Old Jul 27, 2012, 07:17 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by nogas View Post
When running the servo wizard (with Guardian) i am unsure which parameters to give full control input and which to give actual input. The manual states when using Guardian to give full control input and when not using it to give actual input. I am using Guardian so what input do i give for setting cruising? what about climbing?
hi nogas,
the only way you can find out the correct throttle settings is during the fligt tests.
during the first setup on the bench give a liitle bit more than half way for "cruise" and 3/4 for "climb".
my way to find the settings:
1) make some testflights "by sight" to find the proper CG, angle of attack, motor-shift, servo-throw, sets for expo, .... like any other plane without fpv-equipment.(all with guardian gain "0").
2) set the ahi
3) rise the gain of the guardian to the wanted rate of stabilisation
4) notice the stick positions for cruise and moderate climbout
5) redo the wizzard with those stick inputs
6) test and optimize the rth following the given order in the manual.
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Jul 27, 2012, 07:22 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
I'm not getting any count down.
It just tells me to hold the throttle / elevator / rudder aileron in position to climb / cruise / descend then hit next. Did everything it asks 3 times, trying different amounts of input and it says that it is finished everytime but still the menu tells me that i need to run the safety wizard.
hi,
just to be sure ... you wrote "hit next" - you are doing the wizzard on the pc - right? Mike described the "traditional" wizzard using the osd and a tv-connection.
i would do the do the wizzard connected to a tv and not with the pc also ... in former firmware-versions the pc-wizzard made some problems.
on the bottom line you see the commands what you should do followed by a number (which counts down) ...... when the next command comes up, the previous set was stored. hold the sticks until the next command appears and all is fine.
cheers Thomas
Old Jul 27, 2012, 07:24 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Originally Posted by Thint1 View Post
hi nogas,
2) set the ahi
cheers Thomas
Thanks Thomas.
OK, So for cruise, descend and climb i give actual inputs? I took note when flying today where the throttle was for each of those. Cruise (just below half), descend (no throttle) and climb (approx 3/4 - full)
So for the other parameters do i give full inputs?
nogas is offline Find More Posts by nogas
Old Jul 27, 2012, 07:31 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
hi,
just to be sure, do the wizzard connected to a tv and not with the pc.
cheers Thomas
No i'm not getting any numbers. It just tells me to hold the throttle, elevator in position for cruising, descending or climbing then hit next.
Maybe its just the computer version as Mike suggested???
Gotta figure out how to work this from my Tx. Kinda makes it difficult not being able to change settings at the field.
Old Jul 27, 2012, 07:34 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Thanks Thomas.
Hi,
yes, full stick inputs.
cheers Thomas
Old Jul 27, 2012, 07:38 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
Thanks again Thomas.
So i wonder why i'm still getting told i need to run the safety wizard to access certain settings in the menu???
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
sorry, i made some edits on the text in the same time you quoted
i´m not a native speaker and use only 2 1/2 fingers to type
pls read the post again.
using the menus of the osd you can change almost everything at the field .. only the layout of the osd´s screens need the pc-connection.
cheeers Thomas
Old Jul 27, 2012, 07:49 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
hi,
run the wizzard out of the osd menu (tv-connection). power off and reconnect to the pc and you´ll have access to all.
cheers Thomas
Old Jul 27, 2012, 07:59 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
OK, back to the manual to try to figure out how to control the OSD from my Tx. From memory i have to connect an Rx channel to an Aux port of the OSD???
Old Jul 27, 2012, 02:06 PM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
Originally Posted by carlocivicsi View Post
Another question that I want to ask is on the RTH.
I believe I have the radius 800 feet in altitude to 575. And outside the 800 radius I have it for cruising altitude at 2000 feet.
today when I was testing it out for the first time i was more than a mile out about 7000 ft from home and it came home just perfectly but then as it got closer It passed by me at about 700 feet made a right turn (a wide one) and flew down to 50 feet of the ground and i was waiting for it to climb but i wasent climbing, it went down to 50 ft !! and if I wouldn't off pulled up on the stick it would've kept on going lower. I thought that the RTH was supposed to keep on circling above me at a certain height. Sorry for the newbie questions but I'm really new to Eagletree and to fpv.
this is the video of my problem.
My Eagletree RTH Problem. (4 min 2 sec)
carlocivicsi is offline Find More Posts by carlocivicsi
Old Jul 27, 2012, 02:08 PM
Joined Mar 2012
deleted
Old Jul 27, 2012, 02:41 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Nice vid, you have some balls leaving it that long to see if it will kick in!
Have you got a vid of the OSD display and settings? It should keep alt yes, did everything display correctly in the OSD?
Dion
rcimports is offline Find More Posts by rcimports
Old Jul 27, 2012, 03:11 PM
Joined Mar 2012
Dion
i dont have video of the osd display. all i know is that when I hit return to home I was 7000 feet away that's Little bit more then a mile away and it came back just fine. but it didnt circle above me.
Old Jul 27, 2012, 03:36 PM
diasyuri is offline
Find More Posts by diasyuri
Joined Nov 2010
Dear Bill,
Do you think the problem below is because of some incompatibility of the LRS system and the ET OSD ?
__________________________________________________ ______________________
Dear friends from RCgroups,
I´m having a problem with my ET system and a new CL rx, my aileron servo doesn´t stop jittering when I turn the CL tx on.
CONNECTIONS
I use the RTH function of the ET system, so I connect the CL rx´s servo signals into the ET OSD and then to the servos. This way when I turn on the CL tx the servos start jittering
I did a few tests.
a) When I connect the servos directly to the CL rx, the servos work fine.
b) If I connect only the elevator channel from the CL rx into the ET OSD, everything works fine.
c) But If I connect the aileron channel from the CL tx into the ET OSD, the servos start to jitter as soon as I turn the CL tx on. (it doesn´t matter if the elevator channel is also connected).
d) If I substitute the CL rx by my Spektrum receiver, everything works fine (aileron and elevator).
The problem only appears when I use the CL rx AND the ET OSD, so I guess the problem is not with the ET OSD exclusively, because it works ok when I use another receiver. But is not also a matter of UHF interference, because the servos work fine if only the UHF system is not being used.
Any ideias ?
Thanks in advance
PS. a video depicting the problem:
Chain link TX interference (4 min 11 sec)
diasyuri is offline Find More Posts by diasyuri
Old Jul 27, 2012, 04:07 PM
South Africa
Joined Oct 2005
You'll need to provide more settings etc. if you need help here.
Dion
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
