Old Jul 27, 2012, 04:57 PM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
Originally Posted by carlocivicsi View Post
i dont have video of the osd display. all i know is that when I hit return to home I was 7000 feet away that's Little bit more then a mile away and it came back just fine. but it didnt circle above me.
It may be helpfull if you post your setting.
use the usb cable and go hardware then OSD, after that comes up, at the bottom you will see save configuration. that will be a TXT file . post that
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Jul 27, 2012, 07:43 PM
hodges42 is online now
Find More Posts by hodges42
United States, MS, Columbus
Joined Jul 2012
OSD PRO setup issues
I just received elogger v4, gps v4,osd pro and guardian stabilizer. when connected to laptop my guardian functions but wwhen disconnected from laptop the message stabilizer disconnected comes up. Also i have no gps read outs. It will blink 5 times when system is connected to laptop but no readouts, it works fine with my data recorder v2. Im running the beta software, ive tried them all and different firmware options and no help. I can add text to the display but it will not let me select the graphical inputs. Thanks for your help.
hodges42 is online now Find More Posts by hodges42
Old Jul 27, 2012, 11:38 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Carlo,
I answered your PM.
Let me know how those adjustments work for you. If you need to fine tune it after you get it climbing and turning, then let me know.
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Jul 27, 2012, 11:46 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Hodges,
recheck your wiring. Make sure that the devices are plugged into the proper ports and in the proper orientation.
Then when you are sure that You did it right, go back to the instructions, and check it again.
It just sounds like that could be your issue. I may be wrong, but that is the first thing I would check.
-Mike
Originally Posted by hodges42 View Post
i just received elogger v4, gps v4,osd pro and guardian stabilizer. When connected to laptop my guardian functions but wwhen disconnected from laptop the message stabilizer disconnected comes up. Also i have no gps read outs. It will blink 5 times when system is connected to laptop but no readouts, it works fine with my data recorder v2. Im running the beta software, ive tried them all and different firmware options and no help. I can add text to the display but it will not let me select the graphical inputs. Thanks for your help.
Old Jul 28, 2012, 04:24 PM
Joined Jul 2012
My elogger died, led does not flash and a gets warm when connected to usb on laptop. The osd pro doesnt work at all now when connected to my data recorder v2.
Old Jul 28, 2012, 06:09 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
hodges,
open a support ticket at eagle tree website
http://ticket.eagletreesystems.com/
Old Jul 30, 2012, 09:12 PM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
NEW VIDEO WITH OSD PLAYBACK
SATURDAY I was testing THE RTH,,,, it i was about 20,000 ft from home and 2000 ft in atl. it came home just perfectly but then as it got closer It passed by me at about 700 feet made a right turn (a wide one) and flew down to 200 feet when i clearly programmed it for it not to go lower than 550 with 50 error give or take.I thought that the RTH was supposed to keep on circling above me at a certain height.
AT THE END OF THE VIDEO I SHOW MY SETUP,, SO KEEP WATCHING. THANKS FOR THE HELP.
here is the video that i just finished editing and uploading.
Zii eagle tree RTH TEST (8 min 37 sec)
***i have attached my eagle tree file in case you guys want to look at it.***
carlocivicsi is offline Find More Posts by carlocivicsi
Old Jul 30, 2012, 10:02 PM
Cannonballer is offline
Find More Posts by Cannonballer
Joined Mar 2010
Actually doesnt look too bad.
You can try increasing your proportional gains.
Don't have the exact names of the setup items now.
I did post my settings a while back on the Guardian thread (I think).
I'm using a Bixler now (same as EZ star really)
Anyway...mine circles directly over me.
Me turns are tight enough it sometimes does a figure eight.
Works very nice.
RTH is an awesome feature.
Now if only Bill got around to giving us some way-point capabilities
Cannonballer is offline Find More Posts by Cannonballer
Old Jul 30, 2012, 10:09 PM
Joined Mar 2012
Works very nice.
yeah it comes home just fine but it keeps on loosing attitude. i want it to stay up and circle or do figure 8 what ever its is that it does but i dont want it to come down like its been doing to me.
at the end of the video you see what my settings are.
here is a screen shot of the video,,, the part of my settings
Old Jul 30, 2012, 10:17 PM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
http://www.youtube.com/watch?v=IetPeDwXmbc
Increase pitch proportional gain, it will help maintain altitude,...
Increase turn proportional gain to tighten up your turns...
Also make sure you are giving full elevator deflection when you run the servo analysis wizard..
I had a problem with my Twinstar holding altitude during RTH too..
I heeded the suggestion to give slight up elevator (climb) during the wizard when
"set sticks for level flight"
And give slight up elevator (climb) when asked during "Set throttle for climbing"
RTH now works beautiful..
My plane too will throw in a figure 8 now and then when it circles over head..
Mykro is offline Find More Posts by Mykro
Old Jul 30, 2012, 10:30 PM
Joined Mar 2012
How much gain u think i should add to pitch and proportional gains?
Old Jul 30, 2012, 10:40 PM
Joined Mar 2012
Deleted
Old Jul 30, 2012, 10:43 PM
Mykro is offline
Joined Feb 2009
I have my "Max Stab Pitch RTH (Guardian stabilizer menu) at 65
And I have "Turn Proportional Gain" (Safety mode menu) at 75
When you go to fly your plane after changing these settings, only fly your plane Line-of-sight ONLY at first..
It is not recommended to fly your plane where you can't see your plane with your naked eye until you have RTH dialed in..
Old Jul 30, 2012, 10:47 PM
Joined Mar 2012
Thanks I'll try that.
Old Jul 31, 2012, 12:27 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Increase Pitch Proportional Gain.
Keep increasing it until your plane does the following.
*when decending, it seeks the proper altitude,
*when engaged lower than cruise/home altitude, it responds,
and starts climbing to that altitude without loosing more than a few feet of altitude.
also:
It is safe to use 25 feet of error.
-Mike
*EDIT*
Carl,
I just read Mykros' post.
He hit it right on...
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
