Old Jan 08, 2012, 09:19 AM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Many -many thanks toy you Jhondra for taking the time to write such a long post to explain in detail the steps that should be taken for a successful RTH setup. I will try to put them into practice the next time I am at the field, and I have the feeling that things will be greatly improved.
Just a couple of notes:
1) I am using rudder for turning, not ailerons (but the same principles apply)
2) Indeed by "stable I mean that it wants to gradually pull out of a dive, and generally wanting to self-correct back to level straight flight. Actually, this plane is so stable that some times I just leave the TX on the bonnet of my car for a few minutes and enjoy drinking coffee while watching the plane gently circling 200 or 300 meters above my head! However, you are right that the control surfaces have rather a lot of deflection since I like my planes to be very maneuverable. I give only very slight stick deflections during the servo analysis wizard, but still it is enough to cause tight turns. I suppose I should start by mechanically reducing the throws (at the servo arm holes) in order to tame the flying characteristics, and also provide the OSD with more resolution (and hence accuracy) over the position of the control surfaces.
Once again, thank you very much for your excellent detailed post.
I will keep you gents updated when new results are available.
Best regards.
sfakias is offline Find More Posts by sfakias
Old Jan 08, 2012, 09:28 AM
Jhondra is offline
Find More Posts by Jhondra
KF7JBN
Jhondra's Avatar
United States, ID, Nampa
Joined Nov 2008
Originally Posted by sfakias View Post
Many -many thanks to you Jhondra for taking the time to write such a long post to explain in detail the steps that should be taken for a successful RTH setup. I will try to put them into practice the next time I am at the field, and I have the feeling that things will be greatly improved.
My pleasure. There are about 20 hours of video of me working to make RTH very robust on my plane. Honestly, without something like Gyro/closed loop feed back, it will never be "error proof", but you can get it working pretty well, if you start with a very stable plane. FIRST.
Correct. Sorry, I just saw later post from you saying you use rudder...but yes, it will be roughly the same as long as you have an airframe that behaves well (with this being a scratch built, I'm assuming a lot about the robust behavior of the airframe, so I'll let you make sure that is bugged out separately).
Yeah, I do too. But for FPV and RTH, maybe just try a test flight with VERY minimal throws in (either limited on your end points or better, move the throw in the servo arm holes and far out on control surface horns...make sure everything has enough control in normal flight first, and take note of servo deflections needed for nice smooth slow turns to do during servo wizard on ground). Start there and see if that works for RTH better. Also, after spending a LOT of time on this, I strongly would encourage you to consider getting the guardian. It makes most of this much simpler and can handle a LOT more situations gracefully...
Best regards.
Good luck! Good RTH behavior is CRITICAL to being able to move to the next phase, which is worry free "bucket list" flights (distance, height, and any number of other things that would otherwise risk the plane and equipment).
Jeff
Jhondra is offline Find More Posts by Jhondra
Old Jan 08, 2012, 09:37 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
sfakias
It looks like you have gotten a lot of good advice.
the only thing that really stands out to me is that
I would teach it the full throws in servo analysis wizzard, and then adjust the settings to make it fly smoothely.
you are trying to do too much stuff that you can't control as a standard.
use the wizzard as it should be used, and then make your setting adjustments.
m_beeson is offline Find More Posts by m_beeson
Old Jan 08, 2012, 09:59 AM
Dadude is offline
Find More Posts by Dadude
Nothing but high quality
Dadude's Avatar
United States, CT, Glastonbury
Joined Jun 2008
So a weird thing happened today. I when to fly my new sky surfer (More info found here http://www.rcgroups.com/forums/showthread.php?t=1569242), I plugged it in, and I got nothing. I had no control with my radio, my guardian wasn't working, and I had no video signal even though my video tx and ground station was powered. Has my OSD failed?
Jon
Dadude is offline Find More Posts by Dadude
Old Jan 08, 2012, 10:16 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by Dadude View Post
Has my OSD failed?
Jon
Unlikely.
I would look at the reason your (flight) reciever is not working. If your Vtx is working, then I would think that you aren't getting power some where else.
-Mike
Old Jan 08, 2012, 10:24 AM
Jhondra is offline
KF7JBN
Jhondra's Avatar
Joined Nov 2008
Jon
Nice clean build. Color me jealous.
Not sure how you have power routed for VTx and OSD/Rx, but something tells me you aren't getting power to the OSD and Rx, which will still have VTx working...look to your power connections/BESC...
Old Jan 08, 2012, 11:46 AM
Dadude is offline
Dadude's Avatar
Joined Jun 2008
It's my castle BEC . I just tested it. It simply outputs the voltage of the pack and doesn't step it down out all! That means my OSD, all my servos, and my rx, were submitted to 12volts.....If the sensors are powered off the OSD then those may have received 12 volts as well. This is bad....is my stuff shot? I really didn't expect this from castle I have only had good luck with them in the past.
Jon
Old Jan 08, 2012, 11:53 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Jon
Jon
I run all of my sensors straight from the 3SLiPo.
The Eagle tree components can handle 12V.
But your camera may be shot if it takes 5V.
This would account for a lack of video.
The only way to know is to fire everything up (that requires 5V.) on 5V.
Old Jan 08, 2012, 11:59 AM
Dadude is offline
Dadude's Avatar
Joined Jun 2008
Okay that's good news. The camera runs off of 12 volts so it should be fine. But the OSD won't initialize unless it get's signal from the Rx right? Wouldn't that also account for a lack of video? Hopefully it's only the servos and rx that have gone.
Jon
Old Jan 08, 2012, 12:10 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Okay that's good news. The camera runs off of 12 volts so it should be fine. But the OSD won't initialize unless it get's signal from the Rx right? Wouldn't that also account for a lack of video? Hopefully it's only the servos and rx that have gone. Ugh, so much work for this outcome, hopefully I can get it resolved soon.
Jon
Humm,
I don't think so.
Maybe you are getting some strange electrical phenomenon from the BEC.
What you might want to do is unplug the 5V. components, and fire it up.
It sounds like the only thing that you are running on 5V is the receiver...
You may want to disconnect 2 of the motor wires in case it goes into failsafe, or better yet, take the esc out of the loop for testing purposes.
Old Jan 08, 2012, 12:34 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Dadude,
I would also check to make sure that you don't have a bad connection /or broken wires to the camera.
You can pull power and ground from the plug, and see that you are getting 12v.
and you can check resistance across the signal wire.
also this is probably not an issue, but check to make sure that your Vtx and Vrx are on the same channel.
if you are using EE, then make sure that your input matches the Vrx input that you are using.
-Mike
Old Jan 08, 2012, 01:52 PM
Jhondra is offline
KF7JBN
Jhondra's Avatar
Joined Nov 2008
Jon
hum...something tells me you are getting something crossed from your 12v camera supply onto your BEC/Rx 5V VCC...unless you've confirmed that the castle BEC pulled clear out of the whole system and checked is actually providing 12V...seems strange to me if it is...
Are you CERTAIN you aren't pushing the 12v camera voltage into the center/Red pin of the OSD from/to the VTx/Camera connection on the OSD plugs?
Old Jan 08, 2012, 02:26 PM
Dadude is offline
Dadude's Avatar
Joined Jun 2008
When I tested the BEC it was independent of the osd and the video system. If you look at the picture of the plane, I tested the BEC through the molex connector that was in the plane, with the osd and video gear not even being powered or plugged in. Does that make sense to test it that way?
And yeah my rx and tx channels are the same. The inputs and outputs check out as well. It's so weird that I didn't touch the plane and that it worked perfectly 24 hours earlier. I should be thank full that I didn't get any of these problems in the air
Thanks you guys very very much for helping me out with this, I really do appreciate all of the input.
Jon
Old Jan 08, 2012, 02:49 PM
smoln1 is offline
Find More Posts by smoln1
2R Fly Team
smoln1's Avatar
Slovenija, Radovljica, Radovljica
Joined Jul 2009
Originally Posted by smoln1 View Post
I wonder what is in version 10.04 so new? Yesterday when I upgraded to version 10.04 with guoridan stabilization, servo motors had a sudden very little deviation. In no way I could raise them. But when I put back the old version 9.99 were set to decline back to normal.
In what could be the problem?
Thank you for your answers.
anybody?
thanks
smoln1 is offline Find More Posts by smoln1
Old Jan 08, 2012, 04:37 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
sfakias
hi sfakias,
pls use small servo deflections during the wizzard. if you use no guardian, these deflections will be used to control rth .... and your turns will end in the "spiral of death". Rabe2002 made a nice video of this, youŽll find it on the first pages of this thread.
sorry Mike ... full servo deflections during the wizzard is only for use with the guardian (rtfm).
cheers Thomas
Thint1 is offline Find More Posts by Thint1
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
