Old Aug 02, 2012, 09:46 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Kip,
I have not met, or spoken to anyone who has successfully made the dragon osd control throttle during RTH, have you?
Or do you just set it to use your transmitter stick setting...
Originally Posted by Kipkool View Post
I have booth, I would suggest dragon osd for now. It has all sensors embedded on the board with Baro, Compass, Vario, and Imu for true artificial horizon.
GPS has a better and quicker 3D fix than the eagle tree one ( sometime I have to wait more than 2 mn to have a fix outside with ET, it's less than 20 sec with Dragon ).
And at least, there's a compass, so you have a true heading. I fly them with quadcopter, and Eagletree is just not really adapted for this task for now.
m_beeson is offline Find More Posts by m_beeson
Old Aug 02, 2012, 10:21 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by nogas View Post
Can anyone tell me if i can use Guardian settings to eliminate some on power roll i am getting on my Bixler?
I have it trimmed to fly level and straight at cruise speed and it tracks nicely on the glide but as soon as i go above half throttle it banks to the right and goes into a gentle turn. If i trim it to fly straight at above half throttle it rolls left on the glide.
I have my vtx and cloverleaf antenna on the right hand wing so am wondering if the extra drag is causing the problem???
I am also wondering if there is a setting to minimise the tendency to pitch up on full throttle. I understand its a powered glider and thats what they are supposed to do but for FPV i'd prefer it just flew straight. i am currently constantly having to push the nose down when flying WOT.
Hi nogas,
the "rule no.1" is: the plane should fly perfect at "normal" rc-flight.
you have to trim and setup the plane BEFORE fiddling around with electronic settings. youŽll never get a optimal flying plane when you try to cheat failures in the mechanic/aerodynamic with settings
for that your plane glides well, my opinion is that your motor mount isnŽt aligned well. use shims between motor and wooden plate to shift the motor axis in the opposite direction of the curve at higher trottle.
same way to defeat the too high climb rate. the bixler is a pusher - therefore you have to shim the motor at the upper 2 mounting points.
take your time and do some flight tests and find a good setup - then you are able to setup the guardian and rth easily.
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Aug 03, 2012, 02:50 AM
pavn is offline
Find More Posts by pavn
pavn's Avatar
Czech Republic, Olomouc
Joined Sep 2010
Does ET OSD PRO support different compass, speed and altitude ladder styles like Dragon OSD?
pavn is offline Find More Posts by pavn
Old Aug 03, 2012, 02:51 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Is auto return to home autopilot easy to setup?
And is it reliable autopilot?
Old Aug 03, 2012, 03:00 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Does autopilot offers option to hold the current position?
To circle around the current position, I mean.
Old Aug 03, 2012, 03:47 AM
sancho28 is online now
Find More Posts by sancho28
No.
Yes if you read this thread carefully
Yes, very.
No.
sancho28 is online now Find More Posts by sancho28
Old Aug 03, 2012, 03:52 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Would you recommend me ET OSD PRO or Dragon OSD?
I am in decision between this two.
Originally Posted by sancho28 View Post
No.
Yes, very.
No.
Old Aug 03, 2012, 03:54 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Does ET OSD PRO offer frequent firmware updates with new features to be on top of OSD with features or just fixes the issues in the firmware?
Old Aug 03, 2012, 04:32 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Firmware updates and feature requests..
rcimports is offline Find More Posts by rcimports
Old Aug 03, 2012, 04:37 AM
I would definitely recommend it. Dragon is if you like DIY a lot. ET is much more RTF.
The only thing that bothers me with ET is their really poor handling of waypoints: limited in qty (3) and distance (2km I think).
Old Aug 03, 2012, 05:00 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Why do not they change that in tomorrow released firmware? Are they willing to listen users requests?
This is simple update, by my opinion and should not tak more than one day to implement it.
Old Aug 03, 2012, 05:16 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Could somebody check the following OSD comparison chart and update the part for ET OSD PRO, please?
Looks like there are few not actual things there.
https://spreadsheets.google.com/pub?...jg&output=html
Old Aug 03, 2012, 05:20 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Does autopilot support Auto-level, Heading hold and Position hold options?
Dragon OSD supports that.
Old Aug 03, 2012, 05:44 AM
South Africa
Joined Oct 2005
Not to be funny dude, but maybe you should go to their site, read the manual and features and then ask questions?
Features like max limits and auto way-point flights is legal restrictions.
Dion
Old Aug 03, 2012, 06:09 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
I ask since many features are supported by Dragon OSD and I would like to know if there is willingness at least to support the same with ET OSD PRO.
So I can select right OSD. Which will be excellent today and will stay excellent in the future. If here is willingness to make updates upon users requests and based on what other OSDs supports.
Dion
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
