Old Sep 17, 2008, 07:41 PM
Heli Hacker is offline
Find More Posts by Heli Hacker
Hang on, turbulence ahead
Heli Hacker's Avatar
St. Louis
Joined Dec 2007
Mini-HowTo
CX2 extended battery hanger using recycled training gear
I found a good use for the old training gear that I thought I would share.
I needed to move my battery forward for balance, and I ran out of zip-ties, so I cut off and discarded the part of the stock battery holder that prevents the battery from moving forward (the part they tell you to put velcro on). Then I cut two of the CF rods to desired length, in my case 110mm. I fastened the clips on by putting the screws through the holes that are in the lower bend of the battery holder legs. Short sections of the silicone tubing on the CF rods hold them in place.
The rods slope downward slightly, but the stock canopy still fits (barely). The rods can be moved backward also, if you need the CG to go in that direction.
Heli Hacker is offline Find More Posts by Heli Hacker
Discussion Putting on training gear for cx2 Andrewscx2rock Coaxial Helicopters 1 Jan 06, 2008 03:32 PM
Discussion HB FPIII battery life and training gear.... mcf34 Micro Helis 9 Jul 03, 2007 10:41 PM
For Sale FS: Blade stock battery/charger and training gear av8rOC Aircraft - Electric - Helis (FS/W) 1 Aug 08, 2005 11:25 AM
Voyager training gear size? jdmartin8 Electric Heli Talk 0 Jun 24, 2001 02:00 PM
