Old Feb 14, 2010, 07:56 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
i build your circuit and messed around with charge currents and imput voltage levels.
Im afraid the way you drive the led is flawed. Its way to easy to get too much current flowing through the base of T3
sp00fman is offline Find More Posts by sp00fman
Old Feb 15, 2010, 03:30 AM
Peterfly is offline
Find More Posts by Peterfly
Peterfly's Avatar
Joined Mar 2006
Thanks for notice. My up-dated circuit can't work, I deleted it. But I confirm, my first circuit can work.
Peterfly is offline Find More Posts by Peterfly
Old Feb 23, 2010, 04:13 AM
hyper-dart is offline
Find More Posts by hyper-dart
Joined Oct 2007
hello,
I'm going to build the "advanced" version of the charger from the first post.
But I want to power him with a few small solarpanels, with a low charge current.
It will charge a small lipo in an autonymous robot (recharging station)
will this work or is this a no go situation?
grtz
Jacar
hyper-dart is offline Find More Posts by hyper-dart
Old Feb 23, 2010, 09:08 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
It should work, though, at 1C rate, you have to be able to get a solar panel that can provide enough charging current, so basically, if you want to be able to charge a 1000mah battery at 8.4V, you'll need a pretty huge solar panel. But with a low charge current (let say .1C), that would be a decent size. I could see this being a decent thing for charging a Parkzone Vapor 1S 70mah battery. The panel would be rather small, and could likely even work with indoor lighting (if big enough).
RealGambler is offline Find More Posts by RealGambler
Simple 3 cell LIPOLY charger Dan Baldwin DIY Electronics 84 Nov 12, 2008 03:23 PM
another simple lipoly charger Dan Baldwin DIY Electronics 16 May 20, 2005 05:25 PM
Power sources for Potensky Lipoly charger? mthomson Scratchbuilt Indoor and Micro Models 15 Sep 12, 2004 03:53 PM
Simple Li+ charger schematic Takao Shimizu Batteries and Chargers 10 Feb 22, 2003 09:05 AM
>300mah LiPoly charger, cheap? KnifeEdge51 Batteries and Chargers 3 Dec 16, 2002 10:47 AM
