Old Jul 12, 2012, 02:44 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Received my OSD Pro with expander ! Now I need to work out how to make the magic happen !!
OzparkPilot is offline Find More Posts by OzparkPilot
Old Jul 12, 2012, 08:09 AM
Atx_Heli is offline
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
Originally Posted by m_beeson View Post
Thank you guys for your support.
I'm still floored over loosing that much $$$.
I have hopes of it being found, but I am finding that it will almost take a miracle.
The thing that upsets me most (besides the money) is loosing the video of the flight.
It was hands down the most amazing personal FPV flight to date.
I won't hang it up.
And for the record, I tested RTH when I first took off; It was working flawlessly, It was just in a situation where the plane couldn't make it back.
That GPS tracker is getting more appealing to me. When you guys were discussing it on another thread, I didn't like the idea of having to pay for a cell service, but it looks like there is more too it. I would like to hear more about the
the way it sends a signal, and all of it's options.
Kajeet is $5/month.. $1/locate..$30 LG phone....I have one in all my long distance planes/wings that have RTH....most of my FPV buddies have em now also...bought one after I took my Mentor out 10 miles and only made it 7.75 back when I didn't notice that I had picked up a tailwind at altitude
recovered intact (thanks to the guardian gliding it straight into the targeted "ditching" field I picked out before losing video)
Atx_Heli is offline Find More Posts by Atx_Heli
Old Jul 12, 2012, 08:12 AM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
Hey ATX Heli, what setup(motor, battery, prop) are you running on your Mentor? Do you have the RTH working good on it? If you do, could you post the settings for it? Thanks!
philthyy is offline Find More Posts by philthyy
Old Jul 12, 2012, 05:26 PM
papa_lazerous is offline
Find More Posts by papa_lazerous
papa_lazerous's Avatar
United Kingdom, Southend-on-Sea
Joined Feb 2011
Evening all, I'm hoping to pick somebody's brain. I maidened my Vega flying wing Sunday (very similar characteristics to the zephyr) and I just used a backup of my settings for my skywalker on my new setup for the OSD pro thinking that it would be close.
Well it fought me there whole flight so much so I struggled to land it. I had centre stick stabilize turned on for a start, so if I banked at all and started to centre the stick the wing was snapping back to level in an instant, I am thinking of turning of centre sick stabilize and also lowering the gain so it doesn't roll so hard. Anybody flying a wing that can advise on settings used or give any tips?
papa_lazerous is offline Find More Posts by papa_lazerous
Old Jul 12, 2012, 11:15 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
papa_lazerous,
I found that the wing is much more responsive.
I would do as you said; turn off CSS, and lower stabilization gains.
(when stabilization gains are high, then it moves the elevons more agressively, and this creates a side to side waggle).
The key with a wing is to stabilize, without adding too much stabilization gain.
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Jul 12, 2012, 11:22 PM
Joined Feb 2011
Thanks Mike, I knew I was thinking on the right track but it's good to bounce an idea off someone else just incase :-)
Old Jul 13, 2012, 07:23 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
3548 900V motor, 13x6.5 prop, 2x 3S 5000mah....
cant check the OSD settings until next week, but will post then...from defaults, my stabilizer gains and responsiveness are about 1/2...and I had to increase the RTH Turn P and I gains some to get it to turn to home in a glide
Old Jul 14, 2012, 11:40 AM
TimeWheel is offline
Find More Posts by TimeWheel
Joined Apr 2007
no elevator
I have an issue with the OSD PRO, when I connect the OSD PRO, the elevator servo does not work. Eelevator servo connectet directly to the RX works perfect. I did run the servo analysis wizzard with no result(actualy I can see correct reaction in the soft, but servo is not moving). Also, servo getīs 5V from OSDPRO but no steering signal.
maybe somebody had such a problem?
OSDPRO is brand new, bought couple month ago, just never had a chance to connect and configure.
TimeWheel is offline Find More Posts by TimeWheel
Old Jul 14, 2012, 12:06 PM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
Q: with the eLogger and GPS, what else do I need to auto fly way points or alitude corrections?
PROACE is offline Find More Posts by PROACE
Old Jul 14, 2012, 02:31 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
PROACE,
OSD Pro only flies autopilot in RTH mode.
it will seek your designated RTH altitudes, but you have to fly it to waypoints if you choose to setup waypoints.
You have two RTH altitudes, the cruise altitude, and the home altitude.
The cruise altitude is the altitude outside of the home boundries, you can set the size of the home circle in the OSD menu.
The home altitude is the altitude inside of the home boundries.
Airspeed, and altimiter microsensors are nice, but all that you really need is the osd pro, e-logger, and gps with guardian to have a fully functional RTH.
Old Jul 14, 2012, 02:33 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
check your wires,
Ground always goes nearest the board, so when they are on the bottom, the ground is on the top, and vica verca...
Old Jul 15, 2012, 01:33 AM
Joined Apr 2007
check your wires,
Iīm using included male to male servo connectors and you can not put them "wrong way":
Note that the Futaba plug enforces correct polarity when connected to the OSD Pro.
Tried different RX... same thing.
Old Jul 15, 2012, 02:06 AM
nrg2go is offline
Find More Posts by nrg2go
Aussie, Aussie, Aussie!
nrg2go's Avatar
Australia, NT, Katherine
Joined Apr 2009
Actually you can put them in the wrong way!
The included male to male leads have only one end with a keyed Futaba style connector. The other end can go on either way.
So have you confirmed that the black wire is nearest the board (both sides)?
nrg2go is offline Find More Posts by nrg2go
Old Jul 15, 2012, 02:12 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Just about finished my wiring harness but have a question. I am running an external bec so have clipped the positive from the esc to the Rx, i remember reading a while back that i should also clip the ground to prevent a ground loop. Is this correct?
nogas is offline Find More Posts by nogas
Old Jul 15, 2012, 02:48 AM
hornant is offline
Find More Posts by hornant
Back in Hong Kong
Joined Sep 2003
Has anyone used the stab pitch normal and stab roll normal at the max setting (90)
I want to try it.
I hope to get more maneuverability in normal flight (loop,roll) and I hope this will help.
hornant is offline Find More Posts by hornant
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
