Hotdog,
I have a ZII with the ET setup and it returns to home no problem. Your ZII looks like its on the edge of stalling on RTH. Is it fairly stable in a glide (motor off), because it needs to be when RTH is activated above the cruise altitude window ? Quote:
here is my settings " OnscreenSetupVersion="2 " PermitRTHLowAlt="0 " FirstFeatureOffset="15800 " NumberOfFeatures="71 " PageSwitchInterval="0 " DisplayMax="0 " NumSatsForInit="0 " Require3DFix="1 " MinHDOPx10="99 " IntervalAfterGPSFix="0 " Flags="2 " ProStringsOffset="9470 " ShortStringsOffset="8870 " MenuDataOffset="5494 " ElevonCenterMicroseconds="1500 " TotalMAHCapacity="8000 " ProFlags="2 " SerialType="0 " CheckValid="3 " ZeroCurrents="2043,0,0 " ADPCMOffset="19851 " WordInfoArrayOffset="5062 " ADPCMVersion="6 " VoiceIsMuted="0 " VoiceVolume="2 " ExternalIsMuted="1 " ExternalVolume="1 " VarioIsMuted="1 " VarioVolume="1 " ShowAirspeedLadder="1 " ShowAltitudeLadder="1 " ShowCompass="63 " ShowBatteryGraphA="63 " ShowRADAR="63 " XOffset="50 " YOffset="30 " XSize="0 " SamplesPerSecond="10 " SafetyWizRun="1 " LatLonDisplay="4 " RadarUpDegrees="0 " RADARRange="5000 " InterventionMode="2 " FailsafeType="1 " RXType="1 " FlightSim="0 " RTHTestMode="0 " RTHMaxSpeed="0 " UsePitotForRTHSpeed="0 " MaxRTHDeltaAlt="25 " RTHAltitudeGain="0 " UseBaroForRTHAlt="1 " RTHAltitude="150 " ThrottleFailsafe="2012 " RTHThrottleCruise="3025 " RTHThrottleClimb="3611 " RTHThrottleDescend="2559 " AileronFailsafe="3071 " RTHAileronCruise="3072 " RTHAileronLeft="2719 " RTHElevatorLeft="2864 " ElevatorFailsafe="2865 " RTHElevatorUp="3209 " RTHElevatorCruise="2864 " RTHTurnIntegralGain="50 " RTHTurnDerivativeGain="50 " RTHTurnProportionalLimit="40 " RTHTurnProportionalGain="60 " RTHPitchProportionalGain="75 " RTHPitchDerivativeGain="75 " WhiteLevel="7 " BlackLevel="4 " ShowWaypoints="0 " MainDisplayOn="1 " IsOldCopilot="0 " ShowDeflections="0 " ServoPulseWidth="44857 " JumpToExit="1 " ShowAHI="1 " Stabilize="1 " AHIWizRun="0 " AHILevelPitch="171 " AHIForwardPitch="65535 " AHIBackwardPitch="0 " AHILevelRoll="65508 " AHILeftRoll="0 " AHIRightRoll="0 " FDRPitchOffset="22 " FDRRollOffset="20 " DistanceAsLOS="0 " NarrowScreen="0 " OSDConfigSize="130215 " Lat="0,0,0 " Lon="0,0,0 " OnOffWithSelect="0 " ShowCrosshairs="63 " SendTelemetry="1 " AltitudeUnits="1 " SpeedUnits="1 " DistanceUnits="1 " UseTemp1ForRSSI="1 " ModelControlType="1 " RTHAileronUp="3047 " VarioOffAmps="0 " DisableInverse="0 " RSSIOn="3656 " RSSIOff="3656 " AverageTicks="5,10,30,5,5,5,0,5,5,0,0,0 " EEConfig="1,0,114,0,5,1,3,3,0,127 " UseTempForVolt="0,0 " VoltMinX10="100,100 " VoltMaxX10="111,111 " ShowBatteryGraph="0,0 " PanZeroFieldAngle="285 " PanCCWAngle="123 " PanCWAngle="219 " PresentPanCal="1 " PanAnglePWM="932,968,1002,891,858,837,1017,945,909 " TiltLowAngle="0 " TiltHighAngle="90 " TiltLowestPWM="849 " TiltHighestPWM="321 " ForcedPanAngle="0 " ForcedTiltAngle="0 " ForcePanTiltAngles="0 " PanTestPosition="0 " TiltTestPosition="0 " MinPanTiltRadius="239 " ShowFlightTimer="1 " ButtonMode="1 " PitchGainStab="5 " RollGainStab="5 " OverallGainStab="8 " PitchMaxNormalStab="50 " RollMaxNormalStab="50 " PitchMaxSafetyStab="40 " RollMaxSafetyStab="40 " ProportionalStab="0 " DerivativeStab="0 " StabResponsiveness="7 " RTHMinGPSSpeed="0 " HomeRTHAltMode="0 " RTHHomeAltitude="150 " HomeAltRadius="400 " TurnGainStab="5 " StabilizeCenterOnly="0 " CenterStickTolerance="7 " HeadingHold="0 "/> |
Joined Jan 2012
Thanks for taking the time to view clips, made them to long i know.
Just a couple of things that i have noticed?It seems to over shoot home position sometimes, (turn past home position) especially when rth is engauged when you are out quite a ways. Didn't know if that was norm? I have noticed at times plane will make turn toward home and will fly a circle say when it is still out 1400 ft or so and then continue on towards home. I don't think that part was shown in clips. At least it is coming home Thanks for your help. |
Thanks hopefully that does the trick |
hotdog,
I have to tell you that I am a bit perplexed with the behaviors that you are experiencing. I have looked at your config files and there are a couple of things that jump out at me. Let me take them one at a time, and break down what I suspect. * I would need to do some research to determine what I am looking at but I can tell you what I see just off hand. AHIWizRun="0 " AHILevelPitch="171 " AHIForwardPitch="65535 " AHIBackwardPitch="0 " AHILevelRoll="65508 " AHILeftRoll="0 " AHIRightRoll="0 This line of values makes me suspect that you ran the servo analysis wizzard through the PC, and when it was plugged in to the usb, the guardian was not recognized. *often you get a message that the guardian is not recognized, when you plug the osd into the pc usb. I would run servo analysis wizard through your transmitter RTHTurnIntegralGain="50 " RTHTurnDerivativeGain="50 seems very high for a wing " RTHTurnProportionalLimit="40 " RTHTurnProportionalGain="60 " RTHPitchProportionalGain="75 " RTHPitchDerivativeGain="75 seems high " RTHHomeAltitude="150 " HomeAltRadius="400 I usually set my RTH altitude quite high. I'll give you an example. 30 Mph is 44 feet per second So it would take you 3.4 seconds to hit the ground from 150 feet at 30mhp. 500 feet will give you 11.36 seconds to react at that same speed. Home radius is nothing more than a line that you draw in the sky. it distinguishes between RTH cruise altitude, and RTH home altitude. When your plane crosses that line, it seeks the respective altitude. I usually stretch that out to about 1000 feet. *Note: It's a little difficult for me to get the whole picture, but I have given you a couple of things to look at. I hope it helps. Let me give you this link. It will pay to get a solid understanding of the calibration settings. Why & When to change settings. http://www.rcgroups.com/forums/showthread.php?t=1717573 There is a lot of info on this page. |
Ok Thanks , I already changed my min ground speed I am going to test later today. if that dosnt work I will start changing thing one at a time and see what happens. Thanks alot guys I will let you know what happens |
Melbourne, Australia
They need to be set for straight and level flight, not some random position that could be causing your wing to want to turn. |
Damn just went to try and get the RTH working but this huricane is making it windy as hell guess I won't be flying anytime soon |
pavn,
No matter which choice you make, you will have to learn how to make the equipment work for you. Since I don't have a background in programming, then I am glad that I made the choice to go with Eagle Tree. The equipment is reliable, and the code is already written. You just have to figure out how to calibrate it to your plane. If you want some of the features that are offered in the Open Source boards, then more power to you, but I just want to fly, with a reliable failsafe... Everything else is just extra. *Since there are no two airframes alike, then there is no possible way that someone could make a "plug - n - play" OSD, so no matter which one you choose, you will have to learn it... I will not disway you from the decision that you have made, I have not followed any progress on the open source boards in at least 6 months, so my knowlege of the progression is limited. I know that there are a lot of intelligent people who are working on code for those boards, so you may have found a good option. I am very biased because I love my Eagle Tree equipment. I suppose I wish there were a few things different, but I know how much time and effort the Eagle Tree team spends on behind the scenes support, so I don't complain, I just use the features that I have, and enjoy my FPV. |
| Thread Tools | |
| For Sale BRAND New CP Pro/with extra battery | stgtech2 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 06, 2006 09:35 PM |
| New eolo pro glitches with cc60 | aschen | Electric Heli Talk | 24 | May 20, 2004 08:12 AM |
| FS New Piccolo Fun with bearing upgrade and HA tail motor | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2004 06:32 PM |
| For Sale: NEW Pic Pro rotor head with stiffening mod | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 02, 2003 09:16 PM |
