Old Mar 09, 2012, 03:46 PM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
Originally Posted by zapi2 View Post
Hi
Is it possible, with the OSD Pro and a 3 Pos. Switch to switch between, OSD ON/OFF and diff. pages manually??
I am going crazy trying to do this without success, any idea?
Tku
Regards
Eric
yes.
3Pos
Aux2 for guardian
move switch from center to away from you and you open the menu.
move switch to you and page turns.
to set this up you must enable the option to turn the osd off. also, if you are paging with the switch, you need to setup pages in the pc software
GregSilver is offline Find More Posts by GregSilver
Old Mar 09, 2012, 03:49 PM
GregSilver's Avatar
Joined Nov 2005
Originally Posted by Infernal Bill View Post
The funny thing is that RSSI shows fine when I first plug in. It's only after I run the servo wizard that it goes to 1.
I've sent my set file and config file to ET, but have not yet heard back.
Bill...this has happened to me a few times too.
save the config.
reset all factory settings and then run the wizard before you upload the config.
test rssi.
for me, I had corupt config file when i tried importing it back in.
Old Mar 09, 2012, 04:41 PM
Infernal Bill is offline
Find More Posts by Infernal Bill
United States, CA, Rancho Palos Verdes
Joined Sep 2010
Thanks Greg. I'll give that a try (Save Config, then reset all factory settings, then run wizard, then upload the confi file). I would have thought that the config file included the wizard settings but maybe not. Crossing my fingers...
Infernal Bill is offline Find More Posts by Infernal Bill
Old Mar 09, 2012, 05:03 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
hi,
don´t safe the corrupt settings. the config file includes the wizzard´s values.
the factory reset will correct the corrupted items and if u restore a old config your personal adjustments are stored again, and you need not to do all from the start again. but you will have to rerun the wizzard.
do the wizzard with the "old" method and use your rx. sometimes the pc-wizzard fail.
cheers Thomas
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Mar 09, 2012, 09:12 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
All, a quick clarification on serial PPM that has caused some confusion. If your ESC is not providing power (ie, a separate BEC is used), or you do not have the ESC connected to throttle out (i.e., nitro) then you need to make sure that the single SPPM connection from you Rx to the OSD Pro has both ground and power, as well as signal lines. Otherwise, your servos will not be powered. In other words, 5V-6V needs to be applied to at least one of the servo in/out connections of the OSD pro for your servos to be powered. I've amended my original instructions to reference this.
mentony32,
At the end of my last 2 flights the summary has reported the maximum distance where the baro altitude should be?
Sorry, I missed these reports earlier. The simplest way to resolve this now is to edit the config file (.txt) and look for the line <Features String="Dis" ... MaxTableOffset="0" .... and change the MaxTableOffset value from "0" to "56". Alternatively, if you wait until we post software version 10.26 or later, this will be automatically corrected. The issue is that your OSD was configured before we started saving the max distance last year, and you haven't created your config from scratch since then (nothing wrong with that!).
catamar, re the issue you're having on running the servo analysis wizard on the PC, can you try these steps:
1) disconnect the Guardian from the OSD
2) confirm on the serial PPM page that your serial PPM is still set up correctly, and the servos are moving correctly.
3) rerun the servo analyis wizard in the PC software
4) Click "ok", reconnect your guardian, and then verify that everything is working correctly with serial PPM.
Pls let me know whether this resolves the issue!
Infernal Bill,
Long story short, it seems as though the new Dragonlink firmware upgrade doesn't play well with the Servo Wizard. When I slap the new DL into my existing gear, everything works great (including RSSI showing up correctly) until I run the Servo Wizard whereupon RSSI just shows up as "1".
That's odd. Here are a couple of notes, that may help:
1) In our official 10.04 release build, RSSI detection will not work correctly when you run the PC version of the servo analysis wizard. You will indeed end up with a "1" I believe.
2) In the 10.25+ alpha version, RSSI should work correctly with the PC servo analysis wizard. But, you will need to rerun the wizard after installation. I'm not clear if you did this?
Note that we still haven't officially documented the PC version of the wizard. We're waiting for it to go through a full beta cycle before doing so.
When you reload the config, the new values captured by the servo analysis wizard will be overwritten by the values in the saved config, if you follow that sequence. It should work if you:
a) reset (not needed, though)
b) load prior config
c) run the servo wizard
billpa is offline Find More Posts by billpa
Site Sponsor
Old Mar 09, 2012, 09:19 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
If I am understanding this correctly, then
People were running a single (signal) wire from receiver to OSD for SPPM.
and in doing so; they failed to supply power as they had previously, through the servo wires.
m_beeson is offline Find More Posts by m_beeson
Old Mar 09, 2012, 10:13 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Mike,
Yes, that's correct. I had mentioned in my original instructions that the power wire of the SPPM connection was not needed, which is sometimes incorrect.
Site Sponsor
Old Mar 09, 2012, 11:34 PM
Joined Sep 2010
Thanks for the input but it's still stuck. To try to really put a fine point on it, here is exactly what I just did:
1. Conduct a factory reset of the OSD parameters.
2. Change the following onscreen parameters: wing is set for elevon, inputs are set for 3 position and Temp 1 to Show RSSI is set to yes.
3. Turn everything on and I can see RSSI on the screen as a *.
4. Run Servo Wizard from my radio.
5. After servo wizard RSSI shows as 1.
I went back and tried the exact same thing but ran servo wizard with the PC and RSSI still shows as 1 after running the servo wizard. I'm stumped.
Old Mar 09, 2012, 11:39 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Bill,
I think I know what is going on...
I saw this before with range link. He thought he had the pin in the correct place, but He was not actually hooked to the RSSI out signal pin. double check and make sure that you have RSSI in the center on the osd, and on the correct pin for your reciever.
I'll bet you are on the power pin, which would explain the display of 100% when you plug it in after the osd is plugged in,
but when you run servo analysis wizzard the voltage never drops during "transmitter off" phase, so it doesn't have a change to compare between good and bad signal.
-Mike
Old Mar 10, 2012, 02:48 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Rssi pin on rangelink is top pin closest to the antenna port 3rd from the left. Mine works great.
Teamsherman is offline Find More Posts by Teamsherman
Old Mar 10, 2012, 08:04 AM
ScoRpiUs2009 is offline
Find More Posts by ScoRpiUs2009
ScoRpiUs2009's Avatar
Australia, VIC, Mordialloc
Joined Aug 2009
hey guys im having an issue that i cant work out, im getting an error msg when i turn on my plane on the OSD splash screen saying "aileron or elevator undetected" .
i recently had a servo fail and put 2 new servos in just in case other failed as well.
ive pulled out all servo plugs and put them back in and replaced my receiver, even tested on 2 other servos but still no play coming from the osd connected wires.
ive connected the servos directly to my RX and they work fine, ive ran the wizard many times after connecting a new options but still nothing.
Also tried a complete reset not just osd but full system.
ive got no mixing on my radio and the osd is set up for elevon, running osd 2.51 with data 10.04
any ideas how to fix this, it all started when i replaced 2 servos without touching anything on the osd
ScoRpiUs2009 is offline Find More Posts by ScoRpiUs2009
Old Mar 10, 2012, 08:46 AM
texasdrifters is online now
Find More Posts by texasdrifters
Joined Apr 2011
Originally Posted by ScoRpiUs2009 View Post
hey guys I'm having an issue that i cant work out, I'm getting an error msg when i turn on my plane on the OSD splash screen saying "aileron or elevator undetected" .
I will get this same error on occasions. My issue was that I was powering up the airplane before the radio. Now, when I turn on the radio first, then the plane, I do not get the error message.
As a suggestion, I am one that thinks anytime you do any modifications to the plane, I always run the servo wizard. This way any changes are communicated to the OSD Pro.
Good Luck,
Hector
texasdrifters is online now Find More Posts by texasdrifters
Old Mar 10, 2012, 08:58 AM
Joined Aug 2009
thanx but my radio is always on before turning on the radio
Good Luck,
Hector
Old Mar 10, 2012, 11:07 AM
Pathfinder22 is offline
Find More Posts by Pathfinder22
United States, FL, St Cloud
Joined Dec 2011
I have inadvertently changed the switch used to access the on screen menu from AUX 1... to a 3 way toggle (which I do not have). I can not activate the onscreen menu now.
Everything has been fine until I did this.
Can anyone tell me how to fix this please?
Pathfinder22 is offline Find More Posts by Pathfinder22
Old Mar 10, 2012, 12:53 PM
Joined Dec 2011
Nevermind. Hooked OSD up with with USB and figured it out.
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
