Pay attention to the place that you save it, and you can find it. It is a .txt file. Then you can start a post, and hit the paperclip selection above the reply window. that allows you to upload a file. You can hit preview, and see if it was successful. |
Very cool! Thank you! Ok so I'm following your install videos.. I went into the Safety Configuration Menu and started editing my rth altitudes. As soon as I set my altitudes my osd updated with this new information.
I no longer have control on my ailerons.. I have motor, elev and rudder controls though... Any reason for this after configuring RTH safety settings? |
Now to figure out why my servos arent responding. I tried plugging in a known good servo, still no response. Checked connections on the osd, everything is still nice and snug, same on the receiver. |
Make sure that the USB is unplugged. If that doesn't do it, then you have opened up a brain teaser... |
Steve |
Ah yes,
You have to physically enable Stabilization/mixing don't you??? It sure is acting wierd. It shouldn't spiral with guardian enabled... Quote:
My camera kind of sucks, but here is my last mountain flight that I took.
(waiting for a replacement camera to arrive) This was just a couple of days ago
Servos are still stuck after I edited settings on safety inputs for RTH settings via laptop interface (I noticed the USB plug came off the E-Logger but I'm not sure if it happened before or after OSD setup). Like I had mentioned to m_Beeson, my aileron and elev servos are no longer responding to stick inputs from my transmitter. I ran Analysis Wizard a couple different times, each time it completed I had temporary controls but eventually froze up.
Looking for input from a vendor or someone who has experienced this problem if possible. When I run the wizard via laptop or goggles it still does the same thing. However when I run it from the laptop I can still see the % changes when I move the sticks. So I know its getting the requests just not registering somehow. |
| Thread Tools | |
| For Sale BRAND New CP Pro/with extra battery | stgtech2 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 06, 2006 09:35 PM |
| New eolo pro glitches with cc60 | aschen | Electric Heli Talk | 24 | May 20, 2004 08:12 AM |
| FS New Piccolo Fun with bearing upgrade and HA tail motor | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2004 06:32 PM |
| For Sale: NEW Pic Pro rotor head with stiffening mod | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 02, 2003 09:16 PM |
