Gosh sometimes it feels like this system is against me~
Coming back at it after another rest waiting for a new altimeter, and put it all together with the tested twice guardian and new V4 Elogger and OSD Pro. Was going through the setup options of the guardian on screen when all of a sudden i get a error message! First time i have ever got one of them~ Funny thing is it seems to all work ... but i just cant trust it i guess ... it has some sorta error. I have opened a ticket for this ... im sure once it's all going it will be awesome! /edit Had the 10.08 version of the Data Recorder installed, uninstalled that and put 10.04 on ... now it dosent recognise my altimeter although its still plugged in the same and flashing like it was when it was recognised by the newer firmware ?? I did roll back the OSD and Elogger fw but then the altimeter disapeared!!! |
White wire melted????
Hi guys, been trying to setup my elogger v4 + gps + OSD pro on my ritewing Zephyr and after many times seeing wobbly lines across my video feed I have discovered that my OSD pro seems to have almost melted all the white plastic off the white wire that connects the osd to the elogger. I don't know how this has happened but I thought I would ask if anyone else has had this happen and also would this be the reason for interference I'm seeing in my video feed. When I unplug the osd and run the video straight through to vtx the feed is fine with no interference. So must be something going on in osd pro. Any suggestions? I think I may have to send it back for replacement?
^ Yep i have had that happen too .... look a lil something like this pic below?
If you search this thread for melted you will get some results. Basically from what i can understand it happens when you have a bad connection elsewhere and the ground gets routed through the system and the lil wire cant handle the amp draw and melts. In my case i had a bad earth connection to my elogger ( i think it was that one) and it found its own earth through the system. The plane seemed a bit underpowered before it melted and the plane came down ,,, it was underpowered because it was choked up lol. Anyway i had a mate who is a electronics wiz resolder a new wire on (half a extension cable) and it still didnt work properly. Opened a ticket sent it back with the Elogger V3 (just to make sure) and it ended up causing a problem with the elogger. I ended up paying for the repair/upgrade to a Elogger V4. I am no expert and this may not be what happened in your case ... just passing on stuff. Best bet is get the ticket happeneing. |
Ok, new problem. Just want to see if anyone has seen this before I open up a ticket.
Running 10.4. OSD pro,egogger v4, gps, alt,airspeed, & guardian. Well I've lost one plane because of this, so with the new plane in the air I get a "RTH engaged" when my amps are between about 4.0 & 7.6 amps. 4 amps is what I cruise at & 7 is climb. I thought I had a bad ecs, but after changing it. I still have the same problem. Everything in this plane came out of the last one & flew for 6 months without any troubles. Then last month I was going to make a long distance flight & right after take off I went to climb amps & got a fail safe, I was only 20 ft off the ground & lost the plane.. Thanks Marc |
mamut,
Floater, Quote:
yzguy, Quote:
sfakias, i can confirm that Google Earth was recently revised and broke compatibility with our KML files (why, oh why???) and our latest alpha software has been updated to accommodate the change. Bud, what error message were you getting? Regarding the altimeter, are you sure it is not being detected? The altimeter V4 will sit right at zero, with no fluctuation, for long periods of time (until you lift it). Pixturethis, sorry to hear about that! The first step is to figure out why RTH is triggering. How do you have RTH set up? Do you have a video clip? Also, can you post your OSD config settings (.TXT)? The config file will let me see how RTH is configured. |
Hi Bill, yep sure it isnt being detected ... it was before i rolled back the main software.
I opened a ticket about it ... but no response yet. Error code is 0306BE ... would be keen to know soon if i have to send it back because i was all set to fly after not being in the air since August .... and then this happened~ |
Hi
"Can you make an upgrade for pan&tilt the emitter antenna(5.8 Ghz little patch) to the ground station" I rephrase it Can you make an upgrade for the OSD that can pan/tilt the video EMITTER antenna (the one from the plane to direct the entire emitting energy to the receiver that is on the ground) - so no more omni but a patch pointed to the ground station? Something like Eagleeye for emitter on the plane(maybe on the same principle but smaller) Thank you |
I will take this opportunity to remind that there are more simple changes that a few people have been asking for a while. I quote my post from 28th July: "1)Ability to increase the radious of the waypoints (this has been partially done but it is still restrictive "LOS") 2)Ability to fly to waypoins autonomously (like when in RTH mode) 3)Ability to hold pattern above waypoints (circle for aerial photography for example) 4)Eliminate the resetting of the distance at 65000 feet" The above are a collection of various members suggestions, and should be much easier to implement, but they still have not been done. I believe Bill is generally doing the best he can, but we must recognize that due to his workload (and maybe legal matters???) not everything can be implemented. Nevertheless, an update on the status of the above should be interesting. |
Joined Jan 2007
| Thread Tools | |
| For Sale BRAND New CP Pro/with extra battery | stgtech2 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 06, 2006 09:35 PM |
| New eolo pro glitches with cc60 | aschen | Electric Heli Talk | 24 | May 20, 2004 08:12 AM |
| FS New Piccolo Fun with bearing upgrade and HA tail motor | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2004 06:32 PM |
| For Sale: NEW Pic Pro rotor head with stiffening mod | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 02, 2003 09:16 PM |
