Old Sep 16, 2008, 11:47 PM
I just want to fly
justwanttofly's Avatar
USA, IN, Jeffersonville
Joined Aug 2008
GET THE PAPER OFF!! calling all fellow dollar tree/elmers foamboard users
I don't know if this is new but i kinda stumbled apon it..I use my alcohol as usual and this time it left the little thin layer of paper.You know that thin layer just enough to get you real .. Well i was like here we go again.I started to rub it leaving rub marks then i thought hmmm.... i reached under the kitchen sink and grabed Mr. Clean's magic eraser turned on the water started to rub and it all came off within 2 mins.
It works great i dont know if its new but i thought id share a trick that i did.i still have enough eraser to do 20 or more foam boards
justwanttofly is offline Find More Posts by justwanttofly
Old Sep 26, 2008, 10:35 AM
Strathmore, Alberta Canada
Joined Jan 2004
another thing that works really good is from lee valley they have finger nail scrubbers that work great I Use a tub from wallmart and soak the peices in the garage pull most of the paper off then use tis brush under the water to finish the deal off
nickrage is offline Find More Posts by nickrage
Old Sep 26, 2008, 04:16 PM
"Hobby Apparatus" Flyer
Mikey C.'s Avatar
Oxford, PA
Joined Aug 2003
Hey, that's pretty neat if it works. I think I have one of those, I'll have to try it out. Thanks for the tip
Mikey C. is offline Find More Posts by Mikey C.
Old Sep 26, 2008, 04:27 PM
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Or you can let the foamboard sit and completely dry. About 45 minutes. the paper and all that nasty stuff will fall right off.
thewz is offline Find More Posts by thewz
Old Sep 26, 2008, 05:47 PM
Joined May 2008
How thick is this stuff? I've been tempted to stop at the DT on my way home a few times but I've got over half a thing of FFF sitting around. I really like the FFF but my only problem is the waves in it. If the DT stuff is around 6mm I might switch.
jbarr2000 is offline Find More Posts by jbarr2000
Old Sep 26, 2008, 06:59 PM
Starting to Rebuild
Wingnut31's Avatar
Fayetteville NC
Joined Jun 2006
Roughly about 3/16" maybe less. It's good stuff but I like the depron.
Wingnut31 is offline Find More Posts by Wingnut31
Old Sep 27, 2008, 01:02 AM
I peeled a piece today and it measured 4mm without the paper.
adamdb is offline Find More Posts by adamdb
Old Sep 27, 2008, 01:48 AM
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
It's less than .25 inches more like 4.5MM
Old Sep 27, 2008, 02:13 AM
Indiana
Joined Nov 2004
On my dollartree foam I get around 4.5mm with the paper on and 4.3 mm with it off.
The trick to depaper it is to wet out the paper with alcohol and then let it completely dry.
OnGuard is offline Find More Posts by OnGuard
Old Sep 27, 2008, 04:17 AM
Seldom serious
ghostmechanic's Avatar
Not on RCG anymore!!!!
Joined Mar 2006
I've not done A LOT of foam board work because I didn't like it. I thought it was just floppy & weak. But what worked the best for me to get the paper off was to fill the bath tub half way up with really warm water & stick the foam in there to soak for a couple of hours with something to weigh it down & submerge it. After a while the paper just peeled right off in little pieces. It was a pain to clean the tub afterward & the wife did a lot of griping but it gave me results.
ghostmechanic is offline Find More Posts by ghostmechanic
Old Sep 27, 2008, 06:18 AM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Just buy yourself a few sheets of EPP foam 18 x 36 for like $5.00 a sheet 9mm thick 1.9# and your good for a long time.
tallflyer is offline Find More Posts by tallflyer
Old Sep 27, 2008, 11:22 AM
President, RC Dusters
gfdengine204's Avatar
Sandwich, IL
Joined Nov 2006
Another tried-and-true method is to put the foamboard in a large garbage bag, pour in a couple ounces of rubbing alcohol, and seal the bag. Give it a few shakes to get the alcohol on the board, then let it sit overnight. Open and peel.
I am told this works like a charm.
gfdengine204 is offline Find More Posts by gfdengine204
Discussion Taking paper off dollar tree foam board ziomatrixacs Foamies (Scratchbuilt) 8 Mar 30, 2009 01:17 AM
Discussion is there an easier way to get paper off of elmers board bretd123 Foamies (Scratchbuilt) 18 Nov 12, 2007 11:09 AM
Help! How do you take the paper off a foamboard? Draven Foamies (Scratchbuilt) 18 Aug 12, 2007 11:36 PM
Calling all Eco 8'ers... Where did yo get that... 50feet Electric Heli Talk 0 Aug 07, 2005 12:28 AM
How do you get the paper off of SturdyBoard?????? LBMiller5 Foamies (Kits) 14 Jul 02, 2005 01:33 PM
