Old Feb 12, 2003, 07:04 AM
liaudio is offline
Find More Posts by liaudio
Guest
liaudio's Avatar
Joined Dec 2002
Sarted building gws p-51. Whats the best tip you have for me? Thanks!
the subject heading says it all. What are the best mods that you did to your p-51 mustang, while building it, that really made it great? I am leaving to meet up with the Orlando GWS Squadron on Saturday morning and would like it completed by then. Should i not use the screw attaching method for the wing? I opted for landing gear, but should i change that and make it a belly lander? I understand there are other post concerning p51 builds, but i would like a general consenus of the best things to do. Thanks guys!
Michael
liaudio is offline Find More Posts by liaudio
Old Feb 12, 2003, 07:23 AM
av8rOC is offline
Find More Posts by av8rOC
plane crazy
av8rOC's Avatar
Northport, NY
Joined Dec 2002
My impression of the stang is that it is a very well designed kit. Any choices like gear/ no gear or rubber bands or not is personal preference and I have seen the work well both ways.
Personally I opted to have a belly lander. If you do this method make sure to line the belly and scoop with packing tape. I also opted to use the screw method for the wing. Its a cleaner look and the way I figured if I rip it out or work it loose after repeated bad landings I can always switch to the rubber band method.
Any other ideas guys?
av8rOC is offline Find More Posts by av8rOC
Old Feb 12, 2003, 07:25 AM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
http://www.rcgroups.com/forums/showt...threadid=92392
The above thread is just many threads that deal with the build of the famous GWS P-51D Mustang.
Here some more.......
http://www.rcgroups.com/forums/showt...threadid=89364
http://www.rcgroups.com/forums/showt...threadid=88301
http://www.rcgroups.com/forums/showt...threadid=87740
http://www.rcgroups.com/forums/showt...threadid=87190
Okay, it really is a personal choice to have landing gear or not and to either have retracts if you do go landing gear. The rubber band mount is a way not to crack up the FUSE for those that do land on their belly so, it really depends on what you decide.
If I were you, I would read as much as I could to make a good choice.
Ask yourself these questions.
1. Do I like a light plane that can stay up longer?
2. Do I like scale like take offs and landings with gear?
3. DO I have a place to take-off and land in a nice hard surface.
4. Do I have a nice grass field to belly flop if I decide no landing gear?
5. Do I like a very fast plane? If so, I need to reinforce it, causes weight and stress on airframe!
I hope this helps.
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Feb 12, 2003, 11:41 AM
k2rick is offline
Find More Posts by k2rick
k2rick's Avatar
laguna niguel, So Cal
Joined Dec 1999
Keep the cg at the recommended location and use a 9x7 prop if you use a 8 cell nimh pack
k2rick is offline Find More Posts by k2rick
Old Feb 12, 2003, 12:08 PM
gouda is offline
Find More Posts by gouda
Is it summer yet?
gouda's Avatar
Flight Level 46 X 92
Joined Feb 2002
here is another page with some info.
gouda is offline Find More Posts by gouda
Old Feb 12, 2003, 01:16 PM
LESLIEx317537 is offline
Find More Posts by LESLIEx317537
Inbox is almost full
LESLIEx317537's Avatar
Long Island, New York
Joined Nov 2002
Mike,
The best tip I can give you is don't fool around and crash it on your first flight.
Your notorious for inverted flights and landings 10 feet above ground.
If you want, I can take a look at it and check the CG for you before you go to Florida. Let me know.
Also, last I spoke to you, you only had rudder and ailerons controlling it. You need elevator. Rudder isn't required.
LESLIEx317537 is offline Find More Posts by LESLIEx317537
Old Feb 12, 2003, 02:04 PM
av8rOC is offline
plane crazy
av8rOC's Avatar
Northport, NY
Joined Dec 2002
If you want, I can take a look at it and check the CG for you before you go to Florida. Let me know. Also, last I spoke to you, you only had rudder and ailerons controlling it. You need elevator. Rudder isn't required.
Don't worry Les he'll be in good hands.....
(taps fingertips together like mr. burns) EXXXCELENT
Old Feb 12, 2003, 03:50 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
I opened up the batt compartment before gluing together, used a pull-pull system on the rudder, changed out the wheels for some foam wheels, and of course did retracts, oh yea a BL astro 010.
dave morris is offline Find More Posts by dave morris
Old Feb 12, 2003, 06:45 PM
liaudio is offline
Guest
liaudio's Avatar
Joined Dec 2002
no inverted flight 10' above ground?!?!?!??!?!
c'mon lesx537! You think im gonna goof around with this plane? Well....you are probably right, but i still want to build it correctly. I will leave the un-building up to gravity. But anyway, thanks guys. Especially guapoman.
Old Feb 12, 2003, 07:08 PM
liaudio is offline
Guest
liaudio's Avatar
Joined Dec 2002
well...im not using retracts......
i am not using retracts, and its not a belly lander. The above links really seemed to give advice for those using that sort of set-up. Also, what should i do if i need to add cooling passages or move the battery foward now that i have the fuse halves together? Will i need a more foward cg if im not using retracts?
THANKS. cant wait to crash...errr....ummm... i mean FLY her!
Old Feb 12, 2003, 10:37 PM
gouda is offline
Is it summer yet?
gouda's Avatar
Joined Feb 2002
The CG should be in the same place regardless of the retracts or any other feature you may or may not add. there has been lots of discussion about the CG location since the model became available. I think the general concencus now is that it should be near the factory location. Mine is about 3/8's ahead of the spar and it flys fine. Although some people are flying with it up to 3/4's ahead of the spar. A bit ahead of the recommended location is a safe way to start, then move it back a bit at a time as you get used to it.
Discussion Whats the best setup you have used so far? BowerR64 Mini Helis 31 Aug 08, 2007 09:24 PM
GWS P-51 Drivers- Best Setup? TiberianMaster Parkflyers 1 Oct 21, 2003 09:30 PM
Second GWS P-51 flight - no tip stalls Speedbug88 Parkflyers 13 Jun 17, 2003 07:57 PM
A single thread for GWS P-51 mods and building tips Chuck Parkflyers 12 Dec 06, 2002 11:35 PM
Whats the best price you have seen for GWS flight pack? AMTJIM Electric Plane Talk 7 Feb 09, 2002 02:07 PM
