Old Jan 11, 2012, 08:20 PM
Ellis108 is offline
Find More Posts by Ellis108
Ellis108's Avatar
Oregon Coast
Joined Jul 2008
Originally Posted by freshmint View Post
Your correct the negative is always closest to the PCB board
And thank you!
Ellis108 is offline Find More Posts by Ellis108
Old Jan 11, 2012, 08:59 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by sfakias View Post
Hi Mike,
I bought the relay from my local electronics shop, so I do not have a link for it. In the first photo that I attach, you can see the printed label on it.
It is a 6V relay, but it works fine at 5V too (or about 4.8V that the rc rx has). It has five pins: Two of them are for the armature coil, and I connect them with +5V and ground from the rc rx, through the turnigy rc switch. One pin is for the video output connection, and the rest two pins are for the two video input connections. When the relay is not activated, one input is connected with the output, and when I give 5V to the coil and the relay is activated, the other input is connected to the output pin. The connectors coming out of the final assembly are:
-a servo connector for the turnigy rc switch (also provides power to the relay)
-a four terminal female connector with audio, video, +12V and ground wires from the OSD (coming from the FPV cam)
-a four terminal male connector with audio, video, +12V and ground wires which goes to the A/V tx
-a RCA connector (signal and ground) that connects to the point and shoot cam (common ground with the rest of the components). Note: I hate onboard RCA connectors too, but I did not want to modify the point and shoot cam wire.
I have set up the system in such way that in the case of signal loss the FPV cam feed is selected. The audio is just a pass through, always coming from the onboard mic.
I also attach two pics of the assembly, and a pic of the final product, incorporating the sophisticated packaging of fibre reinforced sticky tape .
Regards,
Stavros
Thank you Stavros
Brilliant insight.
m_beeson is offline Find More Posts by m_beeson
Old Jan 12, 2012, 01:43 AM
papa_lazerous is offline
Find More Posts by papa_lazerous
papa_lazerous's Avatar
United Kingdom, Southend-on-Sea
Joined Feb 2011
Originally Posted by techspy View Post
Anyone else have an issue where you can't enter custom text for RSSI? I am using temp sensor A for RSSI, and the RSSI value shows up on the OSD, but there is no label in the block after selecting the location, and when I try to type in the text I want in the "enter OSD screen name for the parameter", it just beeps and doesn't let me type any characters in it.
I had that issue where I couldn't enter text for my RSSI as I found by clicking on the little box where you enter text nothing would appear after typing.
The solution is simple.... Simply hit backspace a bunch of times and then type in RSSI or my preference Sig (short for signal) The problem is that the text box is already full although it doesnt appear so. Perhaps this is a bug that Bill doesnt know about or perhaps only you and I are doing the exact same thing wrong lol
John
papa_lazerous is offline Find More Posts by papa_lazerous
Old Jan 12, 2012, 09:07 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Ah thanks! I will give it a try!
techspy is offline Find More Posts by techspy
Old Jan 12, 2012, 09:32 AM
Joined Feb 2011
I just hope it works for you or I will look very silly stating such a simple seemingly unbelievable fix lol
Old Jan 12, 2012, 12:27 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
That was it! Seems like the text was populated with spaces when I selected it as rssi. Strange.
Old Jan 13, 2012, 10:44 AM
Ellis108 is offline
Ellis108's Avatar
Oregon Coast
Joined Jul 2008
Hey Bill,
Is there any way to get and on screen msg when a servo is triggered?
I'm not using any of the surface control in or outs, and i'd like to have a indication whem aux 2 lever is flipped (for example).
On my hexacopter it would be handy to see if it was in position hold, RTH or off and also when the camera shutter is triggered. These are using aux 1 and 2 on my TX, but I guess they could be run thru the OSD Pro via rudder and elevator.
Ellis
Old Jan 13, 2012, 01:12 PM
Jhondra is offline
Find More Posts by Jhondra
KF7JBN
Jhondra's Avatar
United States, ID, Nampa
Joined Nov 2008
Originally Posted by Ellis108 View Post
Hey Bill,
Ellis
How about just splitting the channel out and connecting an LED to the output and putting that in the view of your camera?
Jhondra is offline Find More Posts by Jhondra
Old Jan 13, 2012, 01:53 PM
Ellis108 is offline
Ellis108's Avatar
Oregon Coast
Joined Jul 2008
That would work for the shutter, or maybe hook up a buzzer and place it by the mic. Hmmm...
thanks
Old Jan 13, 2012, 09:10 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
try both see which you like best
freshmint is offline Find More Posts by freshmint
Old Jan 14, 2012, 06:18 PM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
Google Earth Question-Issue
I have always been able to view my flights in google earth. I have not used this cool feature for months until today. My flight panned near Africa and the altitude was hundreds of thousands of feet up. I went back to try other files that I know worked. They too did same thing. Anyone have any ideas?
Thanks.
Tony97 is offline Find More Posts by Tony97
Old Jan 14, 2012, 06:24 PM
n5iln is offline
Find More Posts by n5iln
United States, CA, Salinas
Joined Nov 2011
Google Earth changed their API format. I think Bill has a fix in the newest alpha firmware for the e-logger.
n5iln is offline Find More Posts by n5iln
Old Jan 15, 2012, 05:11 AM
voodou is offline
Find More Posts by voodou
France
Joined Aug 2010
Hi all, I'll like to know if eagle tree osd users are using aileron or rudder for autopilot with skywalker?
Thanks in advance.
voodou is offline Find More Posts by voodou
Old Jan 15, 2012, 05:25 AM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Thanks in advance.
Rudder works better. This is also stated in the OSD manual.
sfakias is offline Find More Posts by sfakias
Old Jan 15, 2012, 05:26 AM
voodou is offline
France
Joined Aug 2010
Thank you
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
