Old Jan 05, 2013, 06:20 PM
hornant is offline
Find More Posts by hornant
Back in Hong Kong
Joined Sep 2003
here is my silly question...
I think I have updated my firmware to the latest.
it shows Recorder 5.92/seagull 4.83/ OSD 2.51 /EE 1.18 / Guardian 1.19.
does that sound correct... I thought it would display version 10.04
hornant is offline Find More Posts by hornant
Old Jan 05, 2013, 10:27 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I think when you fire it up, the boot screen will show the overall version, but each component has it's own version.
m_beeson is offline Find More Posts by m_beeson
Old Jan 06, 2013, 11:49 AM
Jstjern is offline
Find More Posts by Jstjern
Suomi, Espoo
Joined Sep 2011
RTH banking hard - 80 deg
Hi,
During maiden of Skywalker 1900 with osdpro, guardian and elogger v3, I did not use stabilization. I also tested RTH using Carlyle method. Is stabilization (guardian) used for RTH when stabilization is off during normal flight, or not?
If no, then I understand why I noticed 80-90 deg banking during RTH tests with all gain and PID settings at default (except rth pitch and roll both set to max 35 instead of default 25). If yes, I guess I should decrease roll gain?
Without stabilization, plane flew beautifully, needing only two clicks of left trim.
SkyWalker1900 maiden Jan 5, 2013 (6 min 1 sec)
Two rth tests in video. Any ideas?
Jstjern is offline Find More Posts by Jstjern
Old Jan 06, 2013, 07:36 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
If you set the gains in the menu for normal flight, then you dial them down on aux 2, then it will default to the menu gains for rth.
Originally Posted by Jstjern View Post
Hi,
http://m.youtube.com/watch?v=-O2LzW2o-gw
Old Jan 06, 2013, 11:21 PM
Jstjern is offline
Suomi, Espoo
Joined Sep 2011
Thanks. I had turned stabilization/elevon mix to "off". I re-read the manual and found only implicit info that rth stabilization is also off in my case. As aux2 is also my camera tilt, I will try flying with stabilization only during center stick, size 1 and see how it goes.
Old Jan 07, 2013, 12:05 AM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Whatever you do, you need a way to turn stabilisation off as required, though a spearate gain channel or centre stick stabilisation are your only options with the Guardian system it seems.
This weekend I made the mistake of setting mine up per the manual with stabilisation values of; roll:5, pitch:5, overall:5 (reduced from 8). It was definitely over damped, but the real problem arose when I got too slow and it stalled. I fought the spin all the way to the ground with model destoryed. There was nothing I could have done to stop the spin once it had started.
I should have known not to set up a flight control system without a way of switching it off.
I really wish I'd had the option of having stabilisation on only for RTH. There doesn't seem to be a way to do that without assigning an extra channel (which I don't have)
subsonic is offline Find More Posts by subsonic
Old Jan 07, 2013, 12:27 AM
kaz1104 is online now
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
So the stabilization would have been feeding in opposite aileron to the spin that would not have had a negative effect, but it would also have been trying to feed in elevator to correct the loss of altitude ?? .... bad !! Was there an additional issue of rearward CG ?
Even with stabilize set up for effect only around neutral the effect would have been diabolical once the plane dropped into a spin. The only way out would have been to nail the throttle and manually push in down elevator.
Most airframes will not lock into a spin unless marginal stability or rearward CG.
kaz1104 is online now Find More Posts by kaz1104
Old Jan 07, 2013, 03:36 AM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Hi Kaz.
My cub had three flights on it, only the last one with the guardian active. The first one was used to set the trims and just get a feel for it (guardian off). I did a few spins and had normal recovery just by centering the sticks. I moved the CG back for the second flight, and found that it still had positive pitch stability. A spin was still easily recovered after about one turn just by centering the stick.
The third and last was the first with Guardian turned on. On takeoff, I found the plane very sluggish and felt that a stick input would result in an angle change, not a rate change like I was used to. I didn't like it, but decided to just do a short flight and test RTH once within LOS. As I was climning to a safe altitude, I let the speed drop too much. As I initiated a left turn while flying too slow, it stalled and settled into a spin.
The first thing I tried was to neutralise the controls. I was instantly aware that that did not produce the normal response, and I then wished for a way to turn off the guardian. Knowing that I couldn't turn it off, I tried foward stick pressure. This didn't work either, so with about 100' to go I nailed the throttle to try and wake it up that way. Obviously this made things worse in terms of damage, but it was a last resort. It crashed with full power on. (about 600W)
I'm annoyed with the fact that there is no way to have the guardian only active during RTH without dedicating another channel to it. (I only have 8, so no spares). I'm also equally annoyed with myself for setting up an aircraft this way without really thinking it through, though if you read the guardian manual, it pretty much advocates the setup I used.
Anyway, new cub is already on the way, and the second build will no doubt be much quicker than the first.
Sub
Old Jan 07, 2013, 04:42 AM
Dreamer
Joined Aug 2004
Hi Kaz.
Sub
Hey Sub,
That's all pretty concerning. The flight stabilizers of many years ago used to fight the pilot to the point that it was a huge handicap, rather than a help. Flew a guys "trainer" where he insisted the stabilizing was a great thing and was "essential". Went very close to causing a crash. The new generation units should not act in this way. I have yet to test my fpv plane with the guardian setup. Its there purely for rth in the even of a failure of video or a r/c failsafe. You have me even more worried now ...
Old Jan 07, 2013, 05:07 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
If you want stabilization only to run in RTH, then you could do the following.
1) turn on stabilization and mixing.
2) set sticks for 3pos (rth) (for calibration period)
3)set gains on guardian so it flies comfortably and does not display any odd tendencies.
4)calibrate / test / calibrate RTH
When all is tested and functions well
set switching method to 2pos and 3pos
designate the 2pos to a dial, and dial the gains down (leave everything else as it is).
Now you can use the dial to turn gains up, or turn gains off.
Set your failsafes on your radio, and I would suggest setting the failsafe to the dial as you would normally fly in stabilized flight.
(if your radio supports failsafe on that channel)
also:
*when making substantial changes to your plane it is a good practice to run servo analysis wizzard, and train it to the new changes.
This is the process that I would take to fly that bird unstabilized, but rely on stabilized RTH.
-Mike
Old Jan 07, 2013, 06:59 AM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Here is how I setup a 3-position switch and the Guardian on a variable switch..
I hope this helps..
Go here...
http://www.rcgroups.com/forums/showp...postcount=9940
Mykro is offline Find More Posts by Mykro
Old Jan 07, 2013, 11:39 AM
Jstjern is offline
Suomi, Espoo
Joined Sep 2011
Good summary, Mike, but there's one 'but'.
With a new airframe or after changing servo types (and speed of those) I want to take off without stabilization. I've crashed on take-off twice launching with stabilization after modifications to the plane. I don't want to risk take-off for a maiden or after a mod with stabilization. I want to engage stabilization at altitude duing first flight and possibly de-engage quickly indeed! (That cub crash sucks, sympathies!)
Billpa, if you're listening, pls separate stabilization on/off setting in menus for normal flight and rth (disabled if wing type set to elevon, of course).
Again, thanks or clarifying the current two options. After thinking about it, I'll likely disconnect camera tilt and use aux2 for gain during test flights only, instead of using center stick.
Old Jan 07, 2013, 12:43 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
good point.
I in fact did that on my last plane for maiden
I set level on the bench, then
I initially put it on 2pos + 3pos, and I dialed down the gains.
then I dialed up the gains after take off.
after that I moved it over to 2pos (rth), and began my calibrations.
-Mike
Old Jan 08, 2013, 10:33 AM
jjsueldo is offline
Find More Posts by jjsueldo
Joined Oct 2008
OSD Pro Software Update Request… 65 Km distance limit!
unfortunately and after waiting several weeks for a simple correction resolved for this osd....
http://www.rcgroups.com/forums/showt...+distanc+limit
we decided to change the navigation system to RVOSD.....
in a few days we expect to exceed our team record
jjsueldo is offline Find More Posts by jjsueldo
Old Jan 08, 2013, 11:41 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I love your setup.
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
