Old Feb 25, 2013, 09:16 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by CambriaHobby View Post
Even if I remove the mic I get the hum
That is strange.
I am wondering, Are you using a UHF LRS? (Like Dragonlink, chainlink, rangelink, Ezuhf, etc).
If so, Make sure that your Transmitter is placed 10 - 20 feet away from your equipment for testing purposes, and see if the noise goes away.
That noise that you are getting sounds like it is from an external source.
You can try that first, and then we will look at other options if it is not a 433 Mhz, UHF LRS that is causing the noise.
m_beeson is offline Find More Posts by m_beeson
Old Feb 25, 2013, 09:26 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
If the UHF is not the issue, then the next three things that I would look at, are:
Servo Noise:
Unplug your servos and see if the noise goes away.
If you are using digital servos, then it is conceivable that you are getting feedback.
Ground station recorder:
If you unplug your groundstation recorder, does the noise go away.
It is conceivable that you are getting feedback at the groundstation from the recorder its' self.
Transformers:
Are you powering any of your equipment by using a transformer?
If so, then eliminate any transformers from the system for testing purposes.
That gives you 4 things to look at immediately, to try to isolate the noise.
If it is not either of those, then we can look at some other options.
-Mike
Old Feb 25, 2013, 09:29 PM
United States, CA, Huntington Beach
Joined Dec 2012
Thanks Mike
I'll check it out
Mark
CambriaHobby is offline Find More Posts by CambriaHobby
Old Feb 25, 2013, 09:38 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Thanks Mike
I'll check it out
Mark
Good luck, let me know how it goes.
It is definitely an external source, even if it is coming over your video signal, like a internet router, cell phone, or something like that.
If you are using a 2.4Ghz transmitter, and a 2.4Ghz video, then that could possibly cause something like that.
I am just throwing things out there to be aware of because I don't know your system.
If you have listed your system, then I have missed it. I have been out of town for a few days, and it's hard to follow the forum on the smart phone.
Old Feb 25, 2013, 10:05 PM
Joined Dec 2012
Thanks again Mike
And yes. Lawmate 2.4 video with Dragon link.
I'll get it out of the house and see if it clears up.
Mark
Old Feb 25, 2013, 10:12 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Thanks again Mike
Mark
Dragonlink is 433 Mhz, so it is not likely directly interfering with the video, but it may be radiating a lot of noise that is interfering with your system.
Old Feb 26, 2013, 03:37 AM
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi Mark,
i guess, that your wiring is made like in the manual ... a y-cable to support the voltage supply to the audio in/out of the osd.
i found out that there is a groundloop (gnd connection inside the osd) causing a noise on audio ... a report to et support is in action.
pls try to bring only the signal to/from the osd and bypass the power supply.
cu Thomas
Thint1 is online now Find More Posts by Thint1
Old Feb 26, 2013, 08:08 AM
Dead_Stick_7060
zapi2's Avatar
Espaņa, Comunidad Valenciana, Alicante
Joined Jun 2003
Hi,
Here is my new setup, a single board with all the electronic.
http://www.rcgroups.com/forums/showp...ostcount=16863
Regards
Eric
zapi2 is offline Find More Posts by zapi2
Old Feb 26, 2013, 08:19 AM
Eat. Sleep. Fly.....(repeat)
Qwin's Avatar
United States, GA, Kennesaw
Joined May 2011
Just listened to your video....the noise appears to be present even when you are NOT transmitting (flight battery unplugged) so I suggest looking at the RECV end of the setup.... especially look closely at ground connections since the sound is similar to a floating ground on an AV line....not exactly, but similar.
If you hook up a jumper clip to a known good ground (like power-supply/battery ground) then touch it to other grounds in the system (case, shields, av returns, etc) I suspect you will hear when the noise goes away....
Qwin is offline Find More Posts by Qwin
Old Feb 26, 2013, 12:27 PM
Keep Calm, and Carry On...
United States, UT
Joined Feb 2012
Originally Posted by ron-sand View Post
Are you thinking of the wiring scheme or the OSD configuration file?
Would you be willing to do both?
I was hoping you would document how to use the MFD with the EagleTree Pro?
seearestacey is offline Find More Posts by seearestacey
Old Feb 26, 2013, 02:17 PM
ron-sand's Avatar
Joined Sep 2002
Time permitted I will draw up a wiring cheme. There is nothing fancy to it but I have avoided ground loops where possible and practical. The camera/vtx wiring is shielded.
I can post the et-setup file, but it is not to far of from default as of now.
And you know that the problem I had with the Sunsky vrx might be a freak one....
ron-sand is offline Find More Posts by ron-sand
Old Feb 26, 2013, 02:42 PM
junioro16v's Avatar
Brazil, PR, Curitiba
Joined Mar 2009
Hey guys
getting hum on my audio and can not hear the mic.
I have an ET and it is connected to a Lawmate 500mw tx. I installed the 10k resistor on the audio out and tried a 2.2uk cap on the video out from video to ground but when I connect the cap I lose my video.
Any suggestions?
Thanks.
Hello Sir,
Here is my video before
ET AUDIO NOISE 2 (2 min 27 sec)
And now.
https://www.youtube.com/watch?v=8CxBm4ot-q4
Here is my thread about this issue and the solution -> http://fpvlab.com/forums/showthread....ee-Audio-Noise
Just a question. 2.2uk cap? Can u send a photo of this capacitor? I donīt know what you mean by 2.2uk (uk? what is this).
If this is a 2.2uF capacitor, then your video will be out when connected. You need a 2.2nF or 2200pF (222 in the body) ort anything like this.
Maybe Iīm too older. I just know nF, uF, pF and this terminations (Farads).
junioro16v is offline Find More Posts by junioro16v
Old Feb 26, 2013, 03:51 PM
United States, UT
Joined Feb 2012
Thanks Ron, I really appreciate it!
yes, I'm using a Racewood, hopefully no problems then....
Old Feb 26, 2013, 07:45 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Did you ever figure out which piece of equipment the noise is derived from?
-Mike
Originally Posted by junioro16v View Post
Hello Sir,
https://www.youtube.com/watch?v=RiwfWRYaqz8
And now.
Old Feb 26, 2013, 09:13 PM
Joined Dec 2012
Thanks for the help guys.
So still working on the issue.
Here is what I've done so far.
on this video I removed the resistor from the audio out lead.
I installed the 2200pf cap
Here is the video
Resistor out cap in between gnd and video out (5 min 59 sec)
notice the ripple from the audio on the video with the resistor removed
at the end of the video I removed the video out feed from the osd
Is there a correct way that the cap installs?
Mark
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
