Mykro,
Those oscillations are nasty . I have had similar (RTH climbing) problems with my 2nd ET setup on a Ritewing ZII. I added some back elevator when setting the climb throttle which seemed to help. Perhaps you could try that and take the 'Max Stab Roll RTH' in the Guardian Setup back down to the default 35. Good luck Tony Quote:
Just like in a full size plane, with each new flight or different conditions, one has to re adjust the trims. |
I think the idea is to get the off Guardian and on Guardian flying the same. My expierence with foam planes: from one day to the next can change the trims. If I put on the Guardian the plane flys OK... with out Guardian the plane may need a little trim but, I just leave it alone as long as the Guardian is compensating. The maual does say to run the Wizard after retriming the plane. CAUTION: you can get the ajustments so far out that when the Guardian in on you can lose most of the plane surfaces movement. So when you move the sticks you have little or no movement. Thank to rudder I still have that plane. |
YES!!! That’s what it was “The manual does say to run the Wizard after retriming the plane.”
So let me ask this. Using a 7 Channel radio configured with the 3 way switch (Up-RTH, Mid and Low-OSD menu) which means the Aux Channel is used for scrolling in OSD. In short all I have is the Gear retract Channel opened. With that 3 way switch config, is there any way I can assign the on/off Guardian to the retract channel? Needless to say, being new to FPV flying, I’m just not comfortable enough to go into the OSD menu, scroll and go into the “configure control” sub menu, scroll again and finally turn off the Guardian, all while trying to fly at the same time. I’m just not that efficient yet. Heck, I get all stressed when during flight I need to go into the Guardian menu to reset the Artificial horizon line. Speaking of which. Have yet another question. And please forgive me but I’m going from memory and don’t have the plane or OSD manual at hand. When I go and turn on the Artificial horizon, the options I see is off, 1-65. I tried 1, 2,3 and 65 but can’t tell if there is a difference. What is the difference between those numbers? |
Note: The failsafe positions used by your receiver are detected during the Safety Mode Wizard, so you will need to program your receiver’s throttle failsafe position before running the Safety Mode Wizard. You must rerun the Safety Mode Wizard after any reprogramming of your radio’s failsafe positions! So, when I retrim I reset my failsafe then I run the Safety Mode Wizard I use the 3Way switch but not for RTH. Aux2 iswhat I use for the gain so connect the aux2 to the switch and see if it works. the 1-65 are the other pages you can set up. |
Maybe someone her can help i am having trouble setting up an RTH on my SW.
I have setup the failsafe on my TSLRS ( i am using a MPX EVO 9 ) all control surfaces center sticks and no throttle. then i have run the servo analysis wizzard, until here all good... then actvating flight sim in the menu i can fly around but if i leave throttle center rth engages I had the idea to do the Carlyle Harper method by using the throttle cut function but that is not working either. if i unplug the TSLRS TX the plane will go into RTH no problem. I hope someone can help. and sorry for my English ![]() /Srolin |
Mykro,
increase pitch proportional gain, so it will maintain altitude, and increase turn proportional gain to tighten up your turns. -Mike Quote:
France, Bourgogne, Nevers
Joined Feb 2012
Could you point me to the best source for general information about setting up PPM on the eagle tree equipment? Is the firmware version available-- where? Thanks again, Jim |
Also http://www.eagletreesystems.com/Support/apps.htm I'm using Beta 10.39 http://www.eagletreesystems.com/Support/manuals.htm then ... Click on •OSD Pro User Manual Go down to Serial PPM Support |
Thint1, thanks for posting the video - it should not be switching away from the clearer signal (as you know). I am not sure if that's an issue with the type of antenna, or (probably more likely) something between the EE and the receiver. We have a way now of debugging these types of problems remotely, which we can do if the issue occurs elsewhere.
freshmint, I think the data in the logger is corrupted. is this the first time you've used logging? I'd recommend deleting the recorder's existing log (unless it's important for you to have the flight data) by clicking "data, clear recorder buffer" and seeing if the problem occurs in future flights. Or, if it's info you really need, could you open a ticket with us, and we may be able to help get the data (http://ticket.eagletreesystems.com). randy, please let me know if you see something similar again. Kipkool, thanks for your support! We're looking into some possibilities along the lines of what you're suggesting. |
| Thread Tools | |
| For Sale BRAND New CP Pro/with extra battery | stgtech2 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 06, 2006 09:35 PM |
| New eolo pro glitches with cc60 | aschen | Electric Heli Talk | 24 | May 20, 2004 08:12 AM |
| FS New Piccolo Fun with bearing upgrade and HA tail motor | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2004 06:32 PM |
| For Sale: NEW Pic Pro rotor head with stiffening mod | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 02, 2003 09:16 PM |
