Old Aug 09, 2009, 10:21 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Hi Bill
I installed the Data recorder and osd pro in my CAP232 this week and made few flights with it yesterday and today. It is absolutly awesome to fly with it. The precision of the barometric pressure sensor is very good, they help me already in some aerobatics. The data are very clean and easy to read. I did not install the GPS in my CAP, it will be useless. But I will also use this system in my F-16 later this season, then I will use the GPS in it.
I did not make a video yet, I'm still in the fine tunning adjustement.
When the voltage was going bellow the voltage preset for voice alert, the voice begin to repeat for 1 to 6 time in a row the same message like VOLTAGE 8.5 VOLT. The voltage of the main battery fluctuate a lot, I don't know if I can do something to avoid consecutive repeating of the message, one time would be enough. Perhaps it's possible to do something in the firmware?
Bill you said it would be possible to set metric or us on each parameter individually. I do not ask so much, but at least to be able to choose metric for all the parameter and use use altitude in feet?
I saw in the data recorder manual that is possible for the wireless dashboard to configure Landing Speed Variable Beeps, but it is not possible with the osd pro.
This is the text copied in te data recorder manual for the wireless dashboard:
To set up a notification alarm which will begin beeping slowly at the specified airspeed, and increase down to a very rapid
beep at half the specified airspeed, follow the steps below:
1) Select the “Speed” parameter, and enable it.
2) Click “Low Alarm Enabled” button.
3) Enter the speed at which you wish the Dashboard to begin beeping slowly, as the Alarm Trigger value.
4) Click the “Enable a varying beep rate for this alarm” button.
Many person will like to use that feature to know when the plane begin to approch stall speed at landing, but also in flight. I would use it also in some aerobatic figure. Is it possible to add it on the osd pro?
VRflyer is offline Find More Posts by VRflyer
Old Aug 09, 2009, 11:04 PM
g00bd0g is offline
Find More Posts by g00bd0g
g00bd0g's Avatar
USA, CA, Watsonville
Joined Jul 2001
I just got back from the 2nd flight of my new Eagle Tree OSD PRO equipped FPV Easy Fly. For some reason the home arrow arrow and distance seem to be messed up as well as the speed and altitude ladders. Maybe I didn't get a good GPS fix? How do I know if my gps is ready to go? It worked well for the first flight...
Video Posted!
FPV Easy Glider 2nd flight (08/09/09) (12 min 12 sec)
I think I figured out my gps/home issues, I had the following options enabled.
Use Altimeter for RTH/Ladder:
Use Pitot for RTH/Ladder:
I turned them back off (as I don't have the barometer or pitot) and the home function and ladder guages seem to be working again.
g00bd0g is offline Find More Posts by g00bd0g
Old Aug 10, 2009, 01:14 AM
RCWingFlyer is offline
Find More Posts by RCWingFlyer
Naza, Rabbit, FF, MWC, FY
Saint-Petersburg Russia
Joined Jun 2008
Good day BillPa,
my suggestions about displaying flight times in a different variations, do you remember?
RCWingFlyer is offline Find More Posts by RCWingFlyer
Old Aug 10, 2009, 03:09 AM
Neo360 is offline
Find More Posts by Neo360
Joined Jul 2009
Billpa, you should be able to use two of this input on eLogger v3 (Temp1, Temp2, Temp3 and Throttle) to get the video battery voltage and the RSSI function.
I hope to use this way.
Neo360 is offline Find More Posts by Neo360
Old Aug 10, 2009, 04:21 AM
Neo360 is offline
Joined Jul 2009
Billpa, look the graphical compass with the 1.38 firmware
Old Aug 10, 2009, 07:58 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
VRflyer, thanks for the feedback!
Regarding the repeating voice alarms, when your voltage fluctuates, yes we need to find a way to fix that. We need to add some hysteresis to the trigger, or add a repeat time. I have opened a bug on that and we will get it fixed. Do you know approximately how much variation you are seeing in your voltage (for example, does it jump from 8.3 to 8.6 volts, or more/less?).
We also have the feature of individually choosing metric/english units on the list.
Yes, we will also add the stall speed feature to the OSD Pro. That's a nice feature to have when doing FPV!
RCWingFlyer, sorry, I missed your feature requests for times. I have now added those to our feature list.
Neo360, we will be releasing a new add-on board for RSSI measurement, at least for Thomas's LR transmitter. There is a problem when using the eLogger temperature input directly with Thomas's transmitter.
Regarding the compass problem above, if you disconnect power from your system, and re-apply power, is the compass correct?
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Aug 10, 2009, 08:32 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I will record a video of my flight, a picture worth one thousand words, imagine a video...
Old Aug 10, 2009, 11:10 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
So Bill... Is there any way to read any RSSI data from Thomas's System right now?
Cheers
-J
The_Mongrel is offline Find More Posts by The_Mongrel
Old Aug 11, 2009, 12:18 AM
KnimRod is offline
Find More Posts by KnimRod
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
Cycling the power fixed the issue for me and is probably why I didn't see a difference in the 1.37 Alpha firmware when I tried that.. However, every time I make some change to the display now, the offsets get screwed up until I power cycle the OSD again..
KnimRod is offline Find More Posts by KnimRod
Old Aug 11, 2009, 12:51 AM
billpa is offline
billpa's Avatar
Joined Nov 2003
Mongrel, right now there is no way to read the RSSI from Thomas's system (but we're working on it!).
Knimrod, correct, immediately after changing the settings the display would be incorrect, but after the first power cycle, the display should be correct.
But, this was annoying, so I just fixed it. :-) Version 7.81 has the fix:
http://www.eagletreesystems.com/Late...beta/setup.exe
Regards,
Site Sponsor
Old Aug 11, 2009, 02:17 AM
Kiof is offline
Find More Posts by Kiof
Kiof's Avatar
Tarifa, Spain
Joined Nov 2007
Hi every one
Finally I change the video TX. Lawmate (before) vs Airwave (now)
I think there is big diference about the quaility, not only for the OSD also for the video quality. anyway i think my old lawmate tx was a little "tired" after two years and various crashes.
In the first video i try for first time to active also some voice alarms and variometer... I like this feature.
Airwawe 500mw:
Nº 26 - Persecución FPV en ladera: e-hawk vs Petrel 5m (4 min 6 sec)
Lawmate 500mw:
Nº25- Vejer de la Frontera. E-hawk 2200 fpv (9 min 44 sec)
Best regards
Kiof is offline Find More Posts by Kiof
Old Aug 11, 2009, 02:57 AM
Neo360 is offline
Joined Jul 2009
Regards,
You have now released this addon? Work on Futaba 2.4ghz Rx?
If you want I can try with my TX use the input temp on the elogger, which I say that I have to make. Maybe on the futaba in 2.4ghz should be!
Old Aug 11, 2009, 09:32 AM
KnimRod is offline
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
That did the trick! Thanx!
Old Aug 11, 2009, 05:01 PM
emagnee is offline
Find More Posts by emagnee
Pseudo-Pilot
emagnee's Avatar
Grand Blanc, MI
Joined Oct 2005
Originally Posted by Kiof
Hi every one
Airwawe 500mw:
http://vimeo.com/6016246
Lawmate 500mw:
http://vimeo.com/5768536
Best regards
I can't beleive the difference in quality! I always thought the problem was my camera. My video looks the same as yours, but my Tx is <1yr old and has been in no crashes. I've always heard good things about Lawmate.
emagnee is offline Find More Posts by emagnee
Old Aug 11, 2009, 07:24 PM
npole is offline
Find More Posts by npole
Joined Apr 2009
Bill, as far as you know/predictable.. the delivery date of the new batch still set for the next week?
npole is offline Find More Posts by npole
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
