Old Dec 08, 2011, 05:39 PM
Pixturethis is offline
Find More Posts by Pixturethis
Pixturethis's Avatar
Wichita
Joined Dec 2008
Ok, think I found the problem, you will be happy to know it was me.
1) wrong model. Two anes that are pretty close, but RTH is different.
2) new plane didn't have failsafe setup. I saw that I couldn't get it to come on at all.
So now it is all fixed, ready for another flight, have to wait on weather for that.
Marc
Pixturethis is offline Find More Posts by Pixturethis
Old Dec 09, 2011, 01:42 AM
zapi2 is offline
Find More Posts by zapi2
Dead_Stick_7060
zapi2's Avatar
Espaņa, Comunidad Valenciana, Alicante
Joined Jun 2003
Hi,
Just one question, I got a main menu popup yesterday, quite far from the home, I got a "kernel panic" and I touch the wrong switch and confirm the reset. Fortunately that was a very good flight "without" problems and I land safely at home.
In order to avoid that and to solve some other things I want to try the last alpha firmware.
Any recommendation about it, should I start a new config or use the updated one? Should I run a servo wizard?
Tku
Eric
zapi2 is offline Find More Posts by zapi2
Old Dec 09, 2011, 06:51 AM
smoln1 is offline
Find More Posts by smoln1
2R Fly Team
smoln1's Avatar
Slovenija, Radovljica, Radovljica
Joined Jul 2009
Hello!
Question: i have Sherrer LR system. In failsafe option what option must set for RTH, PCM -failsafe or PPM no failsafe? I don' know what is the right. Guordian works great, just RTH must set for long range.
Please anybody help.
Thanks!!
smoln1 is offline Find More Posts by smoln1
Old Dec 09, 2011, 07:06 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by smoln1 View Post
Hello!
Thanks!!
PCM -failsafe
m_beeson is offline Find More Posts by m_beeson
Old Dec 09, 2011, 07:21 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
Originally Posted by sfakias View Post
2)Ability to fly to waypoins autonomously (like when in RTH mode)
This would be about the only thing that could sway me away from another ET at the moment. Auto waypoints would be awsome. Just site back and enjoy the scenery.
joel0407 is offline Find More Posts by joel0407
Old Dec 09, 2011, 07:48 AM
smoln1 is offline
2R Fly Team
smoln1's Avatar
Joined Jul 2009
Originally Posted by m_beeson View Post
PCM -failsafe
thanks m_beeson. I like your presentation videos. I looked all of them. I use FPV 1 year. After 1 year I decided set up RTH to funkcion. If I need more help, I will ask here.
Old Dec 09, 2011, 09:38 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Same here, that would be brilliant!
I **Think** it's a legal issue though..
rcimports is offline Find More Posts by rcimports
Old Dec 09, 2011, 10:01 AM
Gundy is offline
Find More Posts by Gundy
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Waypoints and loiter would be huge.
I have the full Eagle Tree System on my Falcon wing. and it works great.
I have a different system on my X-5 wing that has loiter, RTH, auto landing and auto launch. All the features are controlled with a single switch.
These are the things that would make Eagle Tree Perfect.
Also a data base with different RTH setups in it.
I am moving my Eagle Tree setup to one of my new Zephyr ZII wings. But I hate the thought of starting the set up from scratch... it would be nice to have a starting point.
Later,
Gundy
Gundy is offline Find More Posts by Gundy
Old Dec 09, 2011, 11:23 AM
smoln1 is offline
2R Fly Team
smoln1's Avatar
Joined Jul 2009
Hello
Sets RTH function. Why am I Guordian during calibration of the system, setting the RTH feature turned on at the top of the screen constantly says:
RTH Engaged: Rx Failsafe Detected
I could not find anywhere, or do I have a failsafe feature is turned on or not between the receiver and transmitter long range. If you turn off this feature, always says:
I have a 100% signal, servo motors Wizzard I've done. When you move the lever on the Futaba 6ex, but this time the sign disappears. Then it reappears. Why this feature is always turned on? Have I set something wrong or forgot?
Thank you
m_beeson?
Old Dec 09, 2011, 12:13 PM
Ricardohpb is offline
Find More Posts by Ricardohpb
Joined Jul 2011
I installed my system did not work Eagle Tree and see pictures of the OSD Pro as they were:
http://youtu.be/vw157ej34Xk
tried everything and did not find the error.
Ricardohpb is offline Find More Posts by Ricardohpb
Old Dec 09, 2011, 12:17 PM
South Africa
Joined Oct 2005
Old Dec 09, 2011, 02:48 PM
Grips is offline
Find More Posts by Grips
Eat-Sleep-Work-Fly-Repeat
Grips's Avatar
Canada, NL, Division No. 9
Joined Mar 2011
I'd just like to ask a question for some clarification. For anyone to use an Eagle Tree Component, one of the loggers is required as a the very most basic part? You add all of the OSD Pro, Guardian, yada yada to the logger.. correct? OR Can you use the Eagle Tree OSD PRo on its own with nothing else?
Grips is offline Find More Posts by Grips
Old Dec 09, 2011, 03:47 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
OSD Pro comes in a kit which includes:
*OSD
*e-logger v4
*GPS
If you want the guardian or other microsensors you purchase them seperately.
So to answer your question,
Osd pro is a complete package.
-Mike
Old Dec 09, 2011, 04:03 PM
smarm is offline
Find More Posts by smarm
Joined Oct 2011
Got video ground connected properly?
Change your white/black settings.
smarm is offline Find More Posts by smarm
Old Dec 09, 2011, 04:13 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
That's not white/black setting issue.
I think you were right about it being a bad connection somewhere, or wrong wiring. There's something strange happening.
This is just a hunch, but I would disconnect the Microphone and try it before you go anywhere else with your trouble shooting.
If that doesn't work:
I'd try disconnecting every non-essential component. check your critical wiring, and re connect each non-essential component back to the osd (one at a time).
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
