Old May 28, 2012, 03:21 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by sfakias View Post
Well, I (and others I guess) have been using the voice alerts feature without any problems, so there must be a cause and solution to your particular problem.
-What vid tranceiver are you using? Have you tried to plug directly the vid output of your OSD to a viewing device (without transmitting and receiving the signal)?
-Have you tried altering the voice alerts volume level?
Im using the LM 2.4GHz vtx when altering the voice alerts volume level to 4 it's get worst the lower the number the better it get but its still there.
Not sure how I would plug my tv to the video out on the osd pro?
I notice the Elogger get really warm almost 50C when the 4s is plug in.
freshmint is offline Find More Posts by freshmint
Old May 28, 2012, 04:01 PM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
To connect your viewing device (TV) with the OSD pro, you just have to make a custom harness (two wires cable, preferably shielded) that on one end it will have a servo connector and on the other end an RCA connector (assuming your TV accepts RCA A/V input). Connect via the harness the ground pin of the OSD to the outer ring of the RCA connector, and the video signal out pin of the OSD to the center pin of the RCA connector.
Regarding the heat issue, are you using the supplied Y cable to log in throttle position? If not, go ahead and connect it between your rc rx and the e-logger, and it might reduce the temperature of the voltage regulators of the e-logger, since it provides back-up power to the e-logger.
Let us know how it goes.
Regards,
Stavros
sfakias is offline Find More Posts by sfakias
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
hi freshmint,
you need an old video- or audio-cable and a servo-plug.
the inner lead is "signal" the shielding is "ground". see the photo how it is done.
donīt worry about my red plug, iīve recycled an old audio-cable
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old May 28, 2012, 04:07 PM
sfakias is offline
ScratchCrasher
sfakias's Avatar
Joined Jun 2008
That's exactly what I meant Thomas! Thanks for posting the photo.
Sometimes typing is faster than taking a pic
Best regards,
Stavros
Old May 28, 2012, 04:17 PM
Joined Nov 2011
Regards,
Stavros
I will make the harness and report back
While doing testing I dont have esc.thro connected.
Old May 28, 2012, 04:19 PM
Joined Nov 2011
i read somewhere the max temp for the elogger is 240f so i should be fine at 50c
Old May 28, 2012, 04:31 PM
Joined Nov 2011
Regards,
Stavros
My osd pro dont turn on unless I have cam connected? is this normal
Old May 28, 2012, 04:41 PM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
hi freshmint,
yes, thatīs the normal behavior.
cheers Thomas
Old May 28, 2012, 05:30 PM
mentony32 is offline
Find More Posts by mentony32
mentony32's Avatar
Australia
Joined Jun 2010
Hotdog,
I have had that exact issue before and would think it is because your BEC cannot provide enough current to supply the servos, therefore the voltage drops and causes the Dragon Link receiver to reset, hence the 2 second delay. My buddy garris2 and I confirmed this just the other night with a multimeter across the R/C power as it was ocurring. I solved the issue by powering the R/C with a SBEC sepatrate to the ESC. The issue is worse if you run 4S like I do.
Tony
Originally Posted by hotdog1 View Post
Ok guys I need your help I have everything set up and working osd,gurrdian,ee,tracker. It here is my problem everything worked fine until I installed guardian now when I go full throttle its as if I am only getting 1/4 throttle from the motor. Also when I give a aileron on, elevator or throttle command there is almost a full 2 seconds before the servos or motor move for the first time. It once the get moving everything is fine untill I stop moving them then if I try to Move then again there is again a 2 second delay.has anyone else expericed this ?
mentony32 is offline Find More Posts by mentony32
Old May 28, 2012, 06:13 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Originally Posted by mentony32 View Post
Hotdog,
Tony
I too am running a 4s setup. thanks I will use a sepatrate bec and see if that helps. I dont know if i will find out if it fixed the problem though because when i got home the issue wasn't there. weird
hotdog1 is offline Find More Posts by hotdog1
Old May 28, 2012, 07:09 PM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
Maiden FPV flight. Went a mile out, hit some clouds and a few speed runs.
At the 3:15 mark, you can see the Pan/tilt looking around.
Zephyr II Pan and Tilt Camera, Clouds and Cruise. Flown with Dragonlink (15 min 8 sec)
GregSilver is offline Find More Posts by GregSilver
Old May 28, 2012, 07:56 PM
Joined Nov 2011
http://www.youtube.com/watch?v=xQTQN9kDIsc
repost respot repost
Old May 28, 2012, 08:09 PM
GregSilver's Avatar
Joined Nov 2005
shh... its all relative for the thread its posted in.
Old May 28, 2012, 10:22 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Nice flight
m_beeson is offline Find More Posts by m_beeson
Old May 29, 2012, 01:20 AM
LaserBeam is offline
Find More Posts by LaserBeam
You Know What I Mean
LaserBeam's Avatar
Australia, NSW, Sydney
Joined Dec 2011
Yellow Title is Link
Originally Posted by filitov View Post
As you can see its a youtube link ... so yes its on youtube
No i didnt see that it was a YouTube link as i usually watch the videos here in RCGroups. Now is realise the yellow title at the top is the link. Thanks.
LaserBeam is offline Find More Posts by LaserBeam
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
