Old Nov 03, 2012, 06:39 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Does anyone else have an issue with the guardian (V1) drifting after a tight turn? Mine has been doing this for a while and its kind of annoying. It always comes back to center, but after the turn it goes way off for about 20 seconds.
ashdec87 is offline Find More Posts by ashdec87
Old Nov 03, 2012, 08:45 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Is your artificial horizon drifting also?
I would suspect one of three things.
1) guardian not mounted well and is moving (not likely)
2) guardian roll gains / or responsiveness too low
3) play in your aileron push rod connections, doesn't allow it to precisely make the necessary adjustments (most likely)
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Nov 03, 2012, 09:25 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
AHI drifts also, so the aileron isnt the issue. Its mounted solidly. When I engage RTH, the turn is slow enough to not elicit this. Its when I make a hard turn (60 degree+ bank), or pull G's in a turn. I posted a video a while back of it doing this, I'll try to dig it up. I also have new video from today that I'll try to get up at some point.
Old Nov 04, 2012, 09:36 AM
flymetothemoon is offline
Find More Posts by flymetothemoon
The Netherlands, UT, Amersfoort
Joined Aug 2004
Question for Billpa:
Perhaps I'm only the loonly for this, but it's my wish......
I fly with an 8 ch. system with cppm option. I like this cppm (or sum ppm) very much! Away with a lot of wires!
But it's all or nothing, I can't have the first 6ch as cppm and the last 2ch "normal".
So for my new project I want to put the cppm rx in the tail of the plane.
(Short coax to the inverted V antenna in the vertical stab)
From there only one servo wire to the OSD PRO.
Osd and Guardian will need 6 ch.
And than I like to have 2ch coming from the osd to the camera pan/tilt servo's
So would it be possible to change FW to use for example aux1 in and aux2 in for pan and tilt out?
Rienk
flymetothemoon is offline Find More Posts by flymetothemoon
Old Nov 04, 2012, 11:35 AM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Fried throttle cable...
Went to fly this morning.. Threw the plane up, gave it considerable throttle and then the motors died.. The plane landed and I noticed the ESCs were beeping every two seconds. I opened up the fuselage and immediately noticed the negative wire on the cable going from "out" on OSD to the throttle harness was completely fried.. I immediately replaced it with a spare in the field, went to power up the plane, gave it throttle, and the same wire fried again.. I'm stumped..
Anyone have a possible solution??
Michael
Mykro is offline Find More Posts by Mykro
Old Nov 04, 2012, 12:49 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
it's always something
do you have another esc to test it with?
Michael
Old Nov 04, 2012, 01:16 PM
Mykro is offline
Joined Feb 2009
My twinstar has dual ESCs, on a Y harness.. Im not sure what to test first..or where to begin..
I'm stumped as to why this all of a sudden just happened ..
Old Nov 04, 2012, 03:56 PM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
I had the same problem with throttle ground wires being bunt. The reason was a ground loop through the ESC. The solution is to connect only the signal wire between the ESC and the OSD throttle out port. The ECS has its ground already connected with the rest of the system through the ground wire of the connection of the ESC and the E-logger. Therefore, the high current that goes through the motor can find its way back to the battery through the thin servo wire that connects the ESC to the OSD. So, you have to remove the ground wire between the ESC and the OSD. My above experience has been with an external BEC (the red wire between the ESC and the rc rx was not connected), but I suspect that it is the same situation if you use the internal ESC BEC too. Also, in a similar fashion, the ground wires burnt after they had been working fine for several flights up to that point.
Best regards,
Stavros
sfakias is offline Find More Posts by sfakias
Old Nov 04, 2012, 09:00 PM
Mykro is offline
Joined Feb 2009
[QUOTE=sfakias;23182000]I had the same problem with throttle ground wires being bunt. The reason was a ground loop through the ESC. The solution is to connect only the signal wire between the ESC and the OSD throttle out port. The ECS has its ground already connected with the rest of the system through the ground wire of the connection of the ESC and the E-logger. Therefore, the high current that goes through the motor can find its way back to the battery through the thin servo wire that connects the ESC to the OSD. So, you have to remove the ground wire between the ESC and the OSD. My above experience has been with an external BEC (the red wire between the ESC and the rc rx was not connected), but I suspect that it is the same situation if you use the internal ESC BEC too. Also, in a similar fashion, the ground wires burnt after they had been working fine for several flights up to that point.
Best regards,
Stavros[/QUOTE
Thanks.. I'll give that a try...
Michael
Old Nov 06, 2012, 05:18 PM
gstierli is offline
Find More Posts by gstierli
GusCBA
gstierli's Avatar
Argentina, CB, Córdoba
Joined Mar 2010
OSD Pro Software Update Request… 65 Km distance limit reached!
http://www.rcgroups.com/forums/showt...2#post23200928
gstierli is offline Find More Posts by gstierli
Old Nov 06, 2012, 05:22 PM
BriGuy82 is offline
Find More Posts by BriGuy82
SemperFi!
BriGuy82's Avatar
United States, TX, Texarkana
Joined May 2012
Where is Bill?? I submitted a ticket to the website days ago and still no response..
BriGuy82 is offline Find More Posts by BriGuy82
Old Nov 06, 2012, 05:51 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Hi Brian,
I know that they are busy working on a new project, but that's no excuse.
try emailing Bill directly he is more proactive than it appears. I checked out his posts a while back, and I was surprised at the amount of threads that he was answering.
-Mike
Old Nov 06, 2012, 06:45 PM
jjsueldo is offline
Find More Posts by jjsueldo
Joined Oct 2008
Originally Posted by gstierli View Post
Limitation on Eagle Tree
We need to free the distance count to get a new record ¡¡¡¡¡
Who Can Help?
Jojó
www.fpv-cba.com.ar
jjsueldo is offline Find More Posts by jjsueldo
Old Nov 06, 2012, 10:10 PM
garris2 is offline
Find More Posts by garris2
Australia, VIC, Glen Waverley
Michael
I also agree with Stravros that this situation is cause by a ground loop problem.
Geoff
garris2 is offline Find More Posts by garris2
Old Nov 07, 2012, 12:57 PM
BriGuy82 is offline
SemperFi!
BriGuy82's Avatar
Joined May 2012
Hey Mike.. This is my second flight ever FPV, to include any flying with ET equipment. On my first video a week ago, everything seemed to be great as far as displays (minus no sound), but this time I recorded two flights. My first flight (on this day), all of my OSD parameters displayed correctly on my goggles. However the second flight, I lost my distance to home display on the top left corner, it was like it was deleted from the settings menu.. Weird!
At the same time, I flew a bit further out this flight. Much higher altitude as well... When I got worried and hit RTH, the plane was very sluggish to respond (at one point it flew right over my head and kept going) so I ended up taking over controls with RTH still engaged. (I know I know, bad boy).. I could see the plane wanting to turn, but it was nothing like it was on my initial tests a week ago, and the flight before this one..
What do you think is going on here? Distance info and RTH responsiveness..
FPV Flight with SkyWalker V2 (15 min 18 sec)
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
