Old Feb 15, 2003, 02:38 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
L200
Billy,
Radio Shack is the wrong side of the pond from me.
I suggest you check their web site. The L200 has been around for some time and is quite a popular chip so there is a good chance.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Feb 15, 2003, 05:16 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
@parkflyer
> i was talking about andy's
oops that was a misread on my part there.
makes since now.
billystiltner is offline Find More Posts by billystiltner
Old Feb 15, 2003, 05:34 PM
Parkflyer is offline
Find More Posts by Parkflyer
Richmond, VA
Joined Apr 2002
Andy,
I like Scott's charger, it works well and was cheap to build but yours is simplier. I may build that one just for the fun of it and it would give me another charger.
Is the L200 fairly available and at what cost?
thanks,
Grant
Parkflyer is offline Find More Posts by Parkflyer
Old Feb 15, 2003, 07:06 PM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
L200 availability
Grant,
The L200 is available from hobby electronics suppliers here in the UK for about 2.50 GBP for one off. I'm not sure what hobby suppliers of components there are in the USA, but Radio Shack was mentioned by Billy. You could start with them.
Andy.
Old Feb 15, 2003, 10:22 PM
Joined Nov 2002
here is the manufacturer of the L200
http://us.st.com/stonline/index.shtml
I checked radio shack - they dont have it
Digikey seems not to have it also but i didnt follow the links returned from the search.
Old Feb 15, 2003, 11:10 PM
srogers316292 is offline
Find More Posts by srogers316292
Webster, NY
Joined Jul 2002
The L200C retulator is available in the US from BGMicro
www.bgmicro.com
Cost is 1.99 ea plus S&H
Search on "L200". You probably need to download the pdf online order catalog to see the prices.
Do yourself a favor and get one of their 1.2 amp 12V wall warts to power the curcuit as long as you are getting the L200C.
I don't know how you would add a charging LED to the L200C circuit.
srogers316292 is offline Find More Posts by srogers316292
Old Feb 15, 2003, 11:29 PM
MX is offline
MX
Find More Posts by MX
MX
Embedded Systems Engineer
MX's Avatar
Grass Valley, CA
Joined Sep 2001
Originally posted by Hodgepodge
@ MX
I am not by any means an expert on electronics, but to vary the voltage, why couldn't you simply adjust R4 for the correct voltage?
If the voltage wouldn't go low enough, you could simply increase the value of R4 to say 3kohm or so.
Am I missing something?
I do use R4 to adjust the voltage. I use it to calibrate to exactly
8.4 volts (or 4.2). But if I use it to change the voltage when
changing the number of cells, I would always require a meter
to recalibrate the voltage each time. With the switch, changing
the number of cells only requires a flip of the switch, which
selects one of the two precalibrated voltages.
Does that make sense?
MX
MX is offline Find More Posts by MX
Old Feb 16, 2003, 01:09 AM
Hodgepodge is offline
Find More Posts by Hodgepodge
Hornet Basher
College Station, TX
Joined Jan 2002
Yes, that makes sense.
Could you calculate the resister value needed for 3 cells?
That was my real intention, and using a multimeter does seem a bit of a hastle
Hodgepodge is offline Find More Posts by Hodgepodge
Old Feb 16, 2003, 09:51 AM
Depdog is offline
Find More Posts by Depdog
Foam Flyer
Depdog's Avatar
Stockbridge, Georgia, United States
Joined Jan 2003
Mx thanks a lot for the pic, that is exactly what I was looking for. On the switches, what are you using?
Are they they single pole double throw (I confess I dont know what in heck that means, but at the Rat Shack I can find what I need if I know what to call it.)
Glenn
Depdog is offline Find More Posts by Depdog
Old Feb 16, 2003, 11:05 AM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
Andy
Very nice charger, i think that i will be building yours instead
Is there any way that a status led could be added, coz i dont charge without them !!
Josh
j8m8l is offline Find More Posts by j8m8l
Old Feb 16, 2003, 12:38 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Josh,
I have not tried this so I don't know how well it would work, but BGmicro sells a 1.5 volt 75ma grain of wheat bulb. If you put one across R3, it would add about 25ma to the charging current and should light while charging and get dimmer and go out when fully charged. I don't know how bright this bulb would be on the 0.5volts across R3, but it would be a very simple charge indicator if it was bright enough, and is worth a try. Any low voltage low current incandescent bulb might work.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Feb 16, 2003, 02:18 PM
j8m8l is offline
j8m8l's Avatar
London UK
Joined Apr 2002
That is an idea........but i dig electronics
Come one, somone out there must be able to work out something snazy
Josh
Old Feb 16, 2003, 05:32 PM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
Josh,
I will think about a simple way to add a LED but it may work out as complex as the LM317 circuit.
You could just attach a DVM across R3 and watch the current drop towards the end of charge.
Adding a bulb is a nice idea but the maximum voltage across R3 is 0.45V would it glow bright enough?
Andy
Old Feb 17, 2003, 12:45 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
You can see the charger design here:
LiIon Charger
And details on modifying for different cell sizes and number of
cells here:
Mods
330 ohms is the size of R4 for 3 cells. The only problem with
3 cells is I believe you need a power supply that can put out
higher voltage. More like 18 volts.
MX
Old Feb 17, 2003, 12:55 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
Glenn
My switches were from Radio Shack. All it needs are single pole
double throw (SPDT), but I ended up using double pole double
throw (DPDT). They came in a package of two. I used one to
switch the number of cells, and one to switch the cell size
(current).
Nice switch reference here: switches
MX
Simple 3 cell LIPOLY charger Dan Baldwin DIY Electronics 84 Nov 12, 2008 03:23 PM
another simple lipoly charger Dan Baldwin DIY Electronics 16 May 20, 2005 05:25 PM
Power sources for Potensky Lipoly charger? mthomson Scratchbuilt Indoor and Micro Models 15 Sep 12, 2004 03:53 PM
Simple Li+ charger schematic Takao Shimizu Batteries and Chargers 10 Feb 22, 2003 09:05 AM
>300mah LiPoly charger, cheap? KnifeEdge51 Batteries and Chargers 3 Dec 16, 2002 10:47 AM
