Old Sep 16, 2008, 06:25 AM
www.ReaperBrushless.com
The Reaper's Avatar
Joined Jul 2007
Reaper Brushless Power Systems Videos UP
hey guys
Scott here from Reaper Brushless power systems this will be the place for information on our outrunners and applications. i will post videos and info on our line up.
adding some video for the GR35 and the GR45 we are waiting on the GR60 video.
Reaper GR35 In 3DhobbyShop SR (2 min 21 sec)
Reaper Brushless GR45 In the New 3DHobbyshop 55" Edge (6 min 1 sec)
Reaper GR60 In the NEW 3DhobbyShop 57" Sukhio (4 min 57 sec)
scott
The Reaper is offline Find More Posts by The Reaper
Old Sep 16, 2008, 11:49 AM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
varoom!.
Manta1 is offline Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Sep 16, 2008, 05:04 PM
ambientech's Avatar
Central Texas
Joined Jun 2008
Hey scott i ordered the slick from 3dhs and i have everything coming for it except the power system. I cant decide whether to get the hacker a30-12xl or your reaper gr-45.
Now here is my problem i have several hackers and zero problems with them! I tried a new motor that everyone in the thread was praising (scorpion) and have had nothing but problems with it! So i am weary about trying new motors! Also i hear they are very powerful but i have seen no prop/amp/rpm info about them. Is there any info you can give me so i can compare the 2 ? It would help you sell these if you can get the numbers posted here!!
thanks
ambientech is online now Find More Posts by ambientech
Old Sep 16, 2008, 05:49 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hello Scott
If you want a freeware REAPER CALC similar to Motrolfly Calc I can do
Louis
Fourdan is offline Find More Posts by Fourdan
Old Sep 16, 2008, 07:02 PM
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
Louis, run these numbers thru your calc
Originally Posted by BoneDoc
Here's my contribution:
GR 85
12S 3DH 5350
XOAR 24x10
Hacker/Jeti 170
RPM 9200
Amp 138
Watts 6000
I thought that seemed a little optimistic, being basically 100% of the voltage x Kv RPM using a 3.5V/cell figure and a 220Kv motor (9240 RPM calculated), but the numbers were confirmed here
Originally Posted by The Reaper
yeah that GR85cc is crazy power . but thats what josh was turning his vids are awesome with it.
scott
and again here
but his prop was spinning that fast because it was underpropped thus giving him the high effic rating and tach reading with its correct prop installed the motor should have run arround 84% effic. but we had to use what josh had on hand for the setup.
scott
I notice on this page that the Plettenberg Terminator is only able to manage 71~75% of voltage x Kv for their RPM. Since the Plettenberg Terminator is a comparably sized motor with comparable Kv, then the comparison would be valid.
This means Reaper has developed a motor that absolutely stomps the stuffing out of a Plettenberg. This is truely an astonishing breakthrough in motor design, Plettenberg may need to go back to the drawing board after this one.
Jeffery is offline Find More Posts by Jeffery
Old Sep 16, 2008, 08:18 PM
The Reaper's Avatar
Joined Jul 2007
motor info
hey chris
heres some of my test data on the motor attached in pdf.
scott
thanks
Old Sep 16, 2008, 08:43 PM
blucor basher's Avatar
United States, PA, Lancaster
Joined Jun 2003
Motor police, making the world a better place.
blucor basher is offline Find More Posts by blucor basher
Site Sponsor
Old Sep 16, 2008, 09:13 PM
ambientech's Avatar
Central Texas
Joined Jun 2008
hey chris
scott
Thanks Scott for the info!
Old Sep 16, 2008, 09:14 PM
The Reaper's Avatar
Joined Jul 2007
motor police
hey ben
i hired this guy they say hes good.
scott
Old Sep 16, 2008, 09:15 PM
ambientech's Avatar
Central Texas
Joined Jun 2008
What police? Just asking for more info
What is wrong with that?
Old Sep 16, 2008, 09:16 PM
The Reaper's Avatar
Joined Jul 2007
perferred
hey chris
if you ask what i like on them in flight i like the gr35 on 12x6 4s gr45 on 15x6 4s gr60 on 15x7 on 4s these are my favorites.
scott
Old Sep 16, 2008, 09:19 PM
The Reaper's Avatar
Joined Jul 2007
private joke
hey chris
sorry man nothing to do with you me and ben thing.
scott
Old Sep 16, 2008, 09:21 PM
ambientech's Avatar
Central Texas
Joined Jun 2008
My bad
I didnt read all the posts
Old Sep 16, 2008, 09:43 PM
And You're Not
Joined Oct 2002
Is there a problem?
If the numbers are correct, then Scott is a world beater. He verified them twice, he obviously knows his motors better than anybody.
When guys need childish cartoons to use in a debate (seems to be a lot of that going on lately), then that usually means they are tapped out.
Old Sep 16, 2008, 10:06 PM
Joined Jun 2003
The picture of Barney Fife, as Scott said, is just an inside joke between us. If you ever watched the Andy Griffith show, you'll understand. If not, you missed on some great Americana.
EDIT - BTW, I've been poking around a little. I managed to find a couple of posts that listed RPM for Hacker A100 and A150 setups...looks like 90-92% of theoretical 3.5V*S*KV RPM is accepted as believeable on Hacker setups.
Also, I've always used a 10% +/- on Kv for hand-would motors (Scott, the GR-85 we're flying is hand-wound, right?) so that's 200-240KV.
That gives us a theoretical RPM range of 8000-10400. Well, I was holding the tach for that 9200 measurement, and the tach appears to be working, so I think the most obvous explanation is that the Reaper is probably similar to the Hacker in its theoretical/loaded RPM ratio, and in fact has a KV of over 220, at least in this example.
I'm not a "motor guy" at all, and it doesn't seem too difficult to understand the numbers Josh posted as being within the norm for other motors in this size range. I think agendas make for hasty, and sloppy, and incorrect posting.
If Reaper has distorted the space-time continuum, it appears Hacker has too.
Site Sponsor
For Sale Brushless Power Systems Gregg28 Aircraft - Electric - Power Systems (FS/W) 0 Feb 23, 2008 09:07 AM
New Product **electrifly Brushless Power Systems Jim T. Graham Product Announcements 0 Apr 22, 2007 10:29 PM
Sold Brushless Power Systems - Castle, Esskay, Great planes Etonic Aircraft - Electric - Power Systems (FS/W) 6 Feb 14, 2006 05:05 PM
Discussion Twin Brushless Power Systems Bigplumbs Power Systems 4 Jan 07, 2006 11:21 AM
Question How do Brushless Power systems work? Spencer J Power Systems 8 May 14, 2005 05:18 PM
