered Freewing F-35 (2 min 59 sec)
Don
Old Sep 23, 2008, 06:50 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by Three-Wire
Don,
I will definitley do that. I willget eagletree plots.
Don
Old Sep 26, 2008, 06:46 AM
jemdesign is offline
Find More Posts by jemdesign
Rhode Island
Joined Feb 2007
Don,
What is the purpose of the thrust tube nozzle and spacer?
jemdesign is offline Find More Posts by jemdesign
Old Sep 26, 2008, 07:39 AM
SmoothCruizer is offline
Find More Posts by SmoothCruizer
Fly it before you paint!!
Delaware
Joined Sep 2006
thrust nozzle? lol its where your mind thinks its faster right? Don did you get that plane back?
SmoothCruizer is offline Find More Posts by SmoothCruizer
Old Sep 26, 2008, 11:44 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
My first one is gone, I can not find it. The new one is here and I will be working on it tonight. As far as the nozzle, the nozzle is added as the exit area of the kit is larger than the fan sweep area. What that means is that the air coming out the nozzle is slower in speed than what is exiting the fan. Generally EDF models want an exit nozzle of 80-90% of the fan sweep area. The nozzle I made is closer to 80% which gets a little more speed in a trade for thrust. Since this model is so overpowered as it is, the thrust is way over 1:1 so the smaller nozzle helps gain more speed yet you still get tons of thrust.
Don
Old Oct 25, 2008, 06:08 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
re
Any progress or flights on the new one Don?
Sammy70 is offline Find More Posts by Sammy70
Old Oct 26, 2008, 12:48 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Yep, the Specktrum AR6100E lost signal and it turned into a pile of foam in the ground
Don
Old Oct 26, 2008, 04:25 PM
turbored21 is online now
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
thats it the freewing jet is cursed!! "halloween!!" stay away..
lol...
sorry don i was really lookin forward to seeing how well that thing went.. ive been looking into my first real edf setup gonna try for a real scooter as it were wanted to see how that thing went with your gear
turbored21 is online now Find More Posts by turbored21
Build Log Wicked Powered EDO F-4 Phantom The Don Don's RC 16 Oct 17, 2011 07:10 AM
Help! Freewing F-35 fh64_lucky Foamy EDFs 7 Feb 18, 2010 07:55 PM
Discussion Does anyone fly the Freewing F-35? Smokescreen38 Foamy EDFs 9 Jul 01, 2008 09:25 PM
Sold F-35 from Oakdaleaircraft.com smooth6x6 Aircraft - Electric - Jets (FS/W) 4 Jun 01, 2006 01:49 PM
f-18 from EJF exowatt Electric Ducted Fan Jet Talk 6 Apr 27, 2001 07:58 AM
