Old Dec 04, 2012, 05:15 PM
cavu flyer is offline
Find More Posts by cavu flyer
USA, UT, North Ogden
Joined Dec 2010
Couple of wild flights with ET equipment
Hope this experience is helpful to others. I did a couple of maiden flights on a skywalker with the latest ET OSD Pro, Elogger, GPS, Baro Altimeter, and Airspeed expander and Castle Creations 75A Ice ESC. I powered my dragonlink receiver thru a separate BEC that provided 5V. On the first flight I called for RTH and the airplane made a turn for home, circled around and then headed away from home. I switched RTH off and turned the plane towards me and it rolled over into a spiral - maybe a stall spin. I recovered briefly and then it rolled over again. I had no control. It crashed from about 250 feet. With relatively minor fixing, the plane was ready to go again.
On the second maiden, I found it difficult to get the airplane to turn on my stick commands. I experienced this on the first maiden as well. So I brought the skywalker back. On final approach to landing with 15 feet altitude, I controlled to turn left to line up and the airplane wouldnt respond. I went full left aileron and the airplane rolled to the right and spiraled in - to a crash landing.
I read in these threads that connecting the throttle connection from ESC to OSD with ground, power and signal wires was not a good idea. In my case, power was getting to the OSD from the fragonlink receiver and from the Castle Creations ESC. I read that noise goes from the ESC to the OSD thru ground and power signals. So I disconnected ground and power and flew with signal only from ESC to OSD Pro. Solved the problems I experienced in the maiden flights.
cavu flyer is offline Find More Posts by cavu flyer
Old Dec 04, 2012, 08:08 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Did you fly yesterday?
m_beeson is offline Find More Posts by m_beeson
Old Dec 04, 2012, 08:30 PM
jimbo24 is offline
Find More Posts by jimbo24
ann arbor, mi
Joined Nov 2009
mykro,
if during the servo wizard you put the throttle stick all the way "down" when it asks for level flight, then during the RTH, wont it think that level flight is throttle stick down and the plane won't have any throttle to go home with.?
jimbo24 is offline Find More Posts by jimbo24
Old Dec 04, 2012, 08:55 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
jimbo,
when it asks for level flight, it is also taking note of the throttle position during level flight.
when it asks for climb, you set it to the position that you would normally set it to, in a reasonable climb.
when it asks for off, you set it to off...
Originally Posted by jimbo24 View Post
mykro,
Kd4Kw is offline
Find More Posts by Kd4Kw
KD4KW
Kd4Kw's Avatar
United States, FL, Tallahassee
Joined Jul 2009
Hi, First; no I have not read the entire thread. Sorry just to old and tired. So I most likely have missed the answer to my question. Please bear with me. I would like to display the ladder graphics on my osd. However. I don't have the pull down menu to select the graphics. I have the pull down to select the sensors to display and the right and left arrows to select pages is right under that.
I just upgraded to latest firmware tonite for osd and the V3 data collector. If I have over looked something or anyone knows how to turn on the select graphics menu please help an old man.......
Kd4Kw is offline Find More Posts by Kd4Kw
Old Dec 04, 2012, 08:59 PM
jimbo24 is offline
ann arbor, mi
Joined Nov 2009
m_beeson
thx for the reply. that's what i set it to, but on the simulator now i have the servo deflections showing and when i trigger RTH, the throttle doesn't move onthe sim, just the other control surfaces.?
Old Dec 05, 2012, 12:04 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Are you using SPPM?
If so, then you should use this version
http://www.eagletreesystems.com/late...lpha/setup.exe
Just another thought on setup
Set your radio failsafes to Level flight, and throttle off and trimmed all of the way down.
Then you can trim it back up to the normal position that you fly with, and run servo analysis wizzard.
Also,
Your ESC should be set to fixed throttle endpoints, not autolearn.
m_beeson
Old Dec 05, 2012, 01:10 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Anyone heard anything about an Eagle Tree magnetometer for heading info?
eroeder is offline Find More Posts by eroeder
Old Dec 05, 2012, 12:09 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
see this post ...http://http://www.rcgroups.com/forum...postcount=9703
cu Thomas
Thint1 is offline Find More Posts by Thint1
Old Dec 05, 2012, 12:24 PM
jjsueldo is offline
Find More Posts by jjsueldo
Joined Oct 2008
Any news about the distance limitation
Thanks ˇˇˇ
Jojó
jjsueldo is offline Find More Posts by jjsueldo
Old Dec 05, 2012, 03:09 PM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
The altitude limit is a bummer too for us near-space balloon guys....
Old Dec 05, 2012, 05:00 PM
yak13 is offline
Find More Posts by yak13
United States, AZ, New River
Joined Apr 2007
Altitude hold, Holding pattern?
To all you experts:
Is there any way to fly in manual stabilized mode AND have the ET OSD hold a fixed altitude?
How about initiating a holding pattern when in flight?
Thanks a lot
Ed
yak13 is offline Find More Posts by yak13
Old Dec 05, 2012, 09:10 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
It looks like I have a flying airframe again
EVO-55" Maiden Flight (7 min 8 sec)
Old Dec 05, 2012, 11:16 PM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
Congrats on a successful maiden! that was interesting but effective launch! do you have a name for that technique?
kokopropelli is offline Find More Posts by kokopropelli
Old Dec 05, 2012, 11:22 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Ya, it's called
HOTYA "here we go"...
Thanks man.
It flew like it was on rails, but my thrust angle was a bit off.
I'm installing the FPV gear right now.
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
