Old Sep 23, 2008, 11:04 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
Bill,
I recently tested a GPS only Backup Artificial Horizon and Nav system for GA and was very impressed with it's performance.
Have you guys worked any on your GPS based AH implementation and considered including it for your latest offering?
Have a good one and keep 'em AGL!
Camship
camship is offline Find More Posts by camship
Old Sep 23, 2008, 11:25 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Originally Posted by camship
Bill,
Camship
That is a good idea, I would never use A GPS based horizon in my real plane, but it would be a great, small, inexpensive, and light solution for FPV. I would like to see someone do this.
JettPilot
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Sep 23, 2008, 11:53 AM
FPV Bill is offline
Find More Posts by FPV Bill
Austin, TX
Joined Sep 2007
JettPilot
Interesting. Can somebody explain how a GPS based artificial horizon works since the GPS doesn't know anything about your pitch or roll?
FPV Bill is offline Find More Posts by FPV Bill
Old Sep 23, 2008, 03:19 PM
Berzert is offline
Find More Posts by Berzert
KJ4ZQE
Berzert's Avatar
Nashville, TN
Joined Nov 2007
I assume the G-Force Expander could be used to measure pitch and roll. You need a gyro for detection, then it just needs to be interpreted graphically into an artificial horizon. The roll indicator Bill included looks like half the battle. Most of the artificial horizons in FPV OSD's don't seem that accurate. Trust me, I would love one. But it would have to be relatively accurate for me to try to use it. I have this grand dream in my head to shoot an approach at night and do a "carrier" style landing with a tail hook and arrestor cable. That would require some accuracy. Back to the topic at hand, I think this comes back to my mantra about flexibility. I think the data is there (via the G-Force Expander) therefore it *should* just be a matter of presenting the information differently. But I'm no expert, so please don't flame me if I'm wrong.
Berzert is offline Find More Posts by Berzert
Old Sep 23, 2008, 03:20 PM
Berzert is offline
KJ4ZQE
Berzert's Avatar
Nashville, TN
Joined Nov 2007
Bill,
Camship
Do you have any links to videos of this product?
Old Sep 23, 2008, 07:59 PM
camship is offline
camship's Avatar
Joined Oct 2001
It is a software product called WinEFIS that runs on anything from a Palm, (PalmEFIS) to a PC and works pretty well. It is published along with a lot of other really great stuff by a company called Hangar B 17.
I just went to check their website and get no page. Possibly they are currently doing work on the page or it's gone. I am not sure.
There are several other companies that use this software/hardware to integrate with their own stuff, Zaon Flight Systems is one of them that has a product that integrates their Collision Avoidance System with WinEFIS and much more.
There are some really amazing things happening in GA that translate directly to FPV/UAV.
Hope that company is still around. I do have copies of the software and will try and make a video.
Have a good one,
Camship
Old Sep 23, 2008, 10:24 PM
CATPart is offline
Find More Posts by CATPart
CATPart's Avatar
Joined Mar 2008
i'm going to take a stab at this one..perhaps the gps antenna orientation could be determined by the differential signal strengths of the various satellites it has locked. if the gps is antenna is mounted firmly on the plane then you could possibly infer the planes orientation from the last known. camship?
CATPart is offline Find More Posts by CATPart
Old Sep 24, 2008, 06:51 AM
emagnee is offline
Find More Posts by emagnee
Pseudo-Pilot
emagnee's Avatar
Grand Blanc, MI
Joined Oct 2005
Bill,
What's the status of your current OSD stock?
It's now the 24th, and your website still says it will be available ~20th.
emagnee is offline Find More Posts by emagnee
Old Sep 24, 2008, 06:58 AM
camship is offline
camship's Avatar
Joined Oct 2001
You are close to a system that has been in testing for a while. This experimental system uses a faceted GPS antenna apeture that is similar to an insects eye. This causes a "blanking" of some satellites while others become visible and attitude is derived from that. But alas, nothing as sophisticated as what you describe.
WinEFIS uses a lot of calculations based on rate of change in altitude, direction and speed. If the performance charateristics of the aircraft are a known value then a lot can be derived from the positional changes in 3D space.
If perhaps you are climbing at a specific rate then most likely the attitude of the aircraft is nose high. The rate of change will determine the amount of pitch change and show the appropriate changes in the AH.
It is easy to see where this can get you in trouble. Say perhaps you are in a thermal then the aircraft can be flying straight and level but the system "sees" this as a climb and "indicates" a nose high attitude.
To help solve this little puzzle the data available from GPS is much more than just position. In many instances the wind direction and speed are included in the GPS information in 50' "layers". Sailplane pilots have been using software for extracting this info for a few years since it is very important for duration soaring.
BTW, their website is back up; www.hangarb17.com
I am thinking of trying this with the GPS data stream from my on-board radio modems. The only thing I don't like is that it gets a bit "jerky" if there are only a few satellites visible. It would not work for aerobatics and such and would only be good for casual flight manuevers.
Hope this helps and sorry Bill for yammering on your thread. I know you guys do have an AH very similar to this already included in your PC software. I know your team is hard at work on something even better for us, right?
Camship
BTW, I am definately going to put the snag on your OSD PRO when it comes out!
Old Sep 24, 2008, 10:11 AM
Crash9 is offline
Find More Posts by Crash9
FPV Pilot
Crash9's Avatar
United States, MT, Missoula
Joined Mar 2006
Originally Posted by emagnee
Bill,
I just got one last week from here http://www.endurance-rc.com/ and there's a few other vendors out there like dpcav.com that still have them in stock
Crash9 is offline Find More Posts by Crash9
Old Sep 24, 2008, 11:30 AM
emagnee is offline
Pseudo-Pilot
emagnee's Avatar
Grand Blanc, MI
Joined Oct 2005
Thanks, Crash9.
Hopefully I'll still be eligable for the upgrade to the "pro" since I didn't buy it directly from Eagle Tree!
Old Sep 24, 2008, 12:08 PM
Carlyle Harper is offline
Find More Posts by Carlyle Harper
Carlyle Harper's Avatar
Joined Feb 2007
Bill,
Was wondering the same thing.
Carlyle Harper is offline Find More Posts by Carlyle Harper
Old Sep 24, 2008, 04:49 PM
emagnee is offline
Pseudo-Pilot
emagnee's Avatar
Grand Blanc, MI
Joined Oct 2005
I just received an email from them saying " We hope to have inventory available sometime during the next month or so".
I just ordered from www.endurance-rc.com, They just don't have the GPS Expander in stock.
Eagle Tree also told me that I will still be eligable for the Pro upgrade.
Old Sep 25, 2008, 12:27 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi All,
First, thanks for the great feedback on the Pro! We are making lots of progress in development, and all the feedback will be incorporated where possible. Please keep it coming! I'll have more detailed responses on the feedback soon.
Regarding availability of the present OSD expander, we are supposed to receive the next shipment next week. It will take us a day or two to get all outstanding orders turned around.
Please contact your favorite Eagle Tree dealer for their stock status. Yes, regardless of where you buy the expander, the upgrade offer will apply!
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Sep 25, 2008, 03:59 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
Great News Bill, thanks again for all the quick responses, answering all questions in a timely manner.... I tell ya that is why people love Eagle Tree stuff so much.
I have a question though. I am waiting for the OSD pro unit to come out and seeing as that is not till Christmas will there be a new Vlogger coming out between now and then? I am wondering if I should buy the V-logger and use that till the osd comes or wait for the possible release of the next V-logger if it is coming soon?
Thanks!
saabguyspg is offline Find More Posts by saabguyspg
Site Sponsor
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
