Old Dec 16, 2012, 02:35 PM
goryc is offline
Find More Posts by goryc
Italy, Sicilia, Messina
Joined Apr 2011
Originally Posted by ashdec87 View Post
You're getting all the turbulence from the camera and nose of the plane. Ideally you want is in front of the nose, or at least an inch out from the side near the nose.
Thank you!
Even I thought the nose was better but I'm afraid that might break in heavy landings! Let's see if I can find a solution that will secure the tube!
Thank you again.
Gory
goryc is offline Find More Posts by goryc
Old Dec 16, 2012, 02:44 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
goryc,
the you will surely bend the sh*% out of it at the nose.
I have been looking at this for some time, and the best solution is to
get a extension pigtail from ET, and embed the sensor in the wing, with the pitot tube just in front of it.
I would go aprox 9"-12" out from the center.
That way you have short tubes
a protected Pitot tube
and clean air.
the drawback is that you have to unplug the pigtail when you remove the wings.
Not really a big deal.
Originally Posted by goryc View Post
Thank you!
Thank you again.
Gory
m_beeson is offline Find More Posts by m_beeson
Old Dec 16, 2012, 03:18 PM
goryc is offline
Joined Apr 2011
Originally Posted by m_beeson View Post
goryc,
and clean air.
Plug the Pitot tube on the wing can be done but it seemed complicated, not so much for the link, and for the balance to be settled between the wing and the other. The extension cable is easy to do, you might have some difficulty with connecting tubes of silicone. Let's see, that's another good idea!
Thank you.
Gory
Old Dec 16, 2012, 03:22 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I have mine on the side of the fus near the nose. I built a little stand off so there's space from the fus and the tube. That works well and its protected.
ashdec87 is offline Find More Posts by ashdec87
Old Dec 16, 2012, 03:40 PM
goryc is offline
Joined Apr 2011
goryc,
and clean air.
Thank you so much but it is not that you have any pictures of your installations to simplify my installation?
Thank you in advance.
Gory
Old Dec 16, 2012, 03:55 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Gory
Hi Gory,
have a llo ka this post - there i described how to mont the pitot-tube flexible.
http://www.rcgroups.com/forums/showp...&postcount=130
cu Thomas
Thint1 is offline Find More Posts by Thint1
Old Dec 16, 2012, 06:45 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I like that.
Originally Posted by Thint1 View Post
Hi Gory,
cu Thomas
Old Dec 16, 2012, 11:36 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Gory
Gory,
Here's how I did mine. It works well and easy to hook up.
Steve
Floater73 is offline Find More Posts by Floater73
Old Dec 17, 2012, 12:37 AM
goryc is offline
Joined Apr 2011
Hi Gory,
cu Thomas
Very interesting this solution! But I have some questions:
1. Even using the Dremel does not ruin the edges of the tube, especially the inner?
2. with the soft tube connecting stretches the Pitot tube, this length variation does not affect the accuracy of the reading of the speed?
Thank you.
Gory
Old Dec 17, 2012, 12:38 AM
goryc is offline
Joined Apr 2011
Originally Posted by Floater73 View Post
Gory,
Steve
Thank you, good solution
Gory
Old Dec 17, 2012, 03:50 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Thank you.
Gory
Hi,
yes, after "dremeling" the edges are sharp ... very bad for silicone tubes you have to smoothen the edges after cutting. for the innerdiameter a dill is o.k. for the outer diameter i´ve done this with a sanding paper.
the lenght of the tubing doesn´t affect the accuracy ... the sensor measures the pressure, not the flow.
the accuracy is the highest if the dynamic pressure in the "right way". that means in front of the plane in an area where no turbulances are and parallel to the airflow. thats the reason why my tube is aligned a liitle downwards to compensate the angle of attack.
cu Thomas
Old Dec 17, 2012, 02:49 PM
mikenc is offline
Find More Posts by mikenc
Joined Jan 2012
Well i am about half way afraid to post what my problem was or maybe i should say what i think my problem was. I haven't had a change to check under flight conditions yet.
Seems as my vtx antenna was keeping gps from locking in. I had changed from IB Crazy V antenna to this one http://www.dpcav.com/xcart/1.2GHz-1....-V-Dipole.html and had mounted it up higher than i had had it mounted before, in order to get it more above motor.
changed it back to ibcrazy v and gps has worked fine since. Haven't been able to fly yet due to bad weather, but ground checks have all worked out fine. Checked it at least six times and it has worked fine.
That dpcav antenna had worked fine before, but it was mounted lower. Anyone alse experenced similar problem.
Best
Michael
mikenc is offline Find More Posts by mikenc
Old Dec 17, 2012, 02:54 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Interresting.
Hopefully you have it worked out.
Best
Michael
Old Dec 17, 2012, 03:29 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Best
Michael
I don't think that is too unusual. I make a practice of plugging in the flight battery, and waiting for a GPS lock (GPS light to stop flashing) before plugging in my power for the video transmitter.
Mark
kaz1104 is offline Find More Posts by kaz1104
Old Dec 17, 2012, 03:48 PM
mikenc is offline
Joined Jan 2012
Mark
High Mark,
I actually did that to several times. As soon as i plugged in video transmitter i would start loosing gps signal. For some reason there is some bad interference with that antenna.
Best
Michael
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
