Old Dec 19, 2011, 03:30 PM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Originally Posted by ashdec87 View Post
If I'm not mistaken there are export issues when it comes to autopilots leaving the US. That's why audopilot makes you sign all sorts of stuff.
It may be so, but we are talking for firmware (software) leaving the US (or it could be distributed from a server anywhere in the world). The physical equipment is already exported, and new parts can be exported without the firmware that has these features, and without purpose-built hardware additions, since they are not required anyway!
I personally think that there are legal workarounds, and ET could implement such features without having any troubles, but of course I am not knowledgeable at all on such legal matters.
At the end of the day, there are other systems (FY systems for example) that offer such features, and can be easily acquired from China, in case any one wants to use them for illegal activities. Preventing US companies to export their technology does not reduce the terrorist threat, or whatever the lawmakers are trying to avoid. It only reduces capital income to the US, which leaks to,usually, China.
Implementing these features will put the ET system on a league of its own, ahead from many other (similarly or higher priced) systems.
If you do not agree with some or all of the above, please do not fire away, they were just a looong introduction to lead to the main point:
Eagle Tree team pleeeeease give us these features.
Thank you for your patience - Peace
sfakias is offline Find More Posts by sfakias
Old Dec 19, 2011, 06:12 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
here's the video of my latest. RTH test in the beginning. Does that initial turn seem too tight? Also my first time out to 2 miles.
SWlongrange (3 min 16 sec)
ashdec87 is offline Find More Posts by ashdec87
Old Dec 19, 2011, 07:48 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Does the RTH work on flying wing with no rudder?
freshmint is offline Find More Posts by freshmint
Old Dec 19, 2011, 07:53 PM
Joined Nov 2011
http://www.youtube.com/watch?v=gmPov...ature=youtu.be
whats your setup and plane?
Old Dec 19, 2011, 09:06 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Plane is Skywalker. Video tx is LM 2.4ghz 500mw with an inverted V antenna. On the ground is an 8dbi patch and 16 dbi yagi. I'm running a 4s 3500 pack (on this flight).
And yes it will work on a wing, I don't have the RTH on the rudder.
Old Dec 20, 2011, 12:15 AM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
Don't be afraid to go further, you can easily go 30000 ft, just remember to climb about 400ft per mile to keep a good LOS to the antennas. But don't exceed 400ft in the US
thekubiaks is offline Find More Posts by thekubiaks
Old Dec 20, 2011, 12:38 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
My video was SOLID at 11K as you can see. Two reasons I turned back. 1) my battery was past its halfway mark and there was some odd wind at altitude that wasn't there at ground level, so I didn't wanna run low on battery. Turns out I had a STRONG tailwind on the way back. 2) I was freezing and couldn't take much longer lol.
Next distance run will be to 2.5 or 3 miles. And there was something wrong with my sensors. I was below 400ft the whole time, but it kept reading much higher
Old Dec 20, 2011, 01:16 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Yeah alt reading can be a bit off at times...
rcimports is offline Find More Posts by rcimports
Old Dec 20, 2011, 01:25 AM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
Yeah, mine always returns to normal once I get it back on the ground
balsabuster2004 is offline Find More Posts by balsabuster2004
Old Dec 20, 2011, 04:17 AM
piet9 is offline
Find More Posts by piet9
piet9's Avatar
Christchurch NZ
Joined Sep 2009
ATTF for their Dec / Jan "giveaway" have a new ET product, also Bill on a Jan podcast to answer questions....that can be emailed into show
http://www.allthingsthatfly.com/prize.php
http://www.allthingsthatfly.com/index.php
Cheers
Neil
piet9 is offline Find More Posts by piet9
Old Dec 20, 2011, 08:43 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
Hey mate.
What's your flight cam. The image looks good to me.
joel0407 is offline Find More Posts by joel0407
Old Dec 20, 2011, 09:38 AM
Joined Aug 2010
I found a cool website to find winds aloft. I usually start my runs into the wind and know that if I get to near half battery, the winds will help me get home with juice to spare.
http://www.blastvalve.com/weather/we...et+BalloonCast
*** CHECK OUT THE RUC WIND PROFILER in blue about halfway down
Old Dec 20, 2011, 11:14 AM
Joined Jan 2004
Very interesting website. should be valuable.
Old Dec 20, 2011, 11:58 AM
fordarrick is offline
Find More Posts by fordarrick
United States, CA, Redlands
Joined Dec 2009
nob quest.........What is HDOP? And what is it used for? Thanks
Darrick
fordarrick is offline Find More Posts by fordarrick
Old Dec 20, 2011, 12:12 PM
Jhondra is offline
Find More Posts by Jhondra
KF7JBN
Jhondra's Avatar
United States, ID, Nampa
Joined Nov 2008
Darrick
I believe it is "Horizontal Dillution of Precision", and it roughly translates to how precise the location projected of GPS is (higher is worse...think variance). I typically get numbers below 1 on ET systems with 8-10 sats, and I don't know what the relative "meaning" is (like is is 1foot, meter or what). Use it for a relative measure of 3D positioning signal resolution. Typically, I think hand held GPS use this to draw the error circle around your location...larger radius for more variability and uncertainty with worse signal or fewer sat locks.
-JM
Jhondra is offline Find More Posts by Jhondra
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 10:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 09:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 07:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 10:16 PM
