Old Oct 27, 2012, 08:38 PM
rcflyer1000 is offline
Find More Posts by rcflyer1000
Joined Jun 2012
Hi guys would anyone be able to upload their RTH settings that they are using on a bixler? Can`t seem to get mine working.
rcflyer1000 is offline Find More Posts by rcflyer1000
Old Oct 27, 2012, 09:05 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
There's a thread dedicated to different settings for different planes here probably a few pages back.
Teamsherman is offline Find More Posts by Teamsherman
Old Oct 27, 2012, 09:31 PM
NutBag is offline
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
My Bix2 uses Factory RTH settings.
Tip... From my experience you need to have model flying "hands off" perfectly in Stabilization mode before the RTH will work correctly.
NutBag is offline Find More Posts by NutBag
Old Oct 27, 2012, 09:36 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
yeah, I would be interested in that too ... setting up a bixler at the moment.
kaz1104 is offline Find More Posts by kaz1104
Old Oct 27, 2012, 09:37 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Thanks NB .. will try default settings
Old Oct 27, 2012, 10:17 PM
NutBag is offline
NutBag's Avatar
Joined Oct 2005
No Probs. I pretty much have to set my "Cruise throttle sticks level" pretty much every day I fly.
Easy to do in the on screen menu while flying with only a few flicks of the Aux switch. Recommend you land and do on ground once trimmed until comfortable.
So.. I launch with no stabilization, get a little height, goggles on, trim out model at cruise power, go into on-screen menu and reset "cruise sticks level" Done.
Now when I turn up my stab gain (aux 2) with a dial my plane will fly perfectly hands off at cruise power... Add power it will climb... Decrease power it will come down. I also use heading lock and it works great, hands off for miles at a time if needed... almost cheating.
The higher the dial the more it locks in, I have 5 as a maximum.
If you have to change your trim you need to redo your level again.
Being "Foamies" these things twist and warp in your car and sun etc so you need to trim them. It's unavoidable
Chris.
BriGuy82 is offline
Find More Posts by BriGuy82
SemperFi!
BriGuy82's Avatar
United States, TX, Texarkana
Joined May 2012
Here she is guys, my first ever FPV flight.. I still cant figure out why i'm not getting any sound to my dvr. Also, after my "bumpy landing", now all I hear is a bad squeal..
My First FPV With A SkyWalker V2 (13 min 19 sec)
BriGuy82 is offline Find More Posts by BriGuy82
Old Oct 28, 2012, 12:04 AM
paul kelley is offline
Find More Posts by paul kelley
3d nut
paul kelley's Avatar
United States, CA, Stockton
Help me
Hi I am in need of some help. I just bought a Eagle Tree 2d/3d gyro. I hook it up to a ar6115 according to the instruction. Here are some question. What do I do with the Mod plug, is the flap switch automatic assign per program to change Mods, if not how do I set it up to my flap switch? I have a DX8. The way it set up now, the gyro is aways on, with no way to turn it off are change Mods. WHAT AM I DOING WRONG? Oh ya with the way I have it set up the Ale, and elevator dose work, the rudder move just a little. It seem to me that I need a 7 channel RX for the Mod plug.
paul kelley is offline Find More Posts by paul kelley
Old Oct 28, 2012, 12:15 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Cool, now you're addicted...
A couple of things Bri:
*If you get lost, just look at the chevron, it will tell you where your plane is. Just point it towards home.
*When you hit the RTH switch, if you move the sticks, then turn RTH off; the message may stay on.
in order to turn that off, you need to engage RTH, then disengage RTH without touching the sticks. Then it will turn off.
*Mic:
I was reading on another thread where you may have bipassed the osd with the mic input to the Vtx. If you did that, then you have ruled out the OSD, but if it is traveling through the OSD, then make sure that audio is not on mute. You can find that in the menu.
http://www.youtube.com/watch?v=s02USLp6Vvc
m_beeson is offline Find More Posts by m_beeson
Old Oct 28, 2012, 12:20 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Paul,
Wrong thread. You want the 2d/3d thread.
You can find it here.
http://www.rcgroups.com/forums/showt...light=guardian
Old Oct 28, 2012, 01:24 AM
BriGuy82 is offline
SemperFi!
BriGuy82's Avatar
Joined May 2012
Finally! Thanks Mike.. I've been reloading the page all night waiting for some feedback.. hehe jk.. But really, thanks.
So yes I have checked and double checked my camera connection to my OSD.. I've made sure the wire inside the JR style connector is making good contact. All looks well so far. On that other thread I uploaded a video which showed a "muffled" sound.. I went into ET settings and made sure my audio was turned up to 4, and checked the settings on my DVR. Again, all should have been normal. Why wasn't my speed icon showing a speed? Only the ladder to the left was showing my speed.
One thing I'm thinking is the camera settings. I don't have the control board for my cam, and ReadyMadeRC is out of stock so I have no way of editing my cam's settings. (not sure if it would or could make a difference for audio).
So if you hadn't noticed, I had a less then stellar landing. When I got home I did a quick record video sitting still. The play back revealed an awful squeal sound I am becoming more and more baffled on this issue. When I plug my headphones into my goggles, I can hear but I have to get right up on the camera and even then its really muffled.
Thanks Mike.. I appreciate all of your help this past couple of months. But hey! I finally got the guts to fly her! Very fun, and next flight will go further..
*Mic:
Old Oct 28, 2012, 10:15 AM
AutoPilotOn is offline
Find More Posts by AutoPilotOn
Joined Oct 2012
Hello all, I am setting up my OSD Pro w/ guardian and when I turn the system on everything seems to be working properly but my servos are making a noise like they are binding up and they seem very sluggish and jumpy, when I move the airframe around they respond properly to the guardian inputs. Any thoughts on why they are doing this, thanks
AutoPilotOn is offline Find More Posts by AutoPilotOn
Old Oct 28, 2012, 12:30 PM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
Try to lower your gain. Are they digital servos?
kstmark is offline Find More Posts by kstmark
Old Oct 28, 2012, 01:07 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I would say that they are digital servos. Those can be very noisy.
The jumpiness is somewhat normal. It has to do with stabilizer responsiveness.
Old Oct 28, 2012, 01:52 PM
austin.laws is offline
Find More Posts by austin.laws
Night flier
United Kingdom, England, Bromyard
Joined Mar 2008
Does the software work with windows 8?
austin.laws is offline Find More Posts by austin.laws
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
