Old Mar 11, 2012, 09:52 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by Pixturethis View Post
I'm setting up ppm.
I see I only need power & signal to the OSD. If I only use signal it doesn't work.
I do have a spare channel used to power my rec.
Marc
If you just run your regular ("3 wire" with jst) from the receiver to the osd, you should be fine.
m_beeson is offline Find More Posts by m_beeson
Old Mar 11, 2012, 11:02 PM
ScoRpiUs2009 is offline
Find More Posts by ScoRpiUs2009
ScoRpiUs2009's Avatar
Australia, VIC, Mordialloc
Joined Aug 2009
nothing plugged in backwards and ive replaced all servo wires from osd to receiver,
just tried with the beta version but still nothing
Originally Posted by m_beeson View Post
plugged in backwards? ground goes closest to board.
Bad plug?
You got me...
ScoRpiUs2009 is offline Find More Posts by ScoRpiUs2009
Old Mar 11, 2012, 11:55 PM
KIR2142 is offline
Find More Posts by KIR2142
KIR2142's Avatar
Russia, Klin
Joined Nov 2010
Please add a space after the voltmeter.
Bill.
This is a very old bug. Dear Bill, please fix it in the next version.
KIR2142 is offline Find More Posts by KIR2142
Old Mar 12, 2012, 03:02 AM
RobJCook is offline
Find More Posts by RobJCook
RobJCook's Avatar
Wagga Wagga, Australia
Joined Sep 2008
menu input(s) not detected
I have just upgraded to 10.3 and on start up I have the following error message, "menu input(s) not detected". I have only Aux 1 connected between the RX and OSD pro. This is on a 3 position switch on the TX. I can toggle between lower and center positions and enter and navigate the OSD menu. But nothing happens between center and upper position, On hooking the RX to a servo, the servo obeys all three positions.
Were I meant to select an option in the Windows OSD setup?
Rob
Help!
RobJCook is offline Find More Posts by RobJCook
Old Mar 12, 2012, 05:44 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Rob
Help!
hi Rob,
pls. check your settings
menu "Radio Control Configuration Menu" item "Choose Menu Receiver Inputs" should be "3Position" if Aux2 is unconnected.
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Mar 12, 2012, 03:29 PM
RobJCook is offline
RobJCook's Avatar
Joined Sep 2008
Originally Posted by Thint1 View Post
hi Rob,
cheers Thomas
Thanx Thomas - that's what I had to do! Works great now.
Rob
Old Mar 12, 2012, 04:57 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Originally Posted by sfakias View Post
I would doubecheck all the connections for start. Does ιt cut off if you just hold it in your hand and apply full throttle? If it does, maybe it is an issue related with voltage shag during take off, but this is only a wild speculation.
I tested the plane on the ground. I could not cause it to cut out by shaking any wires or components, but I noticed that every time I powered up from zero throttle, the OSD would cut out. Actually, I have the ESC set to 'beep' when it sits idle. Every time it does this, the OSD cuts out. I don't understand why because the voltage it fine (using a 4s), and the LED on the bec isn't showing any signs of even a rapid voltage sag.
Could there be some sort of feed back finding its way through the external BEC?
ashdec87 is offline Find More Posts by ashdec87
Old Mar 12, 2012, 11:46 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
ScoRpiUs,
This is one of the rare cases when I will say this, but I am wondering if your servo did not fail at all, and I wonder if it is a terminal connection in your OSD.
I don't know if you have troubleshot the servo by plugging it directly into the receiver,
but I am starting to think that you should open a support ticket
http://ticket.eagletreesystems.com/
-Mike
Old Mar 13, 2012, 01:08 AM
Joined Aug 2009
thanx mike, i have submitted a ticket, just thought id post here incase someone has a solution, ive searched through the whole eagletree forum and found nothing on my proglem .
ill just have to wait till someone from eagletree gets back to me about the problem
ScoRpiUs,
-Mike
Old Mar 13, 2012, 10:12 PM
chasdabigone is offline
Find More Posts by chasdabigone
United States, TX, Rockwall
Joined Sep 2007
Hi, I cannot figure out how to turn off the display of GPS coordinates on the OSD. Can someone point me to the right spot? I cannot find it in the OSD display parameters menu
chasdabigone is offline Find More Posts by chasdabigone
Old Mar 13, 2012, 10:19 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
So I think I solved the reseting OSD. I found a loose servo ground wire. I think that might have been causing some weird interference because after fixing it, the OSD doesn't cut out. This is strange because the servo isn't connected to the OSD in any way shape or form. The ground does run by the GPS wire, so maybe...
I'll fly tomorrow and see what happens.
Old Mar 13, 2012, 10:25 PM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
It's in the GPS setting menu
cody069 is offline Find More Posts by cody069
Old Mar 13, 2012, 10:31 PM
Joined Sep 2007
I cannot find this menu... am I blind? It is in the Eagletree software?
Old Mar 13, 2012, 10:37 PM
cody069 is offline
cody069's Avatar
Joined Dec 2008
I am gusssing your using the OSD..It's in the GPS and Radar Config menu..
Display LAT-LON position
Then there's 5 choices of when it displays ..Or not at all.
Old Mar 14, 2012, 12:54 PM
Ellis108 is offline
Find More Posts by Ellis108
Ellis108's Avatar
Oregon Coast
Joined Jul 2008
deleted...
Ellis108 is offline Find More Posts by Ellis108
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
