Old Jul 15, 2012, 05:01 AM
TimeWheel is offline
Find More Posts by TimeWheel
Joined Apr 2007
Originally Posted by nrg2go View Post
Actually you can put them in the wrong way!
The included male to male leads have only one end with a keyed Futaba style connector. The other end can go on either way.
So have you confirmed that the black wire is nearest the board (both sides)?
I´m using JR RX so there is no way to connect FUTABA end too it. And yes I did checked and even switched them
TimeWheel is offline Find More Posts by TimeWheel
Old Jul 15, 2012, 05:36 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by nogas View Post
Just about finished my wiring harness but have a question. I am running an external bec so have clipped the positive from the esc to the Rx, i remember reading a while back that i should also clip the ground to prevent a ground loop. Is this correct?
Hi nogas,
yes, that´s correct! only connect the signal to prevent a ground loop.
otherwise the loop is: battery - esc - osd - rx - bec - battery (minus-wires).
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Jul 15, 2012, 05:16 PM
Kipkool is offline
Find More Posts by Kipkool
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
Does anyone suceed to use a compass with osd ? Gps based heading is kind of useless with heli & multicopter when hovering or flying slow.
I'd really like eagletree realease a protocol trought serial to receive flight controler sensor data ( Compass, Gps, attitude ).
We already have good tilt compensated compass data in multiwii or others, why not let us using them ?
Kipkool is offline Find More Posts by Kipkool
Old Jul 15, 2012, 05:42 PM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Originally Posted by Thint1 View Post
Hi nogas,
cheers Thomas
Thank you Thint1.
nogas is offline Find More Posts by nogas
Old Jul 15, 2012, 05:52 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Kip,
They are working on a x-copter project.
I don't know any details, but it is in its' infancy stages.
m_beeson is offline Find More Posts by m_beeson
Old Jul 15, 2012, 06:20 PM
nrg2go is online now
Find More Posts by nrg2go
Aussie, Aussie, Aussie!
nrg2go's Avatar
Australia, NT, Katherine
Joined Apr 2009
If you want heading in the hover you are going to need a Magnetometer.
nrg2go is online now Find More Posts by nrg2go
Old Jul 16, 2012, 03:52 AM
Kipkool is offline
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
That's why I asked if there's some tilt compensated compass that works with. Compass = Magnetometer.
Old Jul 16, 2012, 04:32 AM
neo__04 is offline
Find More Posts by neo__04
Australia, VIC, Warrnambool
Joined Feb 2012
Hey all,
Trying to get my fpv setup reliable and bulletproof and have had problems with cheap sunsky video rx and uhf interference.
I ended up getting 2 x new 1.3ghz racewood rx from RMRC to fix this problem.
I just tested them both and with these video RX with my eagletree osd i get a blurring/ streaking of the white of the text across the width of the screen.
if i plug my sunsky rx back in, looks perfect.
Any ideas what this could be? I've attached pics so you can see what i mean.
Thanks heaps!
neo__04 is offline Find More Posts by neo__04
Old Jul 16, 2012, 05:27 AM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
Originally Posted by neo__04 View Post
Hey all,
Thanks heaps!
You May need to change the numbers
Set OSD Text White Level: Adjusts the white level of the OSD Pro text and graphics. Normally, this does not need to be changed from the default
setting of “7.” However, if you see “white streaks” or other anomalies associated with the text display on your video screen, decreasing this value
may help.
· Set OSD Text Black Level: Adjusts the black level of the OSD Pro text and graphics. Normally, this does not need to be changed from the default
setting of “4.” However, if you see “white streaks” or other anomalies associated with the text display on your video screen, increasing this value
may help.
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Jul 17, 2012, 08:07 PM
nogas is offline
nogas's Avatar
Joined Feb 2011
I've got the ET up and running and am starting to play around with it. Is there any templates for info positions? or is it just a case of adding it all my self? Also how do i add the graphical readouts? i can only add numerical at the moment.
I also went to run the servo wizard but it asked me to set the cruise throttle and servo positions. How do most do this? Just make a note of where they hold sticks for the desired speed? and will it matter if i disconnect the motor for this process, (doing this in the house after the kids go to bed and although i love the sound of a brushless motor winding up, my family strangely doesn't share the same love at 10pm)
Old Jul 18, 2012, 05:16 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Just add yourself, I usually take a screenshot of somebody else's I like and make it the same, on the software you can select Graphical or numerical values to display.
You set the stick like you would when you are cruising, don't worry if this is not perfect, when you go fly you can go into a cruise and then go into menu and reset cruise postions, disconnecting the motor is fine,
Dion
rcimports is offline Find More Posts by rcimports
Old Jul 18, 2012, 06:00 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
Dion
Thank you Dion, i'll have another play tonight. No doubt i'll have more questions later.
Old Jul 18, 2012, 09:38 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Nogas,
When you set climb postion; Take note of a stick position that puts you into a reasonable climb.
Going full throttle can give you undesired results.
Old Jul 18, 2012, 08:03 PM
Pathfinder22 is offline
Find More Posts by Pathfinder22
United States, FL, St Cloud
Joined Dec 2011
Are we able to change the ft/km to read as miles yet?
Pathfinder22 is offline Find More Posts by Pathfinder22
Old Jul 19, 2012, 12:18 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
not to my knowlege
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
