Old Jan 04, 2012, 04:17 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by m_beeson View Post
Set reciever failsafe to Throttle trimmed down as far as it will go.
then when you run the servo analysis wizzard, you set the motor off position to throttle trimmed down as far as it will go,
your cruise throttle position to the position that you would normally cruise.
set your climb position to the position that you would normally use to climb.
If you over power the climb, then sometimes it works against you.
Hope this helps.
Is it as easy as it sound? What is rocketman friend doing wrong?
freshmint is offline Find More Posts by freshmint
Old Jan 04, 2012, 06:34 AM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
You might want to try this: turn everything on ..have some one hold the plane (so it does not take off) stay clear of prop
turn off transmitter. what happens
That All I Got
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Jan 04, 2012, 09:42 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
My normal Throttle trim is 10 clicks up from center point.
When I arm the esc, I click down 5 clicks, and then back up 5 clicks.
If I go 10 clicks down to center point, then RTH engages.
I'm sure that I could do something with sub trims, but that is the way it is.
Hope this helps...
m_beeson is offline Find More Posts by m_beeson
Old Jan 04, 2012, 09:57 AM
Jhondra is offline
Find More Posts by Jhondra
KF7JBN
Jhondra's Avatar
United States, ID, Nampa
Joined Nov 2008
Hope this helps...
You should also be able to program a throttle cut off (depending on Tx) that just drops the throttle for like gas powered shut off. Make that setting your Fail Safe, and use it when running the servo wizard for RTH, so now, the throttle cut puts it into RTH, and so does radio off (FS). Saves monkeying with trims...
Jhondra is offline Find More Posts by Jhondra
Old Jan 04, 2012, 09:58 AM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
Originally Posted by Rocketman1092 View Post
Hey guys,
I'm having some issues configuring RTH to engage via the throttle trim method. I set the receiver failsafe with the throttle trimmed to about -25%, then completed the wizard on the OSD Pro. When the throttle trim is reduced, RTH activates properly, but throttle increases by about 25%. Then, when the trim is returned to zero, the throttle stays at the ~25% speed. It's as though the ESC (Thunderbird 36) adapted itself to the negative trim as the new zero throttle endpoint. Any thoughts?
Note: I'm actually describing a friend's airplane here. I have a nearly identical setup, though with a HobbyWing ESC instead of the Thunderbird 36, that I'll be testing shortly.
I did have one ESC (not thunderbird) that did not like the trim going below what it thought was off. Durring operation it would relearn what minimum was, then when I trimmed back up what should have been off, the motor keept going. I swaped ESC's and it started working normally.
yzguy is offline Find More Posts by yzguy
Old Jan 04, 2012, 10:00 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Good point J. I was thinking about putting stability on a switch, I need to study that because I haven't entertained the thought until last night.
but the issue is that people can't get the RTH throttle to work.
Old Jan 04, 2012, 10:03 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Hope this helps...
I should also state that If I go 12 clicks up from center point, then the motor runs.
Hope this helps.
Old Jan 04, 2012, 10:07 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Yes it is that easy. If you follow the outline that I have below, then there is no reason for not having proper RTH engagement/disengagement.
If you follow these steps and RTH does not work, then you have something strange going on.
Hope this helps.
Hope this helps...
Hope this helps.
Old Jan 04, 2012, 02:46 PM
KJ4YYJ
Saint Petersburg FL
Joined Jun 2009
Can this be used with Eagle Tree set up?
R/C Controlled Dual Camera Switch
http://www.dpcav.com/xcart/product.p...7&cat=0&page=5
thanks for the help.
Old Jan 04, 2012, 06:13 PM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
That's the one I've been using. Works fine. I believe that's one that was recommended by Billpa.
balsabuster2004 is offline Find More Posts by balsabuster2004
Old Jan 04, 2012, 08:42 PM
Joined Nov 2011
What Tx are you using?
Old Jan 05, 2012, 01:25 AM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
I opted for the cheaper DIY solution for an RC video switch, using this rc controlled switch and a 6V relay switch from the local electronics shop (cost about $1).
I attach the electrical wiring diagram that shows how I connected the two. Note that the OSD info is overlayed only on the 12V FPV cam video, and not on the video from the point and shoot cam. The final result is a little bulkier that the ready made video switch, mainly because of the size of the relay.
It works great!
sfakias is offline Find More Posts by sfakias
Old Jan 05, 2012, 08:40 AM
Jhondra is offline
KF7JBN
Jhondra's Avatar
Joined Nov 2008
Futaba 9CAP Super.
Old Jan 05, 2012, 11:47 AM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
That looks to be the problem. I tried the same procedure with a HobbyWing ESC instead, and everything works great now. We'll swap out the Thunderbird.
Thanks for the help everyone.
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Jan 05, 2012, 09:31 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I've just about got RTH dialed, on the wing;
it's very close
Flying Wing with RTH (1 min 25 sec)
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
