EDIT: Problem 1 - Needed to configure a few more things on the OSD Problem 2 - Loose camera wire where it plugs into the camera board. Fixed both of those problems and now I have video! Now on to configuring failsafes and RTH...
M. Beeson, you Sir, are a gem! Adjusted the plane characteristics as suggested and when I add a little throttle from cruise it climbs and it's not even pulling bugger all amps too! Only thing it is doing is zig zagging on it's way home, I'd say about 50-75 metres to each side but it is reaching home and doing a u-turn and heading off a little then turning again. So the only thing I'd like to know how to settle is the zig zagging. Any ideas? |
are you using ailerons? or rudder...
Pitch Derivative Gain Turn Integral Gain Turn Derivative Gain Let me know it this does the job, or if we still need to fine tune it... |
DL rssi and OSDpro
Anyone using the DragonLink RSSI with ET gear. I went through all the info but can't get it to work. I also run the wizard with the new RSSI hooked up. When I set Temp 1 to RSSI and connect to the center pin my amps spike and battery voltage goes up from 12 to 20 on the OSDpro screen....Ive read where the new DL 12c has buffering now so no need for the DPCAV buffer....is this correct or do I need to get the buffer.
Thanks.
| Thread Tools | |
| For Sale BRAND New CP Pro/with extra battery | stgtech2 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 06, 2006 09:35 PM |
| New eolo pro glitches with cc60 | aschen | Electric Heli Talk | 24 | May 20, 2004 08:12 AM |
| FS New Piccolo Fun with bearing upgrade and HA tail motor | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2004 06:32 PM |
| For Sale: NEW Pic Pro rotor head with stiffening mod | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 02, 2003 09:16 PM |
