Old Dec 02, 2012, 10:32 PM
1111Mavrick is offline
Find More Posts by 1111Mavrick
1111Mavrick's Avatar
Canada, BC, Gibsons
Joined Apr 2011
Hey guys is there a way to display the OSD information without having a camera plugged in or powered up?
I'm using my gopro as an FPV camera on my quad copter(i know its not ideal but weight is a factor) and just in case the gopro battery goes dead i would like to still see all my display info.
1111Mavrick is offline Find More Posts by 1111Mavrick
Old Dec 02, 2012, 11:36 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
That is the main reason I don't use GoPro for main flight camera, other than the poor video feed on the GoPro 1.
If you loose video, then you loose display.
OSD is not a signal generator, the camera generates the signal, and the OSD merely overlays it's information on the pregenerated signal.
Have you seen this?
http://www.rcgroups.com/forums/showthread.php?t=1763092
Official release notes are not out yet, but keep an eye on it. You'll be impressed.
m_beeson is offline Find More Posts by m_beeson
Old Dec 03, 2012, 12:41 AM
Canada, BC, Gibsons
Joined Apr 2011
Thanks m_beeson...... its what i suspected but hoping wasn't true
Thanks for the link..... so am i correct in the understanding that eagletree OSD pro support for quad copters is just a firmware upgrade away? ...... in the near future that is.
Old Dec 03, 2012, 01:00 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
No, it's a new product
Old Dec 03, 2012, 01:06 AM
jimbo24 is offline
Find More Posts by jimbo24
ann arbor, mi
Joined Nov 2009
question:
have a readymaderc easystar with ET OSDpro, guardian expander, eloggerv3, gps, 900mhz transmitter and Scherrer LRS on a futaba 10CHP with EE base-station.
I've been configuring the RTH function. When doing flight simulator, the EE tracks fine and flight sim works, but I can't get rth to engage when i go back into menu to select. I won't select. so then i put it on a 3 way switch such that "up" was RTH test, but it keeps on telling me to release sticks to engage RTH when i'm not moving any sticks? Any thoughts?
when i turn off the radio, it triggers RTH and it comes back in the simulator as expected. can't figure it out.
thanks.
jimbo24 is offline Find More Posts by jimbo24
Old Dec 03, 2012, 02:35 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Re-run Servo analysis wizzard
Originally Posted by jimbo24 View Post
question:
thanks.
Old Dec 03, 2012, 03:52 PM
jimbo24 is offline
ann arbor, mi
Joined Nov 2009
good thought. i'll give it a try.
how are people setting a switch for RTH AND having a switch to control gain for guardian expander? I have a futaba 10c with Scherrer LRS.
i'm thinking that i should use the carlyle method (with a switch for throttle mixed into itself) and then use the 3pos switch for moving through the menu and selecting (option B?) and then free up aux 2 and move it to a knob?
I'll be upset when i figure all this out and then my model winds up in a tree anyway
thanks for the input.
Old Dec 03, 2012, 04:18 PM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Go Here.. http://www.rcgroups.com/forums/showp...postcount=9500
This will explain how I did my 10cap with the Carlyle method on a switch
Mykro is offline Find More Posts by Mykro
Old Dec 03, 2012, 05:20 PM
jimbo24 is offline
ann arbor, mi
Joined Nov 2009
awesome. i'll give it a shot.
if you have a guardian expander, what do you do for separate gain if anything?
Old Dec 03, 2012, 05:59 PM
Mykro is offline
Joined Feb 2009
awesome. I'll give it a shot.
If you have a guardian expander, what do you do for separate gain if anything?
Read up in OSD manual page 12, You want Option "B"  3 Position switch.
You'll need to choose the 3 Position switch from the
"Choose Menu Receiver Inputs" from the "Radio Control Configuration Menu" when setting up your OSD. (See page 22 of the OSD manual)
Name: Go Main Menu_Choose AUX-CH.jpg
Description:
Go to the main menu in your 10C. Go into the AUX-CH
Name: 3 Pos Switch_Aux1_CH5_SwC.jpg
Description:
AUX1 is plugged into CH5 of Rx.. CH5 is on SwC.. SwC toggles through and selects the OSD menu items.
(SwC has the white shrink wrap on it)
Aux2 is plugged into CH6 of Rx. CH6 is on VrE. VrE adjusts Guardian gain
CH7 - Not Used
CH8 - Not Used
Name: Guardian on_ Aux2_CH6_Switch VrE.jpg
Description:
Pencil is pointing to the Variable switch "E" this adjusts the gain on my Guardian..
Notice the white shrink wrap on switch "C". This is the 3 Position switch which toggles the OSD menu..
If you are going to use extra channels for Pan and/or Tilt then the AUX channels may change.. You may end up using channels 7 & 8..
MY OSD camera is stationary.. I'm not using Pan or Tilt.. Therefore channels 5 & 6 is all that I need..
Old Dec 03, 2012, 09:42 PM
jimbo24 is offline
ann arbor, mi
Joined Nov 2009
mykro. thanks so much for the info. i tried your link above to the carlyle method using switch, but it didnt' work. did you make a thro-thro mix for that switch? or just register failsafe with the switch in one particular direction and throttle down. i'm thinking i need to program a mix.
thx.
Old Dec 03, 2012, 09:45 PM
Mykro is offline
Joined Feb 2009
thx.
Go to Page # 634, post # 9500
Old Dec 03, 2012, 10:06 PM
jimbo24 is offline
ann arbor, mi
Joined Nov 2009
ok. did the thro-thro mix and ur info above and it works on the sim. i guess we'll see if it works in real life. Thanks for taking the time to help. really appreciate it.
Old Dec 03, 2012, 10:09 PM
jimbo24 is offline
ann arbor, mi
Joined Nov 2009
i used offset OFST-->THRO. instead of dialing the rates. no big deal rigth?
Old Dec 03, 2012, 10:27 PM
Mykro is offline
Joined Feb 2009
If it works.. go for it..
My current setup works flawlessly so far.. I've been really happy with it's performance..
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
