Old Jul 18, 2009, 07:43 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
Originally Posted by billpa
BlueAngel, glad 7.73 is working for you. I've not been able to reproduce any ugprade issues from 7.73 to 7.75 (just tried again here) but will work with you when/if you need to upgrade again.
Regards,
Bill, for Eagle Tree
I have tried again today to update OSD Pro to firmware 1.35.
Updating works, but the error code comes again when i hit the OK button.
System is Windows Vista 64bit
this time a made a screenshot for you:
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Jul 18, 2009, 08:16 AM
garris2 is offline
Find More Posts by garris2
Melbourne, Australia
Hi Bill, I have a question regarding the use / operation of the Aux2 input for turning the overlay on/off and page switching.
Is it supposed to work like this..... say you have 2 or more pages of OSD data set up in the "Choose parameters to Display" window, and you have Change Pages with Aux2 enabled, and you also have turn OSD on/off with Aux2 enabled....
Should each toggle of the AUX2 input cause the OSD to cycle through each page of data and then to OSD off, then to OSD on again, then through each page again etc.
sorry for my long winded question but thats how I'm thinking its supposed to work but its not working for me that way.
If its not supposed to work that way could you explain how its supposed to work.
thanks Geoff
garris2 is offline Find More Posts by garris2
Old Jul 18, 2009, 08:47 AM
FPV Bill is offline
Find More Posts by FPV Bill
Austin, TX
Joined Sep 2007
thanks Geoff
I've been using the feature and believe it is working as designed. I have 2 pages setup and have it configured to turn off with the Aux 2 switch. Here's how mine works, which seems correct:
Start at page 1
<Flip the switch>
Swithes to page 2
<Flip the switch>
Turns OSD off
<Flip the switch>
Turns OSD on at page 1
What are you seeing?
FPV Bill is offline Find More Posts by FPV Bill
motiganot is offline
Find More Posts by motiganot
motiganot's Avatar
Israel
Joined Jun 2008
Eagle Tree PRO R.T.H test
On windy day. without FMA AP i did my first RTH test.
the RTH was on bearing only.
and it is working excellent
http://www.youtube.com/watch?v=Cy45G...er_profilepage
motiganot is offline Find More Posts by motiganot
Old Jul 18, 2009, 12:15 PM
rob mueller is offline
Find More Posts by rob mueller
ok, maybe it is a toy
rob mueller's Avatar
Alberta, Canada
Joined Oct 2002
Originally Posted by rob mueller
Hi Guys. I am trying to get my voice prompts to be clearly heard. The problem I have is the there is a lot of background noise from the microphone on board. I snipped off the microphone wires, and just a huge amount of interferenece white noise. Any recommended solutions? Using a Future hobbies system. I want to keep the vice prompts and eliminate any microphone or other interference noise- when I remove the mic.
Thanks!
Hey Bill/Gentlemen. OK, so I muted the speaker but I am getting a lot of interference sounnd when the voice alerts speak. Anyone have an idea how to silence all the loud white noise transmitted when the voice alert talks?? On my FutureHobbies 900mhzVideo Tx, the worst interfence on sound is channel 1. The other 3 channels are better, but not perfect by any means. Thanks for advice in advance!
rob mueller is offline Find More Posts by rob mueller
Old Jul 18, 2009, 10:03 PM
downeym is offline
Find More Posts by downeym
Electric Addict
downeym's Avatar
United States, GA, Atlanta
Joined Apr 2002
I had another great flight this morning...
7-18-2009 thermal soaring flight (51 min 27 sec)
Its not really edited, so if you don't want to watch the whole thing (I don't blame you) here are the highlights
1:00 takeoff
3:15 motor shutdown @ 2100 ft
5:41 found a nice thermal @2074 ft
8:09 managed to scratch up to 2300ft
12:49 down to 1748 ft but found the thermal again
16:55 up to 1939 again
26:57 Since I was facing south, I reoriented the map
28:54 still around 1950ft, but now im in a strong thermal
32:38 peak altitude of 2782ft
41:42 motor back on again at 1222 ft
43:23 motor off again at 2211ft
44:49 max distance of 6042ft from home
45:00 I have to pee!
47:38 Decide to land and engage autopilot home
51:24 reasonably good landing!
4 minutes of motor run time and 50 minutes of flying! Not too shabby! and I only used half my flight battery...
who says you cant find thermals with just a gps?
downeym is offline Find More Posts by downeym
Old Jul 18, 2009, 10:40 PM
Carlyle Harper is offline
Find More Posts by Carlyle Harper
Carlyle Harper's Avatar
Joined Feb 2007
The voice alerts are just too funny to me. Someday I must get the mic hooked up through my osd pro.
Carlyle Harper is offline Find More Posts by Carlyle Harper
Old Jul 19, 2009, 12:03 AM
lilphil26 is offline
Find More Posts by lilphil26
Toronto Canada
Well I guess I can qualify for the upgrade then I got my rma number back in MARCH
Thanks Bill, mine will be in the mail on monday.
I can't wait to get mine up and running, especially after watching some of the recent vids like downey's last post. Awesome video!!!!
lilphil26 is offline Find More Posts by lilphil26
Old Jul 19, 2009, 12:16 AM
Tom in Cincy is offline
Find More Posts by Tom in Cincy
Tom Para
Tom in Cincy's Avatar
Cincinnati, Ohio, United States
Joined May 2003
Nice job Mike. Thanks for sharing.
Tom in Cincy is offline Find More Posts by Tom in Cincy
Old Jul 19, 2009, 01:49 AM
Kiof is offline
Find More Posts by Kiof
Kiof's Avatar
Tarifa, Spain
Joined Nov 2007
kiof/emagnee, I have just re-enabled the white level/black level menu settings. This may help with your text issue. I assume the problem is a combination of the SN555 & your TX, but hopefully decreasing the text white level will help. Pls let me know what you find!
Regards,
Bill Thank you.
As I said i use the SN555 with Tx lawmate 500 mw.
When I conect the camera wired to the recorder it looks much more better...
Now I put the white level to number 1 and black level to 0 and the resut is much better, thank you again.
I have a questions
1- I use metric units, please can some one tell me waht is the meaning of the 3 number os climrate?? If meter/second why show 3 numbers??
2- what is the difference in to climb rate and variometer rate (I use the altimeter)
3- Is possible to conetc a buzzer to the audio ouput (just for the vario)
Thank you
Regards
Kiof is offline Find More Posts by Kiof
Old Jul 19, 2009, 02:21 PM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Bill,
Thanks so much for the ability to configure the osd parameters in the software! Much easier!
I am waiting for one last feature to be implemented. Any idea when the configurable layout of the software will be available? Being able to reposition the gauges etc, and being able to utilize all of the available space and resize the window will be of great help when using the smaller screen notebooks.
Thanks!
techspy is offline Find More Posts by techspy
Old Jul 20, 2009, 12:42 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Yeah, thanks Bill, great work again!!
Is the ability to have ladders/radar on and off per page still in the pipeline?
Thanks again!
Dion
rcimports is offline Find More Posts by rcimports
Old Jul 20, 2009, 01:38 AM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
Is it possible to have the option to display airspeed and vario in Knots and altitude in feet irrespective of the units used for logging(metric or imperial).
Stuart
fredo21 is offline Find More Posts by fredo21
Old Jul 21, 2009, 11:44 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
BlueAngel2000, I *think* the issue you are hitting is now fixed, in 7.76 on our beta site. Let me know if 7.76 fixes it. If not, I'll need to collect some more data from you, as it is specific to how Vista is installed on your PC.
motiganot, great flight! It's fantastic to see RTH working well on windy days, without FMA stabilization.
rob mueller, there is one more thing to try - can you short the ground and signal pins of the OSD Pro mic input together, using a jumper? Let me know if that reduces the noise when voice is active.
downeym, great flight also! So much for not being able to find thermals with GPS!
Kiof, glad to hear that changing the white level improved your video. Regarding climbrate, the the Climbrate and the "Var" (Variometer) parameter are displayed in meters/minute. Additionally, the Var parameter shows the results of total energy compensation, which is based on changes in speed. This feature helps to eliminate "stick thermals." Connecting a buzzer or small speaker to the audio output might just work!
techspy, the gauge resize/move feature is well underway. Hope to have that ready soon. I don't have a precise date unfortunately.
Dion, the programmable ladders feature is on the list, but not yet started.
Stuart, the knots/feet feature is also on the list.
Regards,
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jul 21, 2009, 01:14 PM
South Africa
Joined Oct 2005
Thanks Billpa!!
Hoping to add my "RTH Working" video very soon...Work getting in they way :-)
Cheers
Dion
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
