I do have the pitot tube
Latest blog entry: SS FPV Maiden
Joined Aug 2010
milwaukee wi usa
Joined Nov 2000
level zero noob question alert. Audio Connections on ET OSD PRO PKG
Audio Connections on ET OSD PRO PKG to Advanced FPV Stater Pkg
im just starting to set up an eagletree osd pro w/gps to my rmrc system. http://www.readymaderc.com/store/ind...roducts_id=279 everything seems to be working properly except for the camera's mic. (no sound!). with the RMRC system, the audio only has one wire (the audio signal) in its futaba connector...which plugs into the AUDIO IN of the OSD PRO. first question.....do i need to also wire a ground (and/or power) into this futaba connector?? and regarding the AUDIO OUT. there are 3 wires... ground, power, signal. looking at the instructions (which is confusing to a FPV noob as i am)...they do not show a red wire (power) in their diagram. my connector has all 3 .... which is plugged into the OSD audio out. sooooooo...am i screwing up??? please advise!!! thank you |
another possibility to tune ... lower the ahi until the gliding angle (or gliding speed) is o.k. this can be done editing the settings-file ![]() look http://www.rcgroups.com/forums/showp...postcount=1314 cheers Thomas edit: i use this method to correct a different drag of the wings caused of a second cam mounted on one wing. |
for video or audio the power is connectect between in and out thru the osd. but itīs not connectect between video and audio. make sure, that you have the correct voltage for audio on one of the power-pins .... i doubt that your power on audio may be a output. if you canīt measure a voltage on the aud.power you have to support the correct voltage on your free pins on audio in. cheers Thomas |
Joined Aug 2010
i donīt know exactly how the software works ![]() but: the "level" teached in during "reset pitch and roll" are this values ... changing influences the position of the ahi on the screens and the level to which the stabilisation will correct the plane. cheers Thomas |
I posted this over in the Guradian thread as well, can someone please give me some pointers what to change?
*** I need some help on 2 things please, sorry no vid, forgot to record.. Airframe is a GWS Slow Stick, elevator/rudder, Main gain set on Guardian set to 6, all other setting on defaults. 1. When I hit RTH (Carlyle Method) the plane makes a nice quick trun and heads home, problem is sometime it goes past home and heads into a direction and doesn't seem to stop, haven't left it till it turns yet, I get to scared and turn of RTH. What do I set to change that, home radius maybe? This is without any wind. 2. See attached amps log, it pulses the throttle alot at the RTH altitude, is that normal or can I change that as well? Thanks! Dion |
No, not home radius. If you get your home radius too small, then the plane will fly in, and out of the home radius while circling. This may be a problem if your RTH, and Home altitudes differ. I would look at "Turn Derivative Gain" in the Safety configuration Menu. The plane is given a target. It starts working on a solution for that target. The derivative gain defines how long it takes before it sees an error in its solution. Too low of a derivative gain and it will never see an error message. I don't know what will happen with too high of a derivative gain. I would assume that it would tighten the turns around the home position. If your plane is flying past home and doesn't want to turn, then I would start Increasing the Turn Derivative Gain until it responds and circles around home. -Mike |
the osd tries to hold the hight. the "learned" throttle position for level flight is used for this. if your throttle was too high during the rc-wizzard the plane will do a climb ... then the osd reduces throttle to sink until the plane is too low .... try to reduce the throttle during the wizzard an make a testflight. cheers Thomas |
| Thread Tools | |
| For Sale BRAND New CP Pro/with extra battery | stgtech2 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 06, 2006 09:35 PM |
| New eolo pro glitches with cc60 | aschen | Electric Heli Talk | 24 | May 20, 2004 08:12 AM |
| FS New Piccolo Fun with bearing upgrade and HA tail motor | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2004 06:32 PM |
| For Sale: NEW Pic Pro rotor head with stiffening mod | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 02, 2003 09:16 PM |
